High Oil Pressure - Dodge Cummins Diesel Forum
 17Likes
post #1 of 54 (permalink) Old 05-23-2019, 11:14 AM Thread Starter
High Oil Pressure
What would you consider high oil pressure for these engines? When I was running conventional oil, and before I deleted, I would see 50 PSI, maybe 52 PSI momentarily. Now I routinely see 56-59 PSI. Should I be looking at something being wrong?
Thanks,
Chris
2013 3500 Mega Cab Laramie Longhorn - 6.7 - Aisin - 3.42 - Factory Hitch - B&W Companion - Air lift 5000 - Grand Design Solitude 369RL
chris t is offline
post #2 of 54 (permalink) Old 05-23-2019, 12:39 PM
N of 60's Avatar
Thanks,
Chris
Use a mechanical gunge if your interested in #s. Your EVIC is only a algorithm. If your lights not on. Its above 5psi.
RayK and Lins like this.
2011,4wd LB/CC 2500 H&S Mini MCC by Tomeygun, BD protect 68rfe VB seperator plate enhanced stall triple disk TC, Super B 64.5/80/.91 3rd gen mani & inline EB, Arp 425s, Fass Titanium 95. Spare Mini in my closet.
High tech old school and finally lovin it.
N of 60 is offline
post #3 of 54 (permalink) Old 05-23-2019, 01:49 PM
Ltngdrvr's Avatar
You have nothing to worry about.
CCV reset/seatbelt chime disable
Ltngdrvr is offline
post #4 of 54 (permalink) Old 05-23-2019, 01:59 PM
tsconver's Avatar
Added a mechanical one to mine. At hot idle it is right 20psi. At cruise 50 to 60psi. Cold it gets close to 100psi.
It was an easy addon to my edge insight.
Zaicran likes this.
73 K4CTD
2018 2500 QC SB Laramie - stock for now
2005 2500 QC SB, Rebuilt at 330K miles, Sold
tsconver is offline
The Following User Says Thank You to tsconver For This Useful Post:
N of 60 (05-24-2019)
post #5 of 54 (permalink) Old 05-23-2019, 03:54 PM
Did you compare it to the EVIC, I am curious how far off it is.
tankerpilot01 likes this.
2015 2500 4x4 megacab automatic with ARE Z series topper
cjgoode is offline
post #6 of 54 (permalink) Old 05-23-2019, 11:48 PM
I just have a hard time believing this is true (algorithm vs. a simple pressure sender). I understand this is the prevailing logic around here because, what, there is no part number for an oil pressure sender? Has anyone confirmed this to be the case with Cummins?
cjgoode likes this.
2017 Tradesman 3500 4x4 srw ccsb 68rfe
jbawden is offline
post #7 of 54 (permalink) Old 05-24-2019, 12:25 AM
N of 60's Avatar
Donít need to....
Hard way.....
Take yours out, apply air pressure to the switch and use an OHM meter. Slowly apply air pressure. See the change at about 5-7 PSI. Itís an open or closed circuit thatís it. No gradual resistance change.
To keep it really simple. Start your engine and unplug yours. Tell me what your pressure is. Tell me if you get a red light on your dash at the same time.
Donít shoot the messenger.
dillonjm and Jimmy N. like this.
N of 60 is offline
post #8 of 54 (permalink) Old 05-24-2019, 01:00 AM
dillonjm's Avatar
iTrader Score: 5 reviews
This isnít new. Most gauges on cars or trucks anymore are ďdummyĒ gauges.
16 3500 SRW RCLB G56 4x4- Thuren/Carli/Fox - 285 75/18 Cooper AT3s; FTE / Aero Turbine / ARP / Anarchy / Valair / Pusher / GDP
11 SRT8 Challenger M6 - Corsa; 295 Nittos
dillonjm is offline
post #9 of 54 (permalink) Old 05-24-2019, 01:13 AM
N of 60's Avatar
Don’t need to....
Hard way.....
Take yours out, apply air pressure to the switch and use an OHM meter. Slowly apply air pressure. See the change at about 5-7 PSI. It’s an open or closed circuit that’s it. No gradual resistance change.
Don’t shoot the messenger.
I forgot one thing. When you unplug the pressure SWITCH, jumper the plug once you check your dash instruments 1st. The circuit needs to be closed to think it’s getting minimum oil pressure. Take it for a drive and watch the magic.
dillonjm, Lins and Jimmy N. like this.
N of 60 is offline
post #10 of 54 (permalink) Old 05-24-2019, 07:52 AM
I forgot one thing. When you unplug the pressure SWITCH, jumper the plug once you check your dash instruments 1st. The circuit needs to be closed to think itís getting minimum oil pressure. Take it for a drive and watch the magic.
Suppose heíd believe you if you said the sun came up today?
N of 60 likes this.
Jhenderson is offline
post #11 of 54 (permalink) Old 05-24-2019, 09:04 AM
tsconver's Avatar
The dash gauge is always around 40 to 60 psi. Never shows the high pressure at cold start up or the lower pressure at hot idle. The dash gauge is just an idiot gauge.
73 K4CTD
tsconver is offline
post #12 of 54 (permalink) Old 05-24-2019, 12:26 PM
Buyer of stuff..with OPM
Ram4Sam's Avatar
My 2001 2nd gen truck had the same idiot gauge, just as todays trucks...........
Sam
Lins likes this.
2016 3500 Laramie SRW 4x4 CC LB ,Aisin,white w/brn-beige,B&W TOB/companion built 9/2015
Owned and gone, 1991 d250
... 2001.5 2500qc
...2014 3500 FCA buyback
Drivin' a Dodge Cummins since 1991.......
2008 Thor jazz 2870UK 5er....and 4 dogs.....
Ram4Sam is offline
Similar Threads
2005 Dodge Ram 2500 48RE Madmike13 3rd Gen. Powertrain 4 07-26-2017 11:46 AM
48re won't shift derrickm102 3rd Gen. Powertrain 6 02-08-2016 11:37 AM
Loss of power what's wrong westtxdiver 911 Urgent Situations 5 03-01-2014 05:46 PM
Trany trouble lfr101 3rd Gen. Powertrain 11 11-24-2011 11:20 PM
Engine light and turbo problem smokeater413 07.5 - 09 3rd Gen 6.7L Powertrain 29 08-18-2011 08:07 PM
