Using 5W-40 Synthetic oil in Hot Weather - Dodge Cummins Diesel Forum
 31Likes
post #1 of 43 (permalink) Old 06-03-2019, 09:29 PM Thread Starter
After 6 months, I took my 2018 Ram 2500 diesel to the dealership for its first free oil/filter change. Per the manual, I requested 15W-40 for the hot Texas summer. I also requested full synthetic. When the oil/filter change was completed, the adviser commented that full synthetic was used. I clarified that it was 15W-40 synthetic. He replied that they “put 5W-40 in since a full synthetic 15W-40 isn’t available”. After I got home, a quick check on the internet proved him wrong.
My question to this group is: Will using the lighter weight in 100 degree temperatures damage my engine?
Thanks in advance,
John
Sent from my iPad using Tapatalk
Best Regards,
John H
Johnh75092 is offline
post #2 of 43 (permalink) Old 06-03-2019, 09:41 PM
easymon's Avatar
Perfectly fine running 5-40
Sent from my ONEPLUS A6013 using Tapatalk
06 dodge 3500 G56 ,EFI,BY Zach Fuller at starlite diesel,tunes by,anachy Les at silver bullet ,valair dd organic,fass 150
2013 Ram Laramie longhorn 342 none assin
easymon is offline
post #3 of 43 (permalink) Old 06-03-2019, 09:44 PM
In summer heat, they are both the same weight, 40. The 5W and 15W are winter weights, thus the W.
05PowerHouse, boshog and Jimmy N. like this.
Timberwolf2020 is offline
post #4 of 43 (permalink) Old 06-03-2019, 10:07 PM
15/40 t6 literally became available less than 10 days ago. Don’t expect the fca dealers to get it for at least 6 months. Fluids are never updated in parts catalogs as timely as one would expect. Sorry. However 5/40 is just the same in the above 0 degree environment.
jazdad2007 is offline
post #5 of 43 (permalink) Old 06-03-2019, 10:58 PM
BrianF's Avatar
The first number has no meaning for what you are asking. Look up the product data sheets for those oils. Look at the kv at 100 celcius. That number is what you want. It's the kinematic viscosity at 100c. That's what dictates if the oil is a 40 weight or not. Both 15w40 and 5w40 will have to fall in the same viscosity bracket in order to be a 40.
gsbrockman and Jimmy N. like this.
2017 Ram 3500 Megacab, SLT, True Blue, SRW, CTD, AS69RC. Ubique
BrianF is offline
post #6 of 43 (permalink) Old 06-04-2019, 09:23 AM
So the question should be:
Will a 5W oil be too light for the Hot Texas Winters?
2016 2500 4x4 Reg Cab SLT, Lux, Snow Chief, 2507# payload
brulaz is offline
post #7 of 43 (permalink) Old 06-04-2019, 09:53 AM
easymon's Avatar
The line is most newer diesels recommend 5-40 I've personally run 5-40 in my 13 with over 550,000 miles never used drop of oil till I traded. My 18 same 180,000 and yes I pull in heat of summer Texas, California pulling.
easymon is offline
post #8 of 43 (permalink) Old 06-04-2019, 09:55 AM
Walker111's Avatar
5w is for cold starts, 30* or 0*, the viscosity of the oil will be able to circulate thru the engine at low temps. The 40 says that the oil will hold up at higher temperatures (2??*).
To answer your question. 5w-40 will be fine in our engines all year round in ANY state in the US.
OlorinTharkun likes this.
16 CTD 2500 Bright White Crew Cab
Walker111 is online now
post #9 of 43 (permalink) Old 06-04-2019, 10:59 AM
ritchie1087's Avatar
i only use full synthetic 5w40 as well wouldnt sweat it
Cummins0867 and OlorinTharkun like this.
ritchie1087 is offline
post #10 of 43 (permalink) Old 06-04-2019, 07:29 PM
TexNeck's Avatar
Thats what I have run here in TX as well T6 5-40...I looked for 15-40 T6 forever since I ran 15-40 rotella in my 5.9. Like others have said you have to have EXTREME temps (hot or cold) to really justify needing it
2013 Ram 2500 QCLB 4x4 Leveled-35x12.50x20 ToyoAT2, MM3 Tuning, DRD, 4” Flo Pro Replacement Bumper, Amp Power Steps, AMP rear Step, Train Horns John 3:16 - Philippians 4:13 OFFROAD USE ONLY
TexNeck is offline
post #11 of 43 (permalink) Old 06-04-2019, 08:40 PM
Ltngdrvr's Avatar
You know, in the OWNER'S MANUAL, (y'all have heard of those, RIGHT???) it clearly states the temperature ranges for the various oil viscosity ratings.
Jimmy N. and Learjet like this.
CCV reset/seatbelt chime disable
Ltngdrvr is online now
post #12 of 43 (permalink) Old 06-04-2019, 10:30 PM
White Lightning
gsbrockman's Avatar
iTrader Score: 28 reviews
You mean like in this 2019 oil discussion thread here >> https://www.cumminsforum.com/forum/2...l#post28995191
-lenny- and Cummins0867 like this.
2018 RAM 4500 Chassis Tradesman Crew Cab 60” C/A 4WD, 6.7L Cummins, AISIN AS69RC Transmission, 4.10 Axle Ratio, Chrome Appearance Group, Keyless Entry, Fog Lamps, Chrome Tubular Steps, 52+22 gallon fuel tanks, 5.0 Radio, Single Disc CD Player, 225/70R19.5 Continental HDR’s, Aluminum Wheels, Parkview Backup Camera, Trailer Brake Controller. Equipped with a CM SK Series flatbed w/B&W Turnover Ball. Purchased new April 23, 2018. Currently : 140,423 miles and 2,468 hours as of June 6th, 2019 (Average Miles Per Hour = 56.9)
gsbrockman is offline
