Transmission issues 68rfe - Dodge Cummins Diesel Forum
 1Likes
  • 1 Post By N of 60
post #1 of 11 (permalink) Old 04-15-2019, 01:18 PM Thread Starter
I’ve recently blown up my 3rd bd transmission and I’m starting to look for other options. My truck is deleted and tuned running 38s with 4.30 gears and I only run my 50 hp tune. My first 2 bd trans broke the overdrive shaft and my third one still hasent been diagnosed but I’m thinking I broke my input shaft or the converter went out. The last 2 transmissions only had 4400 miles on both combined. I don’t know if I’m having tcm issues or wiring issues? Any suggestions. Also what brand would you guys recommend? I’m stuck in between Randy’s and a suncoast. Suck the truck only has 55000 miles on it. I’m to the point of just selling it which sucks. Hopefully you guys have some answers
2016 Ram Laramie Megacab 3500 srw, 7" fabtech, 37x12.5x20 toyo r/t's and fuel kranks, 30" totron light bar, deleted w/ efilive and hardway tunes, 5" TBE no muffler, amp steps, bd throttle sensitivity booster, hellwig bags, pocket flares painted to match
craigb44 is offline
post #2 of 11 (permalink) Old 04-15-2019, 01:27 PM
ritchie1087's Avatar
ive heard alot of these just dont last thats why i stay clear of bd products i havnt found anything they make is quality
ritchie1087 is offline
post #3 of 11 (permalink) Old 04-15-2019, 03:30 PM
tsconver's Avatar
I would look at or call the tuner. If you are breaking shafts with just 50 hp I would wonder if the tuner turned off or removed a lot of the TQ management. The trans will not survive 0HP increase if the torque management is removed.
73 K4CTD
2018 2500 QC SB Laramie - stock for now
2005 2500 QC SB, Rebuilt at 330K miles, Sold
tsconver is offline
post #4 of 11 (permalink) Old 04-15-2019, 03:52 PM
nick00less's Avatar
What are you doing to your truck at the EXACT MOMENT your transmissions fail?
Are you in the middle of a burnout? Boosted launch? WOT run?
Or are you merely cruising down the highway and BOOM your transmission goes kuh-put?
'14 6.7 S465 tuned by CTT
'17 6.7 tuned by CTT
'18 6.7 S467.7 tuned by CTT
nick00less is offline
post #5 of 11 (permalink) Old 04-15-2019, 03:57 PM
N of 60's Avatar
I find that completely opposite.
brownbear likes this.
2011,4wd LB/CC 2500 H&S Mini MCC by Tomeygun, BD protect 68rfe VB seperator plate enhanced stall triple disk TC, Super B 64.5/80/.91 3rd gen mani & inline EB, Arp 425s, Fass Titanium 95. Spare Mini in my closet.
High tech old school and finally lovin it.
N of 60 is offline
post #6 of 11 (permalink) Old 04-15-2019, 04:02 PM
N of 60's Avatar
Originally Posted by craigb44 View Post
Iíve recently blown up my 3rd bd transmission and Iím starting to look for other options. My truck is deleted and tuned running 38s with 4.30 gears and I only run my 50 hp tune. My first 2 bd trans broke the overdrive shaft and my third one still hasent been diagnosed but Iím thinking I broke my input shaft or the converter went out. The last 2 transmissions only had 4400 miles on both combined. I donít know if Iím having tcm issues or wiring issues? Any suggestions. Also what brand would you guys recommend? Iím stuck in between Randyís and a suncoast. Suck the truck only has 55000 miles on it. Iím to the point of just selling it which sucks. Hopefully you guys have some answers
How are you controlling LP. Boost reference box or EFI? What TC did you do? Enhanced or low stall? Billet input?
N of 60 is offline
post #7 of 11 (permalink) Old 04-15-2019, 06:26 PM
El Pozzinator's Avatar
Looking thru Randyís build list looks like they use a good bit of suncoast parts mixed with a few sonnax pieces so probably about samey-samey between the two. If those are the options youíre considering Iíd suggest checking into the authorized installers in your area, seeing what their reviews are like, and calling the builders to discuss your history, habits, and goals, and see who gives you the best warm-n-fuzzy before plunking down that much scratch.
Side note: Iím with the above comments that if youíre grenading transmissions with such regularity thereís something off with your tuning, or your driving style needs adjusting a bit for a built trans.
08 Resistol. Anarchy EFI, 5" TBE, Sinister coolant filter, Carbonite DP sensor, CSS -4" springs, reverse level, CalTracs, Amsoil bypass filter, Revmax VB/TCM, & a madly leaking radiator.
El Pozzinator is offline
post #8 of 11 (permalink) Old 04-15-2019, 11:07 PM Thread Starter
The first bd trans I was passing
Someone. Second one I was
Going 65 towing my travel trailer not hot
Roddin at all. The 3rd I was leaving a stop sign light throttle and it started doing some funky downshifting
craigb44 is offline
post #9 of 11 (permalink) Old 04-15-2019, 11:11 PM Thread Starter
First and second trans I had stock tuning with bd pressure box.3rd trans I have hardway trans tune built Specific to bd’s trans( 250 lp) I’m using bd’s converter geared towards towing with a billet shaft
craigb44 is offline
post #10 of 11 (permalink) Old 04-15-2019, 11:36 PM
38s, that's a big tire, but nothing huge. Is this the same transmission rebuilt over and over or new trans each time?
Handshaking is offline
post #11 of 11 (permalink) Old 04-16-2019, 07:22 AM Thread Starter
New unit every time. I thought 38s with stock gearing is why I broke the first one. Regeared it and broke 2 transmissions even faster
craigb44 is offline
Similar Threads
68rfe reliability issues SteveB9000 4th Gen Powertrain 33 05-29-2017 12:52 PM
68rfe DIY Transmission oil change procedure...??? rcan 07.5 - 09 3rd Gen 6.7L Powertrain 9 09-05-2012 02:45 PM
Another Transmission issue ThatOneGuy469 3rd Gen. Powertrain 15 08-03-2012 04:54 PM
Help With Codes, Please! 0743 and 1765 Tommy R 98.5-02 Powertrain 5 05-17-2012 10:32 AM
