Sxe366 egt - Dodge Cummins Diesel Forum
2010-2012 General Discussion General Chit Chat About the 6.7L 4th generation Cummins - NO ADVERTISING
 3Likes
post #1 of 14 (permalink) Old 07-15-2019, 09:08 PM Thread Starter
Sxe366 egt
Was looking for actual feedback on egt's with guys running sxe366. My stock turbo took a dump and plan to do injectors in near future. I'm currently on stock fuel with an old h&s mini max. Waiting to do a tune when fuel sticks go in. Had turbo on since winter, can say it's a no brainer that it has some lag currently. Now that it's hot outside I'm noticing my egt when truck is in 6th is in the 900's and in ballpark of 4-6 lbs boost going down highway . I cant say I remember it being quite that bad. I thought it was in the high 7's before. Now I'm paranoid. Also truck had 37's and without going to a 4.10 and up gear ratio I know that it's not optimal, but life happens and just cant do everything all at once. So any egt feed back would be much appreciated.
american5.9 is offline
post #2 of 14 (permalink) Old 07-15-2019, 09:50 PM
N of 60's Avatar
Without custom tuning on 37s and stock gearing. I could see those numbers that youíre getting. Whatís your AR size?
2011,4wd LB/CC 2500 H&S Mini MCC by Tomeygun, BD protect 68rfe VB seperator plate enhanced stall triple disk TC, Super B 64.5/80/.91 3rd gen mani & inline EB, Arp 425s, Fass Titanium 95. Spare Mini in my closet.High tech old school and finally lovin it.
N of 60 is offline
post #3 of 14 (permalink) Old 07-15-2019, 10:02 PM Thread Starter
It has the H&S kit on it. .91 a/r and 73 mm turbine. Truck is due for a service so this weekend I will double check to see if I have a head gasket going on it, but haven't noticed coolant levels change or any issues in that department. The driveability of the truck isn't the worst for now, I'm just beating my head against the wall not feeling like egt's were this high when I put it on in March, but can't say for sure. I feel like I would have noticed these temps and remembered.
post #4 of 14 (permalink) Old 07-15-2019, 10:05 PM
N of 60's Avatar
Whatís an H&S Kit?
N of 60 is offline
post #5 of 14 (permalink) Old 07-15-2019, 10:08 PM Thread Starter
H&S motorsports turbo kit. Sorry.
N of 60 likes this.
post #6 of 14 (permalink) Old 07-15-2019, 10:21 PM
N of 60's Avatar
Anarchy still does MCC for the 4th gens.
What RPM are you at when @ 900f hi-way speed?
Just curious.
N of 60 is offline
post #7 of 14 (permalink) Old 07-15-2019, 10:28 PM Thread Starter
I would say it's about 1600 rpm or so. If truck is in 6th, doing 65 mph it's in the 900's. If I come to slight grade, and trans does not downshift on it's own, it will climb to 1000. Even when I manually downshift to 5th and bring the rpm's up, it helps, but not much, it will drop back to low 900. if there is little load on the truck going down a country road at 60, its even in the 800 mark for egt. never really is it consistently in the 700's
post #8 of 14 (permalink) Old 07-16-2019, 06:12 PM
Unloaded on the freeway, doing 76-80mph, I'm about 800*
~5-6lbs of boost
1.0 A/R though
'12 Mega, Thuren coils/arms/swaybar/shackles, Carli Front End Kit, Synergy Steering Brace, Fox 2.0, 35" Nittos, S366SXE, EFI by Anarchy, ARP 625s, FASS, 4" TBE w/muffler, stock 68rfe
vandersnoot is offline
The Following User Says Thank You to vandersnoot For This Useful Post:
N of 60 (07-16-2019)
post #9 of 14 (permalink) Old 07-16-2019, 07:33 PM Thread Starter
~5-6lbs of boost
1.0 A/R though
Are you also on stock fuel? In 6th gear going up slight hill does it climb another 150 degrees or so? How do you like the turbo?
post #10 of 14 (permalink) Old 07-16-2019, 08:57 PM
Yeah, I'm still on stock fuel and yes EGT's will rise if there is a grade (6th), but generally not over 1k*. Honestly, I'm not really a fan of the turbo. To keep EGT's and smoke in check, you have to live at 2k RPMs and above, which gets annoying for a daily. I don't even try to pass people in 6th gear (drop to 5th) because it just ends up a smokey mess. That being said, if you're easy on the skinny pedal, its not an issue. When I merge onto the freeway though, I shift it by hand.
If I had to do it over again, I would've gotten a Cheetah for stock fuel or compounds with fuel mods.
post #11 of 14 (permalink) Old 07-16-2019, 09:19 PM
the man in black's Avatar
37s on 3.42s is not a good combo. The motor always has a load on it. Add in sub par tuning and it's no wonder you have higher egts. As for why they are higher now than earlier in the year, hot air is less dense than cool air. You're truck runs less efficient in 100f weather than 60f. Add in all the other factors and there you go.
N of 60 and Paul_hegeholz like this.
Scooty Puff Sr - 2016 3500 CCLB
Truckasaurus - 2010 2500 CCSB -sold
the man in black is offline
post #12 of 14 (permalink) Old 07-16-2019, 09:32 PM Thread Starter
What are your egt's?
