Alfa OBD Success! - Page 44 - Dodge Cummins Diesel Forum
 190Likes
post #517 of 616 (permalink) Old 09-30-2019, 10:11 PM
cutoutcummins's Avatar
Originally Posted by Brummo View Post
Not to go off track, but for those of us with 2018 trucks. From what I am reading, to get Alfa OBD to work we need to by another connector?
I'd like to be able to adjust some things, but am unsure as to what I need to get to do it.
Thanks
You'll need the bypass cable that @ M2Mods / @deereguy sells
Sent from my iPhone using Tapatalk Pro
2018 Ram 2500 6.4L hemi. 2" RCX Level and 1.5" Supreme Suspension Rear Spacers. 35x12.5x18 Federal Cougaria MT'S, 275/65R20 Cooper Discoverer AT3 XLT AT on Stock Black 20's
cutoutcummins is offline
post #518 of 616 (permalink) Old 09-30-2019, 10:55 PM
Originally Posted by cutoutcummins View Post
I'd go with the smallest size first. My 35's measured like 34.5 but to get my speedo right was closer to 33" if I remember.
I used this to get the tire size in millimeters
https://tiresize.com/calculator/
ya my 285/75-18s are listed as 35.1" tall, but on the truck they are listed as above. I have read to use the actual measured height, just wondering which one.
Thanks
yes, you need the security bypass module.
'18 3500 Mega Aisin, Carli suspended
í13 3500 CCLB Aisin, Carli suspended
'11 2500 Mega, Carli suspended
kylant is offline
post #519 of 616 (permalink) Old 09-30-2019, 11:03 PM
Like I said start with the smallest size first. It's probably going to take a few tries to get it right. Took me 4 or 5 times to get it and I'm still off by ~1 mph. I am waiting for winter when I put my winter tires on which are 275/65/20 to see where I'm at
post #520 of 616 (permalink) Old 09-30-2019, 11:33 PM
I'm running 285/75-18s and I just took a real world measurement of what they were on the truck (34 ish if I remember) and it worked perfectly.
I inputted that actual measured height and I am spot on with my displayed mph vs gps mph.
2016 Ram 2500 Big Horn Mega cab, 285/75-18 (35's) Nitto Ridge Grapplers. Fuel Hostage III 18x9 +18 BS Wheels. Bilstein 2.3″ Front Lift, 1" rear spacer.
mtnrider is offline
post #521 of 616 (permalink) Old 10-01-2019, 02:20 AM
lpennock's Avatar
You can go to the tire manufacturer web site and get the actual rolling diameter in revolutions per mile. 20168/revs per mile will get you a very close starting number. It will be slightly low do to rounding error on the 20168.
Sent from my SM-T350 using Tapatalk
Leonard Pennock AD7AS
2006 Ram 3500 4x4 6sp, F&R TrueTrac, EFI Live, GT3782R, Dual Disc
2018 Ram 3500DRW 4x4, Stock for now
lpennock is offline
post #522 of 616 (permalink) Old 10-01-2019, 10:47 AM
i understand. i want to use the real world measurement on the the truck. however, my measurements are 33.75 rear and 33.5 front. these are 285/75-18s.
i understand to pick one try it and try again if it is not right. however, i am not keen on trying multiple times. that just creates multiple times for errors
kylant is offline
post #523 of 616 (permalink) Old 10-01-2019, 01:00 PM
Show Killer's Avatar
That 1/4" difference between the front and rear isn't going to make a difference on your speedo. There will only be about 4 more tire rotations every mile on the front tires compared to the rear tires. I say use either measurement, your speedo is going to read the same.
'14 White 2500 Tradesman, CCLB, 4X4, with some extras
'18 Jeep Wrangler Rubicon on 37's w/all the goodies
'93 Dodge Stealth R/T
Show Killer is offline
post #524 of 616 (permalink) Old 10-01-2019, 05:45 PM
Trowel2013's Avatar
Just an FYI for those who haven't tried yet, I attempted to hook my laptop up to the truck using the cable that normally connects to my CTS2. DO NOT DO THIS. I emailed the person at Alfaobd asking if I could do this. The response was he wasn't sure, it would either connect or it wouldn't. I contacted Edge. They weren't sure either and said the same thing. So, I tried. Luckily, I didn't do any permanent damage. It melted part of the HDMI connection. Was connected for maybe 20-30 seconds, things didn't seem right, so I disconnected rather abruptly, thank goodness. Slightly damaged the HDMI cable, but it's still usable. The dongle I used to connect to the laptop took the brunt of the damage. Laptop seems fine. Truck threw a canbus code. Cleared it and it hasn't come back. That was six days ago. Needless to say, I think (and hope) I got lucky. Just figured I would put this out as a warning to others.
Sent from my iPad using Tapatalk
Lins likes this.
2013-2500 Laramie 4x4-CC-Long Box-Auto-3:42
Trowel2013 is offline
post #525 of 616 (permalink) Old 10-01-2019, 07:44 PM
ok, pulled the trigger and got it done. was a little nerveracked at first.
went with the measured height of 33.75" on the truck, 285/75-18. converted to a circumference of 2693.
speedo was very close, I would say anywhere from 1/2-1mph fast.
i went home and corrected to 2691. speedo was still fast, but gps seemed to respond faster more inline with the speedo.
i corrected to 2689 for the last time. the speedo and gps were pretty darn accurate and close to each other. the speedo still would read a touch faster for a moment, then the gps would respond.
i think i am done adjusting for now.
i may reduce another 2mm and see if that makes it dead accurate.
thanks for all the info
kylant is offline
post #526 of 616 (permalink) Old 10-01-2019, 08:39 PM
G. Mcpherson's Avatar
Great. I did the same as you with 33.8. Adjusted it with 2689 and came out perfect and i have 295-70-18 Cooper's.
2018 Ram Big Horn. Crew Cab Short Box. 6.7Ltr. 68 RFE. Thuren Suspension
G. Mcpherson is offline
post #527 of 616 (permalink) Old 10-03-2019, 05:49 PM
skeemsCTD's Avatar
Has anybody installed the cargo camera on a 2013 2500 successfully even tho it did not come with the soft switches from factory?
2017 Ram 2500 Outdoorsman CTD CCSB 4X4, 68RFE, HBS 2" Level, Thuren Track Bar, Bilstein 5100's, 18x9 +1 Fuel Maverick D538, 35x12.5 Nitto Ridge Grappler, Dee-Zee EZ Drop
skeemsCTD is offline
post #528 of 616 (permalink) Old 10-15-2019, 09:11 PM
Brummo's Avatar
Anyone have a link to Bypass Module needed for the 18's?
The site that was suggested before says out of stock...
2018 2500 CC Laramie 6.7L Cummins
Brummo is offline
