Delete Coolant Leak - Dodge Cummins Diesel Forum
2010-2012 General Discussion General Chit Chat About the 6.7L 4th generation Cummins - NO ADVERTISING
 3Likes
  • 1 Post By drwaggs
  • 1 Post By DMan1198
post #1 of 9 (permalink) Old 04-20-2019, 05:39 PM Thread Starter
drwaggs's Avatar
Delete Coolant Leak
Finally deleted, but I have a leak. See pic. I've read other threads that lead to a Glacier Diesel Heater Hose adapter. Will that work here or are there better fits?
Thanks
2012 Ram 2500 CCLB White, Edge CTS A-pillar mount | Cooper MTP's 285/70/17
EFI Live 4" Pro Flo with Muffler
drwaggs is offline
post #2 of 9 (permalink) Old 04-20-2019, 07:02 PM
I had the same issue after doing my delete and found the issue to be a bad o-ring. I’d pull the connection out and look at that first. Found a new o-ring in a o-ring kit from harbor freight tool. Hope this helps
Cajunberry is offline
The Following User Says Thank You to Cajunberry For This Useful Post:
drwaggs (04-20-2019)
post #3 of 9 (permalink) Old 04-20-2019, 08:02 PM
On call 24/7
98whitelightnin's Avatar
iTrader Score: 16 reviews
I replaced the oring on mine too and my leak quit. Find the biggest oring that will fit and get a handful of them
1998 12v, 4x4, Club Cab, Carli, Thuren, BlueTop, Core 4x4, BD Diesel, PDD 5x.012, South Bend
2012 Laramie Longhorn, EFI by Ryan, Carli, Thuren
1995 Dually, Weston's 5x.016, 4k GSK, 5" FloPro, 255/85r16 Toyo M/T, Goerend, ARP, 60# Springs, BW 62/65/14, BW 75/96/1.10, Isspro, Fass 125, BDP Sump, 7mm DV's, 751 HP 1883 FP Torque on NOS
1998 P-Pumped 24v, 4x4, NV4500 swap
98whitelightnin is offline
The Following User Says Thank You to 98whitelightnin For This Useful Post:
post #4 of 9 (permalink) Old 04-20-2019, 10:34 PM
N of 60's Avatar
Or remove the bypass all together, no more anything to leak.
2011,4wd LB/CC 2500 H&S Mini MCC by Tomeygun, BD protect 68rfe VB seperator plate enhanced stall triple disk TC, Super B 64.5/80/.91 3rd gen mani & inline EB, Arp 425s, Fass Titanium 95. Spare Mini in my closet.High tech old school and finally lovin it.
N of 60 is offline
post #5 of 9 (permalink) Old 04-21-2019, 10:01 AM
Ducati M.
DMan1198's Avatar
What N of 60 said.
Jaeger-12 ram 3500, CCLB, 68rfe, 2" lift, 5" tbe, steed, s476, MM3 w/Warp, ISSPRO factory match, ARP 625's, Hamilton 103's/extreme duties, T/Rex traction bars, mag hytec trans pan, build thread
The Roo Hunter- 93 w250, g360, np205, 4" lift, custom 3/8" bumper, Hellman sump, raptor 100, dual filters, ddp stg 3's and pin, steed, modded hybrid wh1c/hx40/s467fmw compounds 4" tbe, autometer cobalt series.
The Huntress- 02 VW Jetta tdi, 5 speed, egr/muffler delete, 11mm ve, gt1749v, ISSPRO factory match.
click here for Instagram: dsmdiesel
DMan1198 is offline
post #6 of 9 (permalink) Old 04-21-2019, 11:04 PM
iTrader Score: 4 reviews
Originally Posted by DMan1198 View Post
What N of 60 said.
and how would you do that?
2007:sold
2012 MC, deleted, 6" RC lift with fox shocks. ARMY25E (SIGNAL the way)
kens_isb is offline
post #7 of 9 (permalink) Old 05-01-2019, 09:23 PM Thread Starter
drwaggs's Avatar
Not sure how it happened, but bad O-ring right after or during install. Easily fixed with new ring.
Name:	Blown O-ring.jpg
98whitelightnin likes this.
drwaggs is offline
post #8 of 9 (permalink) Old 05-02-2019, 11:47 AM
Ducati M.
DMan1198's Avatar
Insufficient lubrication on install is often the cause of o-ring failure when it looks like that. I generally use petroleum jelly on any o-ring I install.
tnt_motorsports likes this.
DMan1198 is offline
post #9 of 9 (permalink) Old 05-02-2019, 11:49 AM
Ducati M.
DMan1198's Avatar
This is my setup. Itís a modified stock pipe from source automotive.
N of 60 likes this.
DMan1198 is offline
The Following User Says Thank You to DMan1198 For This Useful Post:
drwaggs (05-13-2019)
Similar Threads
2016 RAM full delete zedman 2013-2018 General Discussion 28 03-15-2019 11:54 PM
Sinister EGR Delete Coolant Leak USARMY12V 4th Gen Powertrain 3 12-03-2015 04:59 PM
Slow coolant leak: Waterpump UtahBruteForce 07.5 - 09 3rd Gen 6.7 Liter General Discussion 3 11-15-2015 08:58 AM
Mystery Coolant Leak shooter_d 07.5 - 09 3rd Gen 6.7L Powertrain 3 06-11-2013 12:10 PM
post KDP coolant leak 12valveRussian 94-98 Powertrain 3 12-22-2010 07:07 PM
