Front and rear diff fluids - Dodge Cummins Diesel Forum
2010-2012 General Discussion General Chit Chat About the 6.7L 4th generation Cummins - NO ADVERTISING
post #1 of 6 (permalink) Old 02-08-2011, 11:30 AM Thread Starter
At what mileage are you guys doing your first change on the front and rear diffs? In at 15k and I'm being told they are both dirty.
2010 Dodge Ram 2500 CC Laramie Cummins 4x4
kev2500 is offline
post #2 of 6 (permalink) Old 02-08-2011, 12:25 PM
I refused to let them change mine at 15,000. At 25,000 they said the front was dark colored but the rear was still clean, so i let them change the front. The dealers have a long laundry list of things they want to charge for, most of which dont make any sense to me.
NevadaNick is offline
post #3 of 6 (permalink) Old 02-08-2011, 01:25 PM Thread Starter
thanks nick. They want 260 for rear diff and 100 for the front, i'll just do it myself when it warms up. Amsoil here i come!
kev2500 is offline
post #4 of 6 (permalink) Old 02-08-2011, 03:13 PM
agoldxj's Avatar
iTrader Score: 36 reviews
Wow 360 bucks for less than a hours work! Im in the wrong business..
1993 w250
2012 Jeep Rubicon
agoldxj is offline
post #5 of 6 (permalink) Old 02-08-2011, 03:41 PM
Toyota and Cummins Nut!
toyota_mdt_tech's Avatar
This is from All Data, for 2010 Diesel 4WD:
CORPORATE AXLES
Front Axle C200F Mopar Synthetic Gear Lubricant SAE 75W-140
Front Axle C200FE ANTI-SPIN Mopar Synthetic Gear Lubricant SAE 75W-140
Front Axle C205F Mopar Synthetic Gear Lubricant SAE 75W-90
Rear Axle 8.25 Mopar Synthetic Gear Lubricant SAE 75W-140
Rear Axle 8.25 ANTI-SPIN Mopar Synthetic Gear Lubricant SAE 75W-140
Rear Axle 9.25 Mopar Synthetic Gear Lubricant SAE 75W-140
Rear Axle 9.25 ANTI-SPIN Mopar Synthetic Gear Lubricant SAE 75W-140
Rear Axle C213R Mopar Synthetic Gear Lubricant SAE 75W-140
Rear Axle C213RE ANTI-SPIN Mopar Synthetic Gear Lubricant SAE 75W-140
DANA AXLES
Front Axle 186 FBI Mopar Synthetic Gear Lubricant SAE 80W-90
Front Axle 186 FIA Mopar Synthetic Gear Lubricant SAE 80W-90
Front Axle 216 FBI ANTI-SPIN Mopar Synthetic Gear Lubricant SAE 80W-90
Rear Axle 226 RBI Mopar Synthetic Gear Lubricant SAE 80W-90
Rear Axle 226 RBI ANTI-SPIN Mopar Synthetic Gear Lubricant SAE 80W-90
Rear Axle 226 RIA ANTI-SPIN Mopar Synthetic Gear Lubricant SAE 75W-90
Rear Axle 302 RBI Mopar Synthetic Gear Lubricant SAE 75W-90
Rear Axle 302 RBI ANTI-SPIN Mopar Synthetic Gear Lubricant SAE 75W-90
AMERICAN AXLES
Front Axle 9.25 Mopar Synthetic Gear Lubricant SAE 75W-90
Front Axle 9.25 ANTI-SPIN Mopar Synthetic Gear Lubricant SAE 75W-90
Rear Axle 10.5 Mopar Synthetic Gear Lubricant SAE 75W-90
Rear Axle 10.5 ANTI-SPIN Mopar Synthetic Gear Lubricant SAE 75W-90
Rear Axle 11.5 Mopar Synthetic Gear Lubricant SAE 75W-90
Rear Axle 11.5 ANTI-SPIN Mopar Synthetic Gear Lubricant SAE 75W-90
MAGNA AXLES
FRONT AXLE 275 FBI Mopar Synthetic Gear Lubricant SAE 75W-90
Engine Oil:
Engine Oil SAE 15W-40
API CJ-4 Certified, that meets CES 20081 Standards
Transmissions:
6 Speed AS68RC Mopar AS68RC ATF
Automatic Transmission Fluid Mopar ATF +4
Manual Transmission Fluid:
G56 Mopar ATF +4 Transmission Fluid
G238 Mopar ATF +4 Transmission Fluid
Transfer case:
Transfer Case Fluid Type
Mopar ATF +4, Automatic Transmission Fluid
NV246 Automatic Transfer Case Only
- Mopar PN 05179014AA, Transfer Case Lubricant
Power steering:
Mopar ATF +4 Automatic Transmission Fluid.
Coolant:
Mopar Antifreeze/Coolant 5 Year/100,000 Mile Formula HOAT (Hybrid Organic Additive Technology) or equivalent.
Clutch Fluid:
HYDRAULIC CLUTCH FLUID
Mopar DOT 3 Brake Fluid, SAE J1703 should be used. If DOT 3, SAE J1703 brake fluid is not available, then Mopar Brake and Clutch Fluid DOT 4 (P/N 04549625AC) is acceptable.
Brake Fluid:
BRAKE FLUID
Mopar DOT 3 and SAE J1703 or equivalent.
NOTE: If DOT 3 is not available, then DOT 4 or DOT 4+ is acceptable. Use only recommended brake fluids.
2010 Dodge 2500 SLT Crew Cab Long Bed 4WD G56 6SPD Cummins 6.7 turbo diesel, 3.42 LSD. Add ons: Laramie Alloys, "Powerwagon" flares, Powerwagon bed decal (4X4 off road) OE Ram mudflaps, OE Slush Mats, OE Clearance Lamps, Geno's shift knob in black, spray in bedliner, OE brake controller, Pro Tech Toolbox, Licensed "Extra" class HAM operator, Ranger RCI-2950 10-11-12 meter all mode ham radio/CB, co-phased 4 foot Firestick Firefly 5/8 wave antennas. Yaesu FT7800 2m/70cm VHF/UHF-FM Ham Radio, Larsen NMO2/70C mounted dual band VHF/UHF antenna, Alinco DR-06 6 meter VHF FM, Larsen NMO50C 1/4 wave antenna, 150 PSI on board air system, air powered 157 db train horns!
toyota_mdt_tech is offline
The Following User Says Thank You to toyota_mdt_tech For This Useful Post:
20102500 (04-10-2012)
post #6 of 6 (permalink) Old 02-08-2011, 07:34 PM
Ghostrider304's Avatar
Mine will get Royal Purple and some Mag Hitech covers sooner than later.
Will-
2014 RAM 3500, Crew Cab, LB, Max Steel, 4x4, Laramie, Aisin, 3.73 SOLD-2010 3500
Ghostrider304 is offline
