Diesel fuel - Dodge Cummins Diesel Forum
 9Likes
post #1 of 21 (permalink) Old 06-16-2019, 10:47 PM Thread Starter
Diesel fuel
So. Bought a truck new in 16. Has 1800 miles on it. Had to go away for couple years. Fuel is about year to 2 years old. Is the fuel in there bad? Or good to roll??
LA11 is offline
post #2 of 21 (permalink) Old 06-16-2019, 11:15 PM
Sitting for 2 years? I would drain and replace every fluid in the truck, change every filter as well. That is a lot of time for condensation to build up.
Lins and jdjonesiii like this.
2016 Ram 2500 Big Horn Mega cab, 285/75-18 (35's) Nitto Ridge Grapplers. Fuel Hostage III 18x9 +18 BS Wheels. Bilstein 2.3″ Front Lift, 1" rear spacer.
mtnrider is offline
post #3 of 21 (permalink) Old 06-16-2019, 11:46 PM
boshog's Avatar
I would be concerned about the DEF, that will need to be drained and purged from the system. Engine oil and fuel, that depends on the environment the truck sat in for the past two years.
2015 3500 LongHorn CC, 4x4, SRW, CDT, 68RFE
2013 1500 Laramie CC, 4x4, 8 speed
boshog is offline
post #4 of 21 (permalink) Old 06-16-2019, 11:57 PM Thread Starter
It doesnt need def 😉 its been started here n there ran for about 20 mins but never ran long enough to burn all the fuel in there. Still take diesel out??
LA11 is offline
post #5 of 21 (permalink) Old 06-17-2019, 12:15 AM
HeavyTwo's Avatar
On the DEF, you probably gonna want to drain and replace. It is a precise mixture of mostly water. Over time, the water evaporates changing the mixture. The system sees a slight change in the mixture and puts a check engine light. Of course, you can just put some electric tape over the check light to fi it. ( DO NOT use clear masking tape, it just blurs the "check engine" error light)
However, if the mix is too far off, the system will put truck in to limp mode. Requiring a dealer visit.
Or use a OBDII blue tooth tool to clear.
If the DEF tank is near empty, maybe you can get away with just filling it. Same with the fuel, if its near empty, filling it should help.
I'd definitely change all filters ASAP.
2014 RAM HD. Cummins 6.7 364.5SXE Turbo. EZLynk Tuned. Straight piped. Air-Ride.
HeavyTwo is offline
post #6 of 21 (permalink) Old 06-17-2019, 12:16 AM
Ltngdrvr's Avatar
It doesn't need DEF??? Why???
DEF sitting in the truck that long is definitely bad, and the fuel likely has algae growing in it as well as condensation contamination.
As stated, drain and replace EVERY fluid and filter if you plan to keep and drive the truck, or be prepared for lots of aggravation with expensive repairs.
CCV reset/seatbelt chime disable https://www.cumminsforum.com/forum/2...tml?highlight=
Ltngdrvr is online now
post #7 of 21 (permalink) Old 06-17-2019, 12:32 AM
akhr's Avatar
Maybe his truck no longer uses def 😉. I’ve ran a 2nd gen truck that’s was parked for over 2 years. Had a full tank wasn’t gonna waste it. Only thing was the gauge level got stuck but eventually freed up. I wouldn’t worry about it. Maybe put some diesel treatment or fresh diesel in there and change the fuel filters if it makes you feel better.
Jimmy N. likes this.
akhr is offline
post #8 of 21 (permalink) Old 06-17-2019, 12:44 AM
HeavyTwo's Avatar
side subject
why is it showing " def &#x1f609" for akhr and LA11
HeavyTwo is offline
post #9 of 21 (permalink) Old 06-17-2019, 12:59 AM
Too Tall's Avatar
Maybe this chart will help your decision:
USMC 1968 - 1970. 2014 2500 4 x 4 3.42 maximum Steel
Too Tall is offline
post #10 of 21 (permalink) Old 06-17-2019, 01:36 AM Thread Starter
Someone stole my egr too
LA11 is offline
post #11 of 21 (permalink) Old 06-17-2019, 01:57 AM
Ltngdrvr's Avatar
Well, when you come on here and ask technical questions without providing details on your truck, you get answers that don't fit your situation.
Minnow101 and Lins like this.
post #12 of 21 (permalink) Old 06-17-2019, 02:03 AM
HeavyTwo's Avatar
Hate it when someone takes my emissions stuff..
So, LA11, I thought that "LA" was for LA in California. I was feeling bad that you have to live in California, but as you have no emissions... I suppose you live in one of the real American States.
Jumpinjoe, Jimmy N. and jdjonesiii like this.
HeavyTwo is offline
