Assistant needed - Dodge Cummins Diesel Forum
 3Likes
post #1 of 15 (permalink) Old 04-24-2019, 07:07 PM Thread Starter
amko22's Avatar
Assistant needed
Need some help, currently in California and broke down. It is what I am assuming to be electrical. I have a 2017 3500 mega cab drw 4x4, deleted with efi live. I was driving down the road and my traction control light started flashing as I pulled into the truckstop that I am at more and more light started flashing not exactly sure what it is just replace the alternator three weeks ago.
Unfortunately I canít upload a video but the tack was bouncing from idle to zero I was getting messages that the engine was hot load oil pressure and again the traction control light was flashing on and off
Any suggestions would be appreciated
05 crewcab> Short Bed> Built Auto> SRW> K&N intake> 5in turbo back> Silencer ring MIA> 8000K headlights> 6000K Fog Lights> Smarty SO-6> Fass> 60hp nozzles> More to come!
amko22 is offline
post #2 of 15 (permalink) Old 04-24-2019, 07:26 PM
Walker111's Avatar
Any check engine light? Will your efi live clear body modules?
16 CTD 2500 Bright White Crew Cab
Walker111 is online now
post #3 of 15 (permalink) Old 04-24-2019, 08:05 PM Thread Starter
amko22's Avatar
amko22 is offline
post #4 of 15 (permalink) Old 04-24-2019, 08:12 PM
Hereís a handy listing of codes:
https://www.thoroughbreddiesel.com/d...trouble-codes/
UpThecreek is offline
post #5 of 15 (permalink) Old 04-24-2019, 08:22 PM
boshog's Avatar
Check your battery voltage. Sounds like a possibility your voltage went low and could be your alternator isn't charging. That's all I got.
2015 3500 LongHorn CC, 4x4, SRW, CDT, 68RFE
2013 1500 Laramie CC, 4x4, 8 speed
boshog is offline
post #6 of 15 (permalink) Old 04-24-2019, 08:22 PM
Canít help you but thought itíd be handy to have your codes deciphered in one place. Good luck!
U0001 CAN C BUS
P0513 INVALID SKIM/WIN KEY
P0868 LINE PRESSURE LOW
U0121 LOST COMMUNICATION WITH ANTI-LOCK BRAKE MODULE
U1449 IMPLAUSIBLE ERS MESSAGE RECEIVED
post #7 of 15 (permalink) Old 04-24-2019, 08:25 PM
The first place Iíd look are the 3 plugs behind the drivers side inner fender liner. The wires are susceptible to damage, corrosion, or both. Look closely from the back of the plug to the area where they enter the loom. Nicks, cuts, or even a loose connector. I had the low line pressure code put my truck in limp mode. The light blue wire at PIN number one on the large connector had a nick in the cover. That allowed corrosion which demanded a splice to correct.
Jhenderson is online now
post #8 of 15 (permalink) Old 04-24-2019, 09:03 PM Thread Starter
amko22's Avatar
Thanks for the all the input turned out to be a bad battery. It was my error, I replace the alternator one of the batteries was Really week when I changed out the alternator and I didnít charge it. So the battery at a dead cell in it and just completely died this time. All of the fault codes minus the Lowline pressure was due to the failing battery.
warboar likes this.
amko22 is offline
post #9 of 15 (permalink) Old 04-24-2019, 09:04 PM
Great news! On the road again........
amko22 likes this.
post #10 of 15 (permalink) Old 04-24-2019, 09:05 PM Thread Starter
amko22's Avatar
I will definitely check this out thanks
amko22 is offline
post #11 of 15 (permalink) Old 04-25-2019, 11:49 AM
Lins's Avatar
Glad you got it figured out. Always a good idea to check what was last touched as well (alternator), even if it doesn't seem related.
Jimmy N. likes this.
Lins is offline
post #12 of 15 (permalink) Old 04-25-2019, 12:14 PM
There seems to be a serious design flaw that a bad battery causes it to throw incorrect and irrelevant codes. Awesome all it was was a battery.
2015 2500 4x4 megacab automatic with ARE Z series topper
cjgoode is offline
Similar Threads
47RE transmission troubleshooting chart. country_hick 94-98 Powertrain 0 02-25-2013 12:30 PM
Exaust Service needed? mastershooter1 4th Gen Powertrain 5 10-26-2012 02:04 PM
what is needed to start browe318 98.5-02 Powertrain 2 09-23-2012 03:43 PM
Tools Needed for '08 Steering Upgrade? Browndog 07.5 - 09 3rd Gen 6.7 Liter General Discussion 2 05-26-2012 07:03 PM
Service needed contact dealer hububub46 07.5 - 09 3rd Gen 6.7L Powertrain 1 05-12-2012 06:05 PM
