3500 dually rear air suspension? - Dodge Cummins Diesel Forum
 2Likes
  • 1 Post By groove76
  • 1 Post By Jimmy N.
post #1 of 11 (permalink) Old 05-19-2019, 01:45 AM Thread Starter
kingdaddy's Avatar
Question 3500 dually rear air suspension?
So I'm strongly considering a 2015 or 16 MegaCab 3500 dually with the H.O. engine/Aisin trans. and found one with the rear "air suspension".
I would love to hear any feedback from those who have actual experience with this setup. Not sure if it's a good choice or just the standard suspension and add my own bags (Airlift 7500XL) later? Thoughts?
'06 2500 4x4 Mega Cab Laramie Goerend, Carli, Banks and other stuff...FOR SALE!
"NEW" TRUCK- '15 Laramie DRW MegaCab, Aisin, Rear auto level, stock for now!
kingdaddy is offline
post #2 of 11 (permalink) Old 05-19-2019, 02:05 AM
I have a 2018 3500 with the air suspension, for 5 months now, and quite honestly, I don't know.
The "alt trailer height" switch doesn't really do much unless the trailer is VERY heavy (10,000 lbs or higher), and even then when "Alt Trailer height" is engaged, the truck doesn't drop more than an inch or two.
If you want air suspension for leveling and stability, it helps greatly. If you want it so you can lower the truck to get stuff out of the bed easily, it wont.
I just wish the air suspension accompanied slightly weaker springs, so the truck could dip a bit more when engaging it. I'd like ease of loading into the bed, too.
Ram 3500 Laramie 6.7 Cummins Dually 3.72
JSMITH8505 is offline
post #3 of 11 (permalink) Old 05-19-2019, 11:32 AM
Smithers1945's Avatar
I also have an 18 3500 with it. I haven’t had the chance to haul a heavy enough load for the system to turn on. I will say though, I drove one with the air ride and one without. The one with rear air felt like it drove a bit smoother and absorbed bumps on the road better.
However, my truck has less than 5k miles and the ‘Service Air Suspension Immediately’ light has come on several times already. Dealer said there’s nothing wrong, and the light has since come on again. I’m a bit annoyed.
Smithers1945 is offline
post #4 of 11 (permalink) Old 05-19-2019, 12:45 PM
I have a 17 3500 with factory air. Love it. Keeps truck at the same height with trailer attached or bed loaded. super stable when towing and headlights always aimed correctly.
Can lower a couple of inches (transport mode) to drive the quad in - helps for sure. I would order it again hands down
kevinc2004 likes this.
2017 CCSB 3500 Longhorn, Aisin and Air Ride
groove76 is offline
post #5 of 11 (permalink) Old 05-19-2019, 03:14 PM
I have it on my 2015 DRW. Rides better empty and keeps truck level when loaded. I tow a 16K+ fifth wheel with 4,000 on the pin. The truck is loaded within 800-1000 lbs of 14k max.
2015 Laramie Limited 3500 CC LB DRW 4X4 RAS Aisin 3.73
Sold: 2008 Laramie 3500 Mega Cab deleted
YYC Mike is offline
post #6 of 11 (permalink) Old 05-19-2019, 06:18 PM
robertyoke's Avatar
I like mine, keeps the truck at the same height no matter what trailer I have hooked up to it.
Not sure bout the 10000 lbs trailer comment posted above, couple hundred lbs of pin weight from an empty gooseneck will allow the alt height setting.
'18 mega drw titanium limited, '10 laramie mega 4x4 3500 auto srw ‘sold’
Past '04 ram 3500 4x4 drw qc nv5600 'sold', '03 ram 3500 4x4 srw qc short bed twin turbo'd hot rod 'sold', '98 ram 3500 4x4 drw qc nv4500 'sold'
robertyoke is offline
post #7 of 11 (permalink) Old 05-19-2019, 06:38 PM
Jimmy N.'s Avatar
And if it had weaker springs, how would you counteract the resulting spring wrap?
I know, it's not rocket science to build a set of bars, or even a 4-link, but still.
Just about to order the second 3500 with the factory air, by the way.
Busted likes this.
'14 1500 V6, '17 3500 C&C, plus a '17 2500 in the household.
Jimmy N. is online now
post #8 of 11 (permalink) Old 05-19-2019, 06:43 PM
organized_mayhem's Avatar
2016 with rear air suspension. Works great to keep load leveled. Alt trailer height will only drop about an inch or so as others have stated. No issues so far.
2016 3500 Laramie DRW Mega Cab 4X4 G56 3.73/ EZlynk CTT
organized_mayhem is offline
post #9 of 11 (permalink) Old 05-19-2019, 07:15 PM
kevinc2004's Avatar
Love the leveling of my air suspension when I hook up my 5er. Air compressor comes on and truck goes right to level!
2017 Laramie Longhorn, 3500 CCLB, DRW, AS69RC, 4.10 geared, Air Suspension. 2015 Dynamax Triology 38RL
kevinc2004 is offline
post #10 of 11 (permalink) Old 05-19-2019, 09:54 PM Thread Starter
kingdaddy's Avatar
Hey, I'm looking at a '15 dually with Aisin and 3.73 gears. Are you happy you got the 4.10s or would you have preferred the 3.73s? I have 4.10s in my current truck but the 48re doesn't have the low gearing of the Aisin...OR the higher gearing OD either.
post #11 of 11 (permalink) Old 05-19-2019, 09:58 PM
Jimmy N.'s Avatar
My '17 with the Aisin and 3.73s turn about 2,000 rpm at 80. With 4.10s that'd be about 2,200 rpm.
Similar Threads
3500 Mega cab, softening up the rear end suspension. Riperoo 2010-2012 General Discussion 11 04-09-2019 04:37 PM
Your new 2019 HD RAM dirtRoads 2013-2018 General Discussion 341 01-31-2019 12:51 PM
2001 3500 Dually rear wheels inserts BTMaltby 2nd Gen Tire and Wheel 5 08-06-2015 05:20 PM
99 3500 4x4 Rear suspension Richykayak 98.5-02 Non-Powertrain 0 09-27-2014 10:25 AM
ram not offering rear air suspension on 3500 45 truckie 2013-2018 General Discussion 172 06-13-2014 07:34 PM
