tranny or rear end - Dodge Cummins Diesel Forum
 6Likes
post #1 of 25 (permalink) Old 04-22-2019, 09:57 PM Thread Starter
Brummo's Avatar
tranny or rear end
Something I've noticed the last couple times I've towed. First was a two place trailer with two sleds from Wyoming. Pulled off to fuel up and turning left it felt like the rear was completely locked like it had posi. Or, is their something with the tranny torque converter locked?. Was pulling my boat this last weekend and felt the same a couple times. Can't really pinpoint the issue. Obviously will be taking to dealer, but am wondering if anyone else has felt anything similar.
'18 2500 13000 miles 68RFE anti spin rear.
2018 2500 CC Laramie 6.7L Cummins
Brummo is offline
post #2 of 25 (permalink) Old 04-22-2019, 10:35 PM
I don't know about the Ram diff but I had a 97 Chevy 1500 4x4 that had some casting slag loose in the gear oil that would lock the rear wheels. I would have to back up to get the gears freed up and then it would run normal. This didn't show up until the truck had 90,000+ miles on the clock. Drained the rear diff and cleaned the loose slag out and put new gear oil in it and I was good to go.
Den52 is offline
post #3 of 25 (permalink) Old 04-22-2019, 10:40 PM Thread Starter
Brummo's Avatar
Don't notice it when not towing..
Brummo is offline
post #4 of 25 (permalink) Old 04-23-2019, 09:52 AM
Jared Herzog's Avatar
Change your diff fluid. Mine did the same thing and was no longer tolerable at 8811 miles. It happened only while turning and the hotter the fluid got the worse the chatter got. I used Amsoil and Valvoline and mixed them for a thicker oil. Both were GL5. The chatter has not come back in 30,000 more miles. I just changed the second batch of oil out and will do so every 30,000 miles. The second batch had about 20,000 miles on it and looked new. I have never added any extra friction modifier. Photos:
Don’t have a dealer dump the same oil that already failed you in the truck. Change it yourself using a better oil.
Ram 14 2500 RIP 14,700 Stock. 68RFE."The Lemon"
Ram 15 3500 Dually. Stock. Aisin. N Fab wheel to wheel. Weather Tech Mats. Big D Steering Box Brace.
Jared Herzog is offline
post #5 of 25 (permalink) Old 04-23-2019, 10:54 AM
Ltngdrvr's Avatar
I used to get something similar on mine, but when not towing, but hot. Would grind and feel tight when backing up and turning. It was the tightness in the gear type limited slip diff. I cured mine by a fluid change with the addition of a tube of friction modifier intended for clutch type diffs. The gear type isn't supposed to need it, bit it cured the issue. I now used Mobil 1 synthetic 75w90 that has the friction modifier in it so I don't add the extra tube of it anymore.
OEM recommended diff fluid is 75w85, which is hard to find other than at the dealer and is also quite a bit more expensive than the 75w90. Since my first diff fluid change, I've always used the 75w90 with zero issues.
CCV reset/seatbelt chime disable
Ltngdrvr is online now
The Following User Says Thank You to Ltngdrvr For This Useful Post:
LOOSEWHEEL (04-23-2019)
post #6 of 25 (permalink) Old 04-23-2019, 09:26 PM Thread Starter
Brummo's Avatar
Getting it looked at next week along with the recall. They said they all shudder, but they'll look at it. going to ride with a tech when I drop it off. I did feel it in reverse when I backed into the parking stall..
We'll see....
Brummo is offline
post #7 of 25 (permalink) Old 04-24-2019, 11:06 AM
Lins's Avatar
We'll see....
No wonder people don't like dealerships with comments like that. As @Ltngdrvr mentioned, the rear end can benefit from friction modifier, just add a few ounces yourself if the dealer does nothing about it. Many people on here have mentioned that. My guess is at best they'll change the fluid for you and say they test drove it and can't duplicate it.
Lins is online now
post #8 of 25 (permalink) Old 04-24-2019, 08:56 PM Thread Starter
Brummo's Avatar
What do you recommend for a friction modifier?
Brummo is offline
post #9 of 25 (permalink) Old 04-24-2019, 11:04 PM
Ltngdrvr's Avatar
It's all the same stuff, just get whatever brand your local store has.
I used this before switching to the gear lube with the friction modifier already in it.
https://www.autozone.com/greases-and...tive/17352_0_0
It's easy to use the K&W tube, just cut the end off the nipple and squeeze it in the filler hole.
post #10 of 25 (permalink) Old 05-01-2019, 07:51 PM Thread Starter
Brummo's Avatar
Of course you take it in and go for a test ride...won't do it.. but did it every turn getting there. Ugh.
We'll see..
Brummo is offline
post #11 of 25 (permalink) Old 05-01-2019, 08:36 PM
Ltngdrvr's Avatar
We'll see..
Just change the gear lube yourself, not hard to do. Either use the gear lube with the friction modifier already in it or add a tube to the standard synthetic lube.
Rear cover gasket is reusable, so you only need to buy the lube.
You will also need a external torx socket for the cover bolts.
Jimmy N. likes this.
post #12 of 25 (permalink) Old 05-01-2019, 09:14 PM
7492's Avatar
I will bet the sales representative for a particular brand of additive would not agree with that. His is certainly better than the others.
17 3500 Laramie CCLB loaded, minus the stupid stuff.
2011 Durango Hemi Loaded
09 Freightliner M2 33k GVW ISC 360/1050 RFO9210
7492 is offline
Similar Threads
Some Questions About Rear Axle (Dana 80) turbocruiser 94-98 Powertrain 6 04-17-2019 08:05 AM
Tranny cooler t-stat bad??? Infrared readings... swa240z 3rd Gen. Powertrain 5 08-04-2012 09:44 PM
Injector Maintenance scotchwhiskey 3rd Gen. Powertrain 86 06-22-2012 09:26 PM
fixing to install new tranny, should I install new rear main seal? cummins04.5handshaker 98.5-02 Powertrain 14 05-08-2012 12:44 PM
