2012 Dodge 3500 temperature @ 245 degrees - Dodge Cummins Diesel Forum
2010-2012 General Discussion General Chit Chat About the 6.7L 4th generation Cummins - NO ADVERTISING
post #1 of 8 (permalink) Old 09-13-2019, 08:59 AM Thread Starter
So every now and then my truck will read running hot @ 245 degrees then quickly go back to normal of 200-203. Lately its been running hot and not going back. I changed the thermostat thinking it was sticking but still doing it. I noticed that all the antifreeze has been in the overflow reservoir when this happens. I opened the radiator cap while it was hot and only steam came out. I expected bubbling hot antifreeze/water. Any suggestions on what could be causing this?
james87johnson is offline
post #2 of 8 (permalink) Old 09-13-2019, 09:27 AM
correngcon's Avatar
Head gasket
Been there, done that. It's the head gasket allowing compression pressure to force the coolant into the reservoir and raise the temperature. When you do the head gasket, get the head surface machined and put in your head studs.
The Heretic - 2012 Ram 3500 Mega SRW Longhorn Laramie with a few tasteful mods
2017 Ram 3500 DRW Big Horn (For SALE)
correngcon is offline
post #3 of 8 (permalink) Old 09-13-2019, 11:30 AM
I agree with correngcon about it being the head gasket. If it was anything else the coolant jug would be empty because all the coolant would be pulled back into the radiator. I had two head gasket failures on my 2011 CTD that were replaced under warranty and studs ($469 on me) that replaced the head bolts. I think the dealership did them on the cheap, as the truck was never right after either job. It is now in a private, well recommended garage getting new head gasket and new studs. The difference is that this time the head has the warp machined back to flat. It makes me angry that the stealership wouldn't do the job right because it was warranty work, and that doesn't pay much. Oh, btw, when the garage pulled the head off they saw one of the piston faces had contact marks where something had been banging into the head. They figured the injectors had been replaced and thought a nozzle had come loose, but they were surprised when I told them the injectors were original. Another " thank you" to the rip off dealership.
2011 Laramie 2500 Crew 4x4 w/ 8' box, 68RFE transmission with trans tune, H&S mini w/5" exhaust, sinister egr delete, arp head studs, S&B cold air intake, B&W rollover goose neck hitch, roll'n'lock bed cover
Den52 is offline
post #4 of 8 (permalink) Old 09-13-2019, 02:57 PM
N of 60's Avatar
So whats the whole story here? Deleted with an H&S or a smarty?
2011,4wd LB/CC 2500 H&S Mini MCC by Tomeygun, BD protect 68rfe VB seperator plate enhanced stall triple disk TC, Super B 64.5/80/.91 3rd gen mani & inline EB, Arp 425s, Fass Titanium 95. Spare Mini in my closet.
High tech old school and finally lovin it.
N of 60 is offline
post #5 of 8 (permalink) Old 09-14-2019, 03:36 AM
1ton's Avatar
Here's a pretty good visual of what could be going on. (jump to around 24:50 to get right to it)
2018 3500 Cab and Chassis CM Bed
6.7 CTD 6 speed auto 100% stock
1ton is offline
post #6 of 8 (permalink) Old 09-14-2019, 09:55 AM
N of 60's Avatar
Itís his tuning settings. Same as Den 52.
N of 60 is offline
post #7 of 8 (permalink) Old 09-16-2019, 01:50 AM
JDB1180's Avatar
I'm very curious what a delete has to do with higher engine temps. Mine is deleted with H&S mini maxx and will get up to about 220 when pulling.
JDB1180 is offline
post #8 of 8 (permalink) Old 09-16-2019, 03:16 PM
N of 60's Avatar
Deleting doesn't cause it. It usually helps lower them.
Incorrect tuner set up, Timing versus fueling and or using defuel settings with the Mini on a 4th gen. Lifting or picking away at the HG VIA higher cylinder pressures. Once air/combustion gases get into the water jacket, cooling is now affected. It will cause these temp spikes and overflow the coolant reservoir after the 18 psi has been breached at the rad cap. Where else can it go?
N of 60 is offline
