What have you done to your Ram today? - Page 298 - Dodge Cummins Diesel Forum
2010-2012 General Discussion General Chit Chat About the 6.7L 4th generation Cummins - NO ADVERTISING
 921Likes
post #3565 of 3786 (permalink) Old 04-15-2019, 11:21 PM
cumminthanstrockin's Avatar
Originally Posted by Andrewme View Post
Experienced my first death wabble today. Was getting onto the highway and when I got to 55 the truck started shaking violently. Had to drive 50 all the way home. Jacked up the front and there is some slight movement in the upper ball joint so that's going to have to get fixed. Saw on Amazon a orion motor tech 22 piece ball joint kit. Has anyone used one of those kits on our trucks?
Do you have an orielly, advance, autozone or any parts store near you? Just use there’s on rental
Tow Rig: 2011 Ram 2500 Laramie MCSB - FloPro | Sinister | Draconian EFI | Thuren/Carli | Fuel Wheels | Toyo MT | RIGID INDUSTRIES
Daily Driver: 2016 Ram 1500 Laramie Longhorn Crew Cab w/ 5.7 Hemi & 8 Speed
cumminthanstrockin is offline
post #3566 of 3786 (permalink) Old 04-15-2019, 11:27 PM
Andrewme's Avatar
Yes. But I like gathering tools. And every time I used the loan a tool program the tool I get is broken or defective. It also gives me another way to make extra money on the side. Just never got the press before because the shop on base has one but I wont be able to use that one for another 3-4 weeks. And I need this one done asap.
2011 Dodge Ram 2500HD CCLB manual 4x4. G56. Valair DD clutch, 5" tbe, stainless diesel S465, Smeding diesel intake horn, air dog II 165gph lift pump, mini maxx MCC by Anarchy Diesel, 1.75" level; 37x12.5R17 on G-FX TR-12
Andrewme is offline
post #3567 of 3786 (permalink) Old 04-16-2019, 09:27 AM
Barlow96's Avatar
I have a kit similar to that. I changed my ball joints out a couple weeks back. I had to call friend who had a dodge kit from Chrysler. The c clap he had was bigger and had more fittings. My kit like that would not do the job.
2011 2500 4x4, 33 inch toyo's RTs on 18 inch fuel wheels with +20 offset , Edge CTS2, RamManInc manual locking hubs. Efi Live by Anarchy, 5 inch flo pro tbe with muffler, CNS egr delete kit.
Barlow96 is offline
post #3568 of 3786 (permalink) Old 04-18-2019, 02:06 PM
Pufferman's Avatar
Currie tools came in. JJ rebuild kit should be here tomorrow. Hopefully get to do some wrenching this weekend. Cause not looking forward to do home improvements...2000 sqft of nail down oak flooring... LULZ
THE WHITE WHALE 2010 2500 6.7 4x4. Auto. MCSB. 363SXE. Hamilton 194/220. Manton 110# Springs & Rods. ARP 2000. 160HP Tune By PHIL. 5" TBE. AFE Intake. Fleece Thisandthat.
Pufferman is offline
post #3569 of 3786 (permalink) Old 04-20-2019, 08:50 AM
Andrewme's Avatar
Went to replace the ball joints last night. Started with the passenger side. Got to the wheel bearing bolts and saw this
Picked up 2 new ujoints, and went ahead and ordered new wheel bearings and replace it all while I'm there.
daltana and Pufferman like this.
Andrewme is offline
post #3570 of 3786 (permalink) Old 04-20-2019, 01:03 PM
Pufferman's Avatar
nice find! lol
post #3571 of 3786 (permalink) Old 04-20-2019, 01:13 PM
Andrewme's Avatar
Yea. Definitely wasnt expecting to do everything at once lol. But might was well. Just have to be careful for another week so it doesnt cause any more damage. Plan to use the ball joint press to press thr cups of the ujoint out. And itll give me an excuse to do some extra cleaning and some paint.
Andrewme is offline
post #3572 of 3786 (permalink) Old 04-20-2019, 04:33 PM
Pufferman's Avatar
i'd prolly remove the front shaft to take off any extra torque on the joints.
Since you're in there... MANUAL HUB CONVERSION!!!!
daltana and one2doo like this.
post #3573 of 3786 (permalink) Old 04-20-2019, 04:41 PM
Pufferman's Avatar
...but deleted so no more soot...
post #3574 of 3786 (permalink) Old 04-20-2019, 04:47 PM
Andrewme's Avatar
If it's in 2wd the front shaft is free spinning. But since it a locked hub the front axle shafts spin with the wheel and can stress the joint. Dont plan on running to town this week but if I keep the speeds low it shouldn't be a problem. The new wheel bearings should be here on Wednesday. I can start Thursday after work and ride my bicycle to work on Friday. It's only a mile away so it's not too bad.
Andrewme is offline
post #3575 of 3786 (permalink) Old 04-20-2019, 09:46 PM
Been helping work on my 2004 3/4 ton Cummins. Been in a friends shop since late November getting cab corners, rockers. That turned into 4 doors, fenders and a hood to get rid of rust. In final reassembly stages. Then on to painting frame and mounting the new bed.
Pufferman and cwendel like this.
ryanl14w is offline
post #3576 of 3786 (permalink) Old 04-21-2019, 08:56 AM
Ducati M.
DMan1198's Avatar
Those axle joints won’t press out with a balljoint press (I’ve tried) the top of the caps are tapered or something, and they just won’t push through like most u-joints will. The only puller that’ll work cradles one cup, and pushes sides of the cups going the other way.
This: https://www.tigertool.com/product/u-...SABEgJgIvD_BwE
Jaeger-12 ram 3500, CCLB, 68rfe, 2" lift, 5" tbe, steed, s476, MM w/MCC, OD, ISSPRO factory match, ARP 625's, Hamilton 103's/extreme duties, T/Rex traction bars, mag hytec trans pan,
The Roo Hunter- 93 w250, g360, np205, 4" lift, custom 3/8" bumper, Hellman sump, raptor 100, dual filters, ddp stg 3's and pin, steed, modded hybrid wh1c/hx40/s467fmw compounds 4" tbe, autometer cobalt series.
The Huntress- 02 VW Jetta tdi, 5 speed, egr/muffler delete, 11mm ve, gt1749v, ISSPRO factory match.
click here for Instagram:
DMan1198 is offline
