Rear Differential Fluid Drain...Need Help - Dodge Cummins Diesel Forum
 42Likes
post #1 of 66 (permalink) Old 02-28-2019, 02:08 PM Thread Starter
Need some quick assistance, although I'm afraid I know the answer.
I've got a 2014 3500 up on blocks and was going to change the rear end fluid. Took out the filler bolt. Took out the lowest bolt of the differential cover and expected oil to drain from that hole, however nothing came out. Do I need to completely remove all of the cover bolts and pry open the cover to get the fluid to drain? Will that ruin the gasket? (I do not have a replacement gasket).
Hotel California is offline
post #2 of 66 (permalink) Old 02-28-2019, 02:11 PM
G. Mcpherson's Avatar
You will have to Pull the cover. The gasket if there is still one in there is reusable from the factory.
Jayson41 likes this.
2018 Ram Big Horn. Crew Cab Short Box. 6.7Ltr. 68 RFE. Thuren Suspension
G. Mcpherson is offline
post #3 of 66 (permalink) Old 02-28-2019, 02:12 PM
Billy V's Avatar
You need to remove the cover itself. The gasket is reusable.
That bolt you removed is the Fill Hole.
A word of advice about replacing the Bolts, manual calls for 30 lb ft of torque.
- It seems a little high for these bolts, especially if the threads are wet.
Clean off the old RED loctite and replace the bolts with Blue. Use common sense when tightening this bolts in a star pattern.
Too Tall and Electrojake like this.
2017 Ram 2500 Laramie CTD 68rfe 4x4 CC SB
Billy V is offline
post #4 of 66 (permalink) Old 02-28-2019, 02:14 PM
HeavyTwo's Avatar
Yes, removal of rear cover is required.
You can loosen all bolts. Then start removing bottom ones. Gently pry cover on bottom when most all bolts out
The gasket maybe reusable. If its metal with RTV lines. Or you can buy a new gasket. Or you can just use RTV.
2014 RAM HD. Cummins 6.7 364.5SXE Turbo. EZLynk Tuned. Straight piped. Air-Ride.
HeavyTwo is offline
post #5 of 66 (permalink) Old 02-28-2019, 02:35 PM Thread Starter
Thanks all. I've got all the bolts out.
post #6 of 66 (permalink) Old 02-28-2019, 06:01 PM
TheRAMadaINN's Avatar
Be sure to use a clean rag to clean both sides of the gasket and the mating surface of the diff cover and axle prior to reassembly.
@TheRAMadaINN 2017 3500 CCSB SLT 68RFE 4x4 Flatbed FourWheelCamper Carli Pintop 37" Ridgegrapplers 4.30's
TheRAMadaINN is offline
post #7 of 66 (permalink) Old 02-28-2019, 07:34 PM
utahtrapper's Avatar
Might as well check your gear pattern.
nick00less, HeavyTwo and Jimmy N. like this.
2006 Blue Laramie DRW. 3500 5.9 G56 Mobil Delvac 50, Tans Cool PTO Covers, GDP Fuel Boss, GDP Double-X Ladder Bars, GPD big line kit, GDP MK-2 Fuel filter kit with CAT UHE 416 1225, GDP Power-Flo Intake Manifold, Throttle Up Industries Dual Fuel Filters, Dieselsite Coolant Filter, Cool Hose, Timbrens, 26k with Horses in Trailer, ................... BBi's .5 Towing Injectors WOW!
Carli Ball Joints
utahtrapper is offline
post #8 of 66 (permalink) Old 02-28-2019, 07:35 PM Thread Starter
Thanks for the assistance and advice. All done. No apparent leaks.
Next time I will not take out any of the differential cover bolts. Will just back
each of them out 1/8 inch and let the fluid drain through the gap
post #9 of 66 (permalink) Old 02-28-2019, 09:23 PM
callen8365's Avatar
If you develop a leak or next time it doesn’t work out for you, I would just buy a gasket. The rtv works, but if your ocd like me your down and out for a day. The directions for the stuff I used stated to put it on the cover, hand tighten the cover onto the differential, then wait 10-15 minutes before torquing it down. Then you were suppose to wait (I believe) 24 hours or so before filling up the differential with fluid. I’m sure a lot of people get away with not following the manufacture directions. But for whatever reason whenever I try to take a short cut, I always regret it and something happens. Anyways long story short a gasket in my opinion is the only way to go. Plus when you have to do the job again it’s a lot easier to get the gasket off than rtv sealant.
Chris
callen8365 is offline
post #10 of 66 (permalink) Old 02-28-2019, 09:30 PM
Jimmy N.'s Avatar
Originally Posted by Hotel California View Post
Next time I will not take out any of the differential cover bolts. Will just back each of them out 1/8 inch and let the fluid drain through the gap
Why? It doesn't take many seconds extra to remove the cover.
With it off you can inspect the gears and see if things look good in general.
Besides, how did you plan on cleaning off the sealing surfaces with an 1/8-inch gap?
mrbb1, utahtrapper and Electrojake like this.
Jimmy N. is offline
post #11 of 66 (permalink) Old 02-28-2019, 09:47 PM
mrbb1's Avatar
or just invest in a new cover with a drain, then never have to take cover off, unless you wish to inspect things?
2016 2500 crew cab Big Horn, Cummins, short bed, 4x4 cap, SIlver in coler
My 10th or so 2500 dodge/ram, now!
mrbb1 is offline
post #12 of 66 (permalink) Old 02-28-2019, 10:12 PM
Ltngdrvr's Avatar
With the oem reusable gasket, it will seal right back up without cleaning the gasket surface.
CCV reset/seatbelt chime disable
Ltngdrvr is online now
Similar Threads
Performing a Drain & Fill on the Aisin AS69RC Transmission gsbrockman 2013-2018 General Discussion 116 12-08-2018 10:38 PM
11.8 / 300mm AAM Rear Axle Fluid Change gsbrockman 2013-2018 General Discussion 123 02-10-2017 05:05 AM
Looking for advice for friend w/ 06 Fireman02 3rd Gen. Powertrain 63 12-05-2016 12:02 AM
2001 2500: Another bad automatic transmission defdes 911 Urgent Situations 5 01-31-2015 07:41 PM
What broke on your truck and when? cummins939 3rd Gen. Powertrain 46 03-12-2013 09:13 PM
