Clunking noise coming from under the front of the truck - Dodge Cummins Diesel Forum
2010-2012 General Discussion General Chit Chat About the 6.7L 4th generation Cummins - NO ADVERTISING
post #1 of 6 (permalink) Old 11-17-2019, 09:14 PM Thread Starter
Need some help here. I have an 11’ 2500 4x4 lifted 5” just recently started hearing a clunking noise coming from under the truck while driving at highway speeds of +60 mph. If the speed is less than 60, no noise. Is sounds like it may be in the front axle. Checked steering, ball joints and transfer case shaft, everything is tight. Not sure what to do next. Any suggestions? I was thinking of opening the front axle and taking a look but it doesn’t make sense to me that the noise only comes at certain speeds. Thanks in advance.
timacomfort is offline
post #2 of 6 (permalink) Old 11-17-2019, 10:57 PM
5.7 Hemi's Avatar
Check the axle u joints and hub bearings.
5.7 Hemi is offline
post #3 of 6 (permalink) Old 11-25-2019, 07:12 PM
if you get a vibration check the cardan joint. if it blows so does the transfer case. do you grease it?
ar_mcadams is offline
post #4 of 6 (permalink) Old 12-01-2019, 07:21 PM Thread Starter
Hi, thanks for your response. Sorry for the late response...been super busy. So, I replaced the ball joints on the driver side and thought that I solved the issue but the noise has actually gotten worse. It now does it as low as 45 mph. Thank you for the suggestion, I will check the cardan joint and let you know. Aslo, I will be pulling the diff cover to check the gears...
post #5 of 6 (permalink) Old 12-10-2019, 10:14 AM
jroyster06's Avatar
I doubt its the gears. sounds like U joints
2013 Mega Laramine longhorn. 6" BDS Long arm, 22" Hostages, 37x13.50 Nitto Ridge Grapplers, Fusion Bumpers, Back flip, AMP steps, Mag Diff Covers, 4.30's.... 3 previous cummins
jroyster06 is online now
post #6 of 6 (permalink) Old 12-14-2019, 07:09 PM
BR1
how tight did you put that trac bar bolts?
2010 CCLB Auto 4x4, 37x12.5x17 Ridge Grapplers, Method Standard machined, dynatrac pro-steer's, Carli TracBar, Carli arms, Carli Fox Commuters, Creative Box Brace, 3" Carli springs, synergy shackle, Tom Woods front shaft, synergy steering, carli lower stablizer.
BR1 is offline
