Rear Differential Fluid Drain...Need Help - Page 4 - Dodge Cummins Diesel Forum
 42Likes
post #37 of 66 (permalink) Old 03-01-2019, 08:20 PM
Jimmy N.'s Avatar
Originally Posted by Too Tall View Post
Here's a good alternative, even my dealer doesn't pull the cover.
I'd consider that the worst alternative. Okay, better than never changing the fluid.
At least with a drain plug most of the contaminants will come out.
'14 1500 V6, '17 3500 C&C, plus a '17 2500 in the household.
Jimmy N. is offline
post #38 of 66 (permalink) Old 03-01-2019, 08:20 PM
tankerpilot01's Avatar
Originally Posted by Jimmy N. View Post
I usually use the overkill method, taking the slowest speeds, longest allowable distances, etc. from three or four gear manufacturers.
In other words, if one source says no more than 50 mph and another 60, I go with 50.
And absolutely no towing until after at least 500 miles. Then ideally the correct procedure for that part of the break-in.
Normally I also change the fluid between 500 and 1,000 miles the first time.
I just posted the question of break in as a separate post. I知 over 500 miles and I知 going to tow around 7K 1500 miles. Then I was thinking to change the rear diff. I did similar on my duramax. Perhaps I should change it after getting to OK (750 miles towing the 7K); that would be around 1300 miles on the ODO. Then tow back to IA on fresh fluid.
Rat
2018 3500 Limited Tungsten 4x4 Dually-True Blue Pearl - CC - 8'
tankerpilot01 is offline
post #39 of 66 (permalink) Old 03-01-2019, 08:23 PM
Jimmy N.'s Avatar
I would change the fluid before the trip, then take a look at what's on the magnet when back home again.
At the very least I think you should check the magnet before leaving.
Jimmy N. is offline
post #40 of 66 (permalink) Old 03-01-2019, 08:26 PM
Change it with only 600 miles before towing? Then again after the 1500 miles towing the 7K?
The thought being to get fresh fluid in to flush out the break in contaminants before putting the weight behind her?
Rat
post #41 of 66 (permalink) Old 03-01-2019, 08:30 PM
Jimmy N.'s Avatar
Sorry, that's not what I meant. I'd change it at 600 miles, yes, but then leave well enough alone for 10,000 to 15,000 miles, depending on usage.
Oh, and take a peek at the magnet ever so often in between.
Jimmy N. is offline
The Following User Says Thank You to Jimmy N. For This Useful Post:
tankerpilot01 (03-01-2019)
post #42 of 66 (permalink) Old 03-01-2019, 08:36 PM
Too Tall's Avatar
I mean a better alternative than loosening the cover bolts and letting it drain as the OP was asking about. As you mentioned, who know what trash would get between the gasket and sealing surface.
USMC 1968 - 1970. 2014 2500 4 x 4 3.42 maximum Steel
Too Tall is offline
post #43 of 66 (permalink) Old 03-01-2019, 08:37 PM
So I値l change it before my trip. Then again prior to 渡ormal after doing some towing. As I think under severe duty amsoil says 50K with their severe gear 75W90. Not sure I知 comfortable if a lot of they was towing...to go 50K!
Rat
post #44 of 66 (permalink) Old 03-01-2019, 08:57 PM
Jimmy N.'s Avatar
I wouldn't change it twice in relatively rapid succession, unless you find crap in there on the first change.
Not knowing what or how often you tow, it's hard for me to guess how often the diff may need attention. The magnet will tell part of the story.
I nearly always tow, it's only a matter of what, and use Amsoil 75W-140. But I wouldn't feel comfortable going 50K without seeing what's going on in there, even if I didn't tow.
And once the cover is off, I certainly wouldn't put the old fluid back in.
Jimmy N. is offline
post #45 of 66 (permalink) Old 03-01-2019, 09:10 PM
agreed. No way I would put the fluid I just drained back in. 75W140. Copy. Maybe I was confusing the Ram with my duramax. I thought amsoil and even ram recommended 75W90....??? Do they have 75/140 in it from factory? Or do most run 140 no matter what Ram...or amsoil day?
Rat
post #46 of 66 (permalink) Old 03-01-2019, 09:15 PM
Jimmy N.'s Avatar
No, the 140 isn't recommended. But since it's still a 75W when cold, it shouldn't hurt anything. If it helps when towing heavy, great.
Besides, many run the 140 in Rams.
Jimmy N. is offline
post #47 of 66 (permalink) Old 03-01-2019, 10:47 PM
Safe to assume this applies to rear diff only (changing fluid at 500-1000 miles) I致e never followed this procedure for the front diffs...double checking I知 not wrong with that technique!
Rat
post #48 of 66 (permalink) Old 03-02-2019, 02:12 AM
White Lightning
gsbrockman's Avatar
iTrader Score: 28 reviews
Heck, it's a lot quicker and easier to pull and reinstall a diff cover than it is to change a flat tire.
Why learn to change a tire....when there痴 this
Jimmy N. likes this.
2018 RAM 4500 Chassis Tradesman Crew Cab 60 C/A 4WD, 6.7L Cummins, AISIN AS69RC Transmission, 4.10 Axle Ratio, Chrome Appearance Group, Keyless Entry, Fog Lamps, Chrome Tubular Steps, 52+22 gallon fuel tanks, 5.0 Radio, Single Disc CD Player, 225/70R19.5 Continental HDR痴, Aluminum Wheels, Parkview Backup Camera, Trailer Brake Controller. Equipped with a CM SK Series flatbed w/B&W Turnover Ball. Purchased new April 23, 2018. Currently : 140,423 miles and 2,468 hours as of June 6th, 2019 (Average Miles Per Hour = 56.9)
gsbrockman is offline
Similar Threads
Performing a Drain & Fill on the Aisin AS69RC Transmission gsbrockman 2013-2018 General Discussion 116 12-08-2018 10:38 PM
11.8 / 300mm AAM Rear Axle Fluid Change gsbrockman 2013-2018 General Discussion 123 02-10-2017 05:05 AM
Looking for advice for friend w/ 06 Fireman02 3rd Gen. Powertrain 63 12-05-2016 12:02 AM
2001 2500: Another bad automatic transmission defdes 911 Urgent Situations 5 01-31-2015 07:41 PM
What broke on your truck and when? cummins939 3rd Gen. Powertrain 46 03-12-2013 09:13 PM
