DEF tank - Dodge Cummins Diesel Forum
 5Likes
  • 2 Post By mtnrider
  • 1 Post By FlaCracker
  • 1 Post By Redheadhunter21
  • 1 Post By cjgoode
post #1 of 10 (permalink) Old 04-15-2019, 01:43 PM Thread Starter
DEF tank
I bought my 2017 2500 in late January (14k original miles) driving it up from North Carolina to NY. It started with a full DEF tank per the gauge. At 15,200 I was at 1/2 full and bought some WalMart DEF and dumped the whole 2 1/2 gal. in (gauge showed full,100%). I have since put another 800 miles on her but the gauge hasn't budged..Is this normal? Mostly short city driving...I'm a bit nervous as I have a long distance trip planned with my daughter and don't need any probs along the way that could be avoided..
Thanks for any input...
2017 RAM 2500 CC 4x4 Laramie UnderCover hard tonneau, gooseneck pkg, offroad pkg,Supernova V4 LED low beams and fog lights,rear mount Trek step, CalTrend seat covers....
LI Guy is offline
post #2 of 10 (permalink) Old 04-15-2019, 01:45 PM
Normal. The gauge is far from linear.
Matt6785 and LI Guy like this.
2016 Ram 2500 Big Horn Mega cab, 285/75-18 (35's) Nitto Ridge Grapplers. Fuel Hostage III 18x9 +18 BS Wheels. Bilstein 2.3″ Front Lift, 1" rear spacer.
mtnrider is offline
post #3 of 10 (permalink) Old 04-15-2019, 01:58 PM
Really depends on type of driving, i.e., hauling and towing, highway versus city. Mine uses the most when towing or hauling loads. I drove 600 miles this past weekend, towing a 98 Dodge Ram pickup on a 20' trailer,went from close to full to a quarter in 900 miles, 2.5 gals of DEF filled it back up. When daily driver back and forth to work, probably go 2k miles before hit drops quarter of a tank.
Your experience sounds normal. If concerned, just take a 2.5 gal jug with you, for peace of mind.
LI Guy likes this.
2014 Ram 3500 Tradesman Dually (2x4), 68RFE, 3.73 rear, Jamo 5' turbo-back stainless steel exhaust, Diamond Eye 51" muffler, EZLink tuner/CTT tunes.
2016 Ram 1500 Big Horn (2x4), 5.7 Hemi, 3.92 rear.
FlaCracker is offline
post #4 of 10 (permalink) Old 04-15-2019, 02:08 PM
Normal gauge reads full long before the tank is truly full. Part of that is because def will freeze up north and they leave some room for it. I usually let mine go to the red and then fill up then puts it right around full even then.
LI Guy likes this.
2018 Ram 2500 6.7L, Thuren Suspension, 37x13.5r20 Milestar M/T, MB Wheels 352 20x9, Timbren, Amp Research Powersteps, Weather Tech mats, E-Max Tonneau Cover, Line-X, Andersen Rapid hitch
Redheadhunter21 is offline
post #5 of 10 (permalink) Old 04-15-2019, 02:20 PM
Ltngdrvr's Avatar
There is almost two gallons of tank capacity above where the gauge reads 100%, so running light, you can go a very long way before the needle will start to drop.
But, why would you be nervous of a long trip due to DEF usage?
DEF is available in thousands of locations throughout the country, at just about any walmart, auto parts store, and at almost all truck stops either in jugs or at the fuel island bulk pumps. Absolutely no need to be nervous about finding DEF, no matter where you are, or where you're going.
CCV reset/seatbelt chime disable
Ltngdrvr is online now
The Following User Says Thank You to Ltngdrvr For This Useful Post:
FlaCracker (04-15-2019)
post #6 of 10 (permalink) Old 04-15-2019, 02:27 PM
The tank will hold about 2+ gallons above the full mark on the gauge. I wait till mine get into the red and then out in a 2.5 gallon jug and that takes it back to 100%. I am sure that is a little over 100% as it takes a while to start dropping. I use to fill the tank and it would take a long time to start goind down, then through a code, I assume because the DEF was in the tank too long in the extreme heat hear. So now I never add too much def so it turns over a little more often.
LI Guy likes this.
2015 2500 4x4 megacab automatic with ARE Z series topper
cjgoode is offline
The Following User Says Thank You to cjgoode For This Useful Post:
post #7 of 10 (permalink) Old 04-15-2019, 02:30 PM Thread Starter
It was more for the correct amount of usage. Wasn't sure if there was a possible clog in the system or some such thing..First diesel ,so just being over cautious especially going away from home with it. Thanks for your reply...
LI Guy is offline
post #8 of 10 (permalink) Old 04-15-2019, 02:46 PM
Lins's Avatar
If there's something wrong, the truck will let you know. Don't worry about it.
Lins is online now
post #9 of 10 (permalink) Old 04-15-2019, 02:58 PM
I just went over 2,000 miles before the gauge came off the full mark.
please watch this video https://youtu.be/czJZuc8ThhI
2017 Ram Big Horn, DRW long box, 4x4, Cummins, Aisin, 3.73
B&W Ram Companion
2015 Wildcat 317RL, 12,000 lbs
Learjet is offline
The Following User Says Thank You to Learjet For This Useful Post:
post #10 of 10 (permalink) Old 04-15-2019, 03:55 PM
I only refill with the small jugs if I'm not taking a trip. The heat here can kill the DEF in the summers easy.
Handshaking is offline
Similar Threads
Aftermarket Tank Affect Fuel Sender? - 96 Standard Tank Dimensions TX_Diver 94-98 Non-Powertrain 6 04-07-2017 08:46 PM
At my wits end. 08 6.7 acting like it has 1/4 tank Fass issue... but it NOT. THE STIG 07.5 - 09 3rd Gen 6.7L Powertrain 15 05-24-2016 12:13 AM
Fuel Pressure issues with less than 1/4 tank? Coloradokevin 98.5-02 Powertrain 11 01-16-2013 01:18 PM
Need Opinions - Aux/Transfer Tank Vs No Aux/Transfer Tank cory1337 2010-2012 General Discussion 9 06-07-2012 04:34 PM
Auxiliary fuel tank 03/5.9/CTD 3rd Gen. Non-Powertrain 5 07-06-2011 04:19 PM
