How to check the health of your 68RFE - Dodge Cummins Diesel Forum
 26Likes
post #1 of 61 (permalink) Old 02-18-2019, 12:03 AM Thread Starter
nick00less's Avatar
Please share what your CVI values are so we can get a rolling avg. that I can update this thread with
**UPDATE** Read Post #18
You can also use EzLynk (which is much easier)
So today I discovered something and I’d like to share it with anyone whose been curious about the health of their clutches. Are they worn? Are they ok? How do you check? For you OCD people who worry thinking they’ve damaged their clutches (or other components), even though you don’t have any CEL, there’s a quick way you can check.
The method I used was AlphaOBD. The information we’re looking for is CVI (Clutch Volume Index).
Taken from RevMax-
“Clutch Volume Index (CVI) is a calculated numerical value to indicate how much volume of transmission fluid was needed to apply a friction element without stroking the accumulator piston...As the friction material wears, the volume of fluid needed to apply the element increases.”
Taken from @TransEngineer -
“The CVI is a measure of how much oil it takes (in units of 1/64 in³) to apply the clutch. So, for example, a 4C CVI value of 42 means it takes 42/64 = .656 in³ to apply the 4C clutch.”
Basically as your values increase, this could either mean your clutches are wearing (requiring more fluid to hold them) or there could be a leak. @TransEngineer if I’m wrong on any of this feel free to correct me)
The ‘recommended’ CVI’s for our 68RFE are
The way you find out through AlphaOBD is choose the engine function and select MY2013-17. Then click connect.
Select Plotted Data tab up top. Beneath that select Start Scan. Then find tabs 20 and 21.
You’re looking for
-LR Clutch Fill Volume (Tab 20)
-OD Clutch Fill Volume (Tab 20)
-UD Clutch Fill Volume (Tab 21)
-2C Clutch Fill Volume (Tab 21)
-4C Clutch Fill Volume (Tab 21)
You will then activate each of these items by either double clicking them or right click and click Activate Selected. A green dot should appear to the far left. Turn truck on and go for a drive. During my tests I selected/activated a ton of additional windows (as you’ll see in my photos) however you only need to select the ones mentioned above. Shift 1-6 down the road a few times and the program should record your findings.
When you finish the units will be 0.00 to the far right but above that should be a recorded number that was logged while driving. The only ones that might not have a small red number will be LR and UD. That’s ok. Just use whatever number is in that column.
Results should look like this
Take each of the numbers recorded and multiply them by 64.
Voila! Now you have your CVI’s and at the very least a basic idea of your transmissions health.
@TransEngineer spent some time helping me so I figured I would pass the info along to anyone who might not have known either.
'14 6.7 S465 tuned by CTT
'17 6.7 tuned by CTT
'18 6.7 S467.7 tuned by CTT
nick00less is offline
The Following 15 Users Say Thank You to nick00less For This Useful Post:
2013_6.7 (02-18-2019), 2500/6 (02-19-2019), boshog (02-18-2019), cycling4life (03-02-2019), dieselgeek5.9 (02-19-2019), DJRobinson (02-19-2019), dvpvic (05-26-2019), gatorguy (02-19-2019), Jared Herzog (02-18-2019), MachAF (03-09-2019), NickBeek (03-01-2019), pwr2tow (02-18-2019), Show Killer (03-07-2019), str8t six (02-18-2019), Trowel2013 (02-18-2019)
post #2 of 61 (permalink) Old 02-18-2019, 10:17 AM
K9Kodi's Avatar
Very impressive brother. Very impressive
--2015 2500, Crew Cab, Long Bed, 4x4, G56, Maximum Steel
- To Do List, 6" suspension,37" tires,4.56 Gears
--2006 2500 4x4 4 door long bed auto, 8" BDS, 37s
K9Kodi is offline
post #3 of 61 (permalink) Old 02-18-2019, 10:29 AM
hooked55's Avatar
WOW! Incredible stuff. And I always thought if the fluid is the right color, the right level on the stick, no burned smell, no leaks, and it shifted properly we were good to go. What next!
