Steering play - Dodge Cummins Diesel Forum
2010-2012 General Discussion General Chit Chat About the 6.7L 4th generation Cummins - NO ADVERTISING
 7Likes
post #1 of 92 (permalink) Old 11-27-2014, 09:04 PM Thread Starter
Talking Steering play-FIXED!!!
2012 Ram 2500 4x4 Hemi, bone stock
I know its not a Cummins but I like this forum
Steering is loose on center since 50,000km and getting worse (100,000km now) Getting into winter driving and sick of white knuckles
I went underneath to look for problem areas and the only issue I could see was a dead spot right at the box. Pitman arm wasn't moving immediately when steering wheel moved back and forth.
I figured bad steering box, ordered a Redhead and installed it and a brace last weekend. Still have the same issue. Now I'm wondering about the coupler on the box input shaft. Anybody replaced the lower steering shaft and had great improvement??? It seems like the double D design on the box would be more prone to getting loose than a splined shaft
freejay is offline
The Following 2 Users Say Thank You to freejay For This Useful Post:
2012Ram6.7 (09-27-2016), MTMOPAR1 (09-28-2016)
post #2 of 92 (permalink) Old 11-30-2014, 04:24 AM
ClintsCummins's Avatar
Did you take it in for the latest recall...replaced knuckles on mine for a recall 2 weeks ago and had the same issue. Its like brand new again. Just a thought.
2010 Ram 3500 6.7 Crew Cab/Short Bed, Blue, MiniMaxx, H&S EGR/Cooler del., H&S Rail Plug, AFE intake man., AFE Trans pan & rear diff. cover.S&B Cold Air Intake, AirDogII, 4" SS Flo Pro TBE, Nitto 295/70/18's on XD Spy's,Recon lights, N-Fab Nerfs,
ClintsCummins is offline
The Following User Says Thank You to ClintsCummins For This Useful Post:
Anklh (11-30-2014)
post #3 of 92 (permalink) Old 11-30-2014, 06:34 AM Thread Starter
I haven't been notified of any recalls on my truck. Are you talking about the N49 campaign? According to the Ram website that's the only steering recall that could apply. Did they replace your balljoints?
Thanks
freejay is offline
post #4 of 92 (permalink) Old 11-30-2014, 07:56 AM
Look closely at the drag link. Had to replace mine @ 60,000 miles. Steering is much improved now.
Hope this helps.
wu367 is offline
The Following User Says Thank You to wu367 For This Useful Post:
Anklh (11-30-2014)
post #5 of 92 (permalink) Old 11-30-2014, 10:54 AM Thread Starter
I just ran my VIN number on the Chrysler website and apparently my truck doesn't need the n49 recall. Has anybody been able to get them to do this recall even though your truck doesn't need it according to them?
I'm going to take a real close look at the drag link, it seems tight if you're off center with the steering wheel but its loose from side to side if that makes any sense
freejay is offline
post #6 of 92 (permalink) Old 11-30-2014, 12:14 PM
Ducati M.
DMan1198's Avatar
I don't think they'd do the n49 recall without it actually being needed, as mine took a little over 10 months for them to get the parts to do it
Jaeger-12 ram 3500, CCLB, 68rfe, 2" lift, 5" tbe, steed, s476, MM w/MCC, OD, ISSPRO factory match, ARP 625's, Hamilton 103's/extreme duties, T/Rex traction bars, mag hytec trans pan,
The Roo Hunter- 93 w250, g360, np205, 4" lift, custom 3/8" bumper, Hellman sump, raptor 100, dual filters, ddp stg 3's and pin, steed, modded hybrid wh1c/hx40/s467fmw compounds 4" tbe, autometer cobalt series.
The Huntress- 02 VW Jetta tdi, 5 speed, egr/muffler delete, 11mm ve, gt1749v, ISSPRO factory match.
click here for Instagram:
DMan1198 is online now
post #7 of 92 (permalink) Old 11-30-2014, 05:35 PM
They said it was a Tie-Rod repair but it included lower balls joints from what the service guy told me. This was the third time I took it in for this recall...Dodge says they "may not" need to replace all but need to inspect. My dealer doesn't mess with the inspection and replaces the items regardless, or so it seems.Can always take it to them and ask...worse they can say is "No". Nothing to loose...
post #8 of 92 (permalink) Old 12-27-2014, 04:33 PM Thread Starter
Update!
I changed the drag link, still no better.
Finally got time to have the truck aligned, the guy said the alignment was perfect and front end wear was well within spec.
Clamped the input into steering box and still had major play at the steering wheel. Found the coupler at the firewall had major play. Fixed it with about 1/2" of rubber air hose and a hose clamp.
Good as new again.
I'd recommend anyone with steering issues look at this
freejay is offline
The Following 5 Users Say Thank You to freejay For This Useful Post:
2012Ram6.7 (09-27-2016), 4x4x4door (12-30-2014), apeters (12-27-2014), CumminDreamz (12-31-2014), malibu27 (03-07-2015)
post #9 of 92 (permalink) Old 12-27-2014, 06:17 PM Thread Starter
Pics...
Play to one side
Play to the other side
Rubber hose inserted on pins
Hose clamp to secure hose
freejay is offline
The Following 20 Users Say Thank You to freejay For This Useful Post:
4x4x4door (12-30-2014), 98whitelightnin (10-27-2016), BowWow (12-29-2014), CumminDreamz (09-24-2015), Cummins_Diesel_Man (08-23-2016), Danderson (01-22-2016), DarylB (05-13-2018), imkindofabigdeal (08-25-2016), J.R.R. (01-06-2018), malibu27 (01-25-2015), MegaWonder (06-13-2017), Mike2007Cummins (09-26-2015), ol sooty (01-02-2015), old ram (09-26-2015), RWH (09-27-2016), UNDER-PRESSURE (01-27-2015), woody96639 (09-30-2015), WouldRatherbeCummin (03-07-2015), Xrockdawgx (04-03-2015), Yellowmike (05-01-2016)
post #10 of 92 (permalink) Old 12-28-2014, 04:09 PM
is that just a screw in pin ?
does it help with the feel ?
2012 big horn 2500 CCLB 4x4, GDP MKII Filter,RDS 60 gal bed mounted toolbox diesel tank with GDP 20 micron filter water sep, ARP 625 head studs, ISSO boost and EGT temp gauges center mount,MiniMax tuned by Draconian Diesel
BigRich954RR is offline
The Following User Says Thank You to BigRich954RR For This Useful Post:
Poncho2012 (04-03-2015)
post #11 of 92 (permalink) Old 12-28-2014, 10:52 PM Thread Starter
It seems like a pressed in dowel. I think the pin is a backup for an internal plastic or rubber piece that no longer functions on my truck. The steering feels really good now. Night and day difference from before
freejay is offline
The Following 7 Users Say Thank You to freejay For This Useful Post:
4x4x4door (12-29-2014), BowWow (12-29-2014), coldakram (12-29-2014), Jeff McGuire (01-22-2015), MamthTORQ (01-22-2015), ol sooty (01-01-2015), shawsy599 (03-15-2016)
post #12 of 92 (permalink) Old 01-25-2015, 12:49 PM
malibu27's Avatar
Thank you for this thread! Exactly why I'm part of this forum!
J.R.R. likes this.
2010 lotta extras
malibu27 is offline
