Fuel heater location - Dodge Cummins Diesel Forum
 1Likes
post #1 of 14 (permalink) Old 04-14-2019, 06:45 PM Thread Starter
andrew1346's Avatar
I’m was wanting to know where the fuel heater was located, I was going to do a fuel filter delete because I added a cat filter in the back.. but if the heater is in the front filter I will leave it in place... I am currently having problems with it surging at idle when it’s cold as well
99 qcsb, black sport 2001-2010, totaled, RIP friend. 01 qcsb burnt orange 2010-2013, Sold. 2014 Bighorn Megacab, BlueStreak, ordered 1/13, picked up 3/17, Love it!
andrew1346 is offline
post #2 of 14 (permalink) Old 04-14-2019, 07:03 PM
Ltngdrvr's Avatar
IIRC, it's in the water separator/filter housing.
CCV reset/seatbelt chime disable
Ltngdrvr is offline
post #3 of 14 (permalink) Old 04-14-2019, 07:42 PM Thread Starter
andrew1346's Avatar
Surging at idle
When the trucks cold, it likes to surge at idle, if it idles for 5-10 minutes it seems to be fine, or if I just drive it’s fine. Always fine if it’s warm.. first noticed it when we were on vacation and at higher elevations it was doing the same thing in the morning, with fairly new fuel filters
post #4 of 14 (permalink) Old 04-14-2019, 08:05 PM
White Lightning
gsbrockman's Avatar
iTrader Score: 28 reviews
Originally Posted by andrew1346 View Post
When the trucks cold, it likes to surge at idle, if it idles for 5-10 minutes it seems to be fine, or if I just drive itís fine. Always fine if itís warm.. first noticed it when we were on vacation and at higher elevations it was doing the same thing in the morning, with fairly new fuel filters
If the truck is the 2014 in your signature.....have you verified that the rear separator heater was actually enabled on your truck? All 2013ís and an early portion of 2014ís were NOT enabled due to an error in programming.
https://www.cumminsforum.com/forum/2...operation.html
A multimeter and a few minutes of your time is all it takes to verify.
URDiesel likes this.
2018 RAM 4500 Chassis Tradesman Crew Cab 60Ē C/A 4WD, 6.7L Cummins, AISIN AS69RC Transmission, 4.10 Axle Ratio, Chrome Appearance Group, Keyless Entry, Fog Lamps, Chrome Tubular Steps, 52+22 gallon fuel tanks, 5.0 Radio, Single Disc CD Player, 225/70R19.5 Continental HDRís, Aluminum Wheels, Parkview Backup Camera, Trailer Brake Controller. Equipped with a CM SK Series flatbed w/B&W Turnover Ball. Purchased new April 23, 2018. Currently : 140,423 miles and 2,468 hours as of June 6th, 2019 (Average Miles Per Hour = 56.9)
gsbrockman is offline
post #5 of 14 (permalink) Old 04-14-2019, 09:47 PM Thread Starter
andrew1346's Avatar
The thing is... with the surging, it can be 50-60 degrees out, with the first start, it surges, so I don’t think the heater really has anything to do with the surging
post #6 of 14 (permalink) Old 04-14-2019, 10:04 PM
White Lightning
gsbrockman's Avatar
When did the surging begin?
post #7 of 14 (permalink) Old 04-14-2019, 10:27 PM
On the 99 the fuel heater is in the top of the fuel filter housing. Should not be surging after first 30 seconds even when cold. Better describe "surging".
bigfish95971 is offline
post #8 of 14 (permalink) Old 04-14-2019, 10:36 PM
N of 60's Avatar
RPM swings 700 to 500? 700 to 900?
2011,4wd LB/CC 2500 H&S Mini MCC by Tomeygun, BD protect 68rfe VB seperator plate enhanced stall triple disk TC, Super B 64.5/80/.91 3rd gen mani & inline EB, Arp 425s, Fass Titanium 95. Spare Mini in my closet.
High tech old school and finally lovin it.
N of 60 is offline
post #9 of 14 (permalink) Old 04-14-2019, 10:47 PM Thread Starter
andrew1346's Avatar
It swings from normal which is like 700, down to like 500, even when I take off at idle and up to around 1000 rpm, then it smooths out, once it’s warm it’s fine
post #10 of 14 (permalink) Old 04-14-2019, 10:49 PM Thread Starter
andrew1346's Avatar
It’s been doing this more the last couple of months but probably started randomly a couple years ago
post #11 of 14 (permalink) Old 04-15-2019, 01:07 AM
Ltngdrvr's Avatar
It's not a 99, 2014 according to the signature.
Ltngdrvr is offline
post #12 of 14 (permalink) Old 04-15-2019, 01:09 AM
Ltngdrvr's Avatar
It swings from normal which is like 700, down to like 500, even when I take off at idle and up to around 1000 rpm, then it smooths out, once itís warm itís fine
Sounds like a fuel rail pressure issue, need to get a gauge on it and see what it's doing.
Ltngdrvr is offline
Similar Threads
Running ATF in my 06 amazes even me. Ole Smoky 3rd Gen. Powertrain 224 12-07-2015 10:08 AM
What Exactly Does The FCA Do? tijuanasam 3rd Gen. Powertrain 6 08-17-2014 10:24 AM
Adding SuperTech 2 cycle oil to ULSD... jols 3rd Gen. Powertrain 46 10-01-2012 08:45 AM
Installed 2 new batterys. Pulling codes now. triflex 98.5-02 Powertrain 14 11-01-2011 03:09 PM
Joe G's fuel system writeup ykdave 94-98 Engine 2 04-22-2008 09:13 AM