2014 2500 Laramie Crew, short bed. 2014 30’ 10k Timber Ridge TT, Nascar Nut.......
hooked55 is offline
post #4 of 61 (permalink) Old 02-18-2019, 10:38 AM
Lins's Avatar
Nice to know alfaOBD can do this. I did a ton of research with my '02 1500 when it was giving me some trouble which had the 45RFE. I read about the CVI's a bunch but the only tools I could find that could do it were hundreds of dollars.
I could be wrong in how I'm explaining it, but when the trans re-learns, it is resetting the measuring your CVI's at various temps, shifts, etc. Although it is always learning and looks at the CVI's to adjust how it shifts.
Lins is offline
post #5 of 61 (permalink) Old 02-18-2019, 11:02 AM
slayerfish's Avatar
Way too anal for this guy. it either works or it don't!
'16 2500 Bighorn 6.7 Cummins CCLB 4x4 68rfe Timbrens Hellwig // 2017 Hallmark 8.5' UTE Pop-Up.
slayerfish is offline
post #6 of 61 (permalink) Old 02-18-2019, 11:23 AM
battlerattle's Avatar
Make this a sticky!
dillonjm and hooked55 like this.
2016 2500 Laramie Longhorn 4wd CTD crewcab Granite Crystal Metalic, 2" Pure Performance triple rate leveling springs, Adjustable front Trackbar, Stealth Module
battlerattle is offline
post #7 of 61 (permalink) Old 02-18-2019, 01:39 PM
Its like doing a leak down test every month just to make sure your rings and valves are seating when you have no problems at all. I paid a lot of money for a truck so I can worry about it every time I drove it, if I wanted that I would have bought something a lot older and a LOT CHEAPER.
2015 2500 4x4 megacab automatic with ARE Z series topper
cjgoode is offline
post #8 of 61 (permalink) Old 02-18-2019, 01:41 PM
Lins's Avatar
Then why even comment on this thread?
BobSagetIsGod? likes this.
Lins is offline
post #9 of 61 (permalink) Old 02-18-2019, 01:42 PM Thread Starter
nick00less's Avatar
Curious to hear what others are getting for CVI values (from stock guys and guys with tuned/high hp trucks)
post #10 of 61 (permalink) Old 02-18-2019, 03:28 PM
I guess I’m gonna have to buy an Android device (gag). This all seems too cool.
Sent from my iPhone using Tapatalk Pro
2012 CCSB Laramie
6.7, 68RFE
EFI Live, Flo Pro/factory exhaust, gauges and Edge Insight.
Mike D Texas is offline
post #11 of 61 (permalink) Old 02-18-2019, 03:36 PM
webrats's Avatar
Im in the same boat. Please port to ios!
'16 | 3500 | Dually | 4x4| Longhorn | Fox 2.0 | Carli Stuff| Fabtech Lifted 5" 4 link | Efi SWDS | BD throttle thing | Deleted | Speakers/Sub swapped | Amps | Royalty Core stuff | Rigid Lights | Cell Booster | Train BELL | AKA Al Gore | Paid Off
webrats is offline
post #12 of 61 (permalink) Old 02-18-2019, 03:37 PM
Too Tall's Avatar
Very ingenious, thanks for sharing that! Love that stuff
USMC 1968 - 1970. 2014 2500 4 x 4 3.42 maximum Steel
Too Tall is offline
Similar Threads
Limp Mode, P1222 Error, and WTS Light while driving on a 2006 Cummins 5.9L 06SilverMegaCummins 3rd Gen. Powertrain 0 08-17-2016 02:41 PM
Code 1776 Justincast 07.5 - 09 3rd Gen 6.7L Powertrain 4 07-17-2016 10:51 AM
Use a Dyno to check Engine Health? 20:04:05 3rd Gen. Powertrain 1 03-22-2016 01:21 AM
47RE transmission troubleshooting chart. country_hick 94-98 Powertrain 0 02-25-2013 12:30 PM
blue smoke AGAIN !!!! 2006sigouin 98.5-02 Powertrain 10 12-09-2012 07:00 PM
