Data pac - Dodge Cummins Diesel Forum
 1Likes
  • 1 Post By Jimmy07
post #1 of 9 (permalink) Old 05-23-2019, 07:56 PM Thread Starter
callen8365's Avatar
Data pac
I was hoping someone on here could tell me where the data pac is for a 2018 ram 3500. It’s a Laramie with a G56, I hope that does change something. The directions and online videos show it to the right of the steering column. I have watched multiple videos. It’s just not there on my truck. The videos show it wrapped in foam. I did find two other connections. One wrapped in foam but it was two green and two purple wires. Another wiring harness not wrapped in foam and the colors didn’t match what I need to tap into. Any help would be appreciated. I have traced the wiring as best as I could. Felt behind all the cavities with my hand and I’m not finding anything.
Thanks,
Chris
callen8365 is online now
post #2 of 9 (permalink) Old 05-23-2019, 08:47 PM
Ltngdrvr's Avatar
What the heck is a data pac???
CCV reset/seatbelt chime disable
Ltngdrvr is online now
post #3 of 9 (permalink) Old 05-23-2019, 08:49 PM Thread Starter
callen8365's Avatar
That’s what “they” called it. I’m looking for the wiring harness with the CanH and CanL in it.
post #4 of 9 (permalink) Old 05-23-2019, 08:52 PM
Ltngdrvr's Avatar
You're trying to connect to the CanBus?
What are you trying to hook up to it?
post #5 of 9 (permalink) Old 05-23-2019, 09:12 PM Thread Starter
callen8365's Avatar
A remote start
post #6 of 9 (permalink) Old 05-23-2019, 09:15 PM
Don_T's Avatar
He may be trying to install a security bypass which is required in ‘18+ HD Rams if you want to use AlfaOBD or I imagine something similar. On the ‘18s it is easy to find but my understanding it is much higher up under the dash in the same area on the ‘19s. I have not looked as I have no need for it. The ‘18s used a long green connector that has a bunch of two pin wire connectors attached. One side of the connector had all white connectors and the other side all green if I remember right. I don’t know if the connector changed for the ‘19s.
2019 Ram 3500 Crew Cab Long Bed
Don_T is offline
post #7 of 9 (permalink) Old 05-23-2019, 09:27 PM
Ltngdrvr's Avatar
Here's an article that talks about hacking the CAN-H and CAN-L on a jeep, may help.
post #8 of 9 (permalink) Old 05-23-2019, 11:46 PM
What you’re looking for is the 10 pin trailer brake controller module connector under the dash next to the steering column. If you have the trailer brake controller, it’ll be plugged into a little black module along with a 4 pin connector. If you don’t have the controller option, it’ll be wrapped in foam. You’re looking to tap into the orange wire and the yellow wire. The reason you’re tapping those wires out of the remote start t-harness and not using the pass through OBD connector is because of the security gateway module. The CAN H & L that you need to grab are in the trailer brake module, which is after the security gateway, and closest to the remote start t-harness.
7492 likes this.
Jimmy07 is online now
post #9 of 9 (permalink) Old 05-24-2019, 09:55 AM Thread Starter
callen8365's Avatar
You are the man! Thank you! I saw that, the first time I looked and I was going back and forth on it. But I just figured there was no way that was it!
Chris
Similar Threads
ported HE351 exhaust housing data GRUNT 11B 3rd Gen. Performance Parts Discussion 38 11-12-2016 11:47 PM
NSA - Disabling truck communications? TruckinFool 2013-2018 General Discussion 51 01-07-2014 10:57 PM
Cummins MPG Data After Deletes (not towing) NorCaler 4th Gen Performance Parts Discussion 22 11-30-2012 02:25 AM
