Fan tower bearing - Dodge Cummins Diesel Forum
2003/2004 General Discussion General Discussion for the Early (2003/2004) Common Rail No Advertising ...NO ADVERTISING
post #1 of 5 (permalink) Old 08-12-2019, 06:47 PM Thread Starter
Kirby5.9cr's Avatar
Fan tower bearing
I look everywhere trying to find an answer does this bearing needs to be pressed in or it can be done without a press?
Kirby5.9cr is offline
post #2 of 5 (permalink) Old 08-13-2019, 12:01 AM
I used a BFH and a brass punch, oh and some wood blocks to support it.
04.5 CC SB 4x4, Low stall converter, billet input, intermediate, and valve body mods. HPT tuned by Firepunk, FASS 150, BMS 50 injectors. Mechanical fan conversion with OEM plastic fan blades, Traction bars.
jballou is offline
post #3 of 5 (permalink) Old 08-13-2019, 12:03 AM
Now that I think about it, once I destroyed the bearing getting it off, I put the bearing on some dry ice, and heated up the retainer. May have been the other way around, but you get the idea. Slid together no problem.
jballou is offline
The Following User Says Thank You to jballou For This Useful Post:
Kirby5.9cr (08-14-2019)
post #4 of 5 (permalink) Old 08-13-2019, 12:22 AM Thread Starter
Kirby5.9cr's Avatar
Thanks , I put it in the freezer tonight with that thought in mind I think with the 110 degrees tomorrow the tower should be hot enough and the bearing cool enough for that , I just didnít want to take everything apart and not being able to finish
post #5 of 5 (permalink) Old 08-14-2019, 11:23 PM Thread Starter
Kirby5.9cr's Avatar
Thanks I installed the new bearing today and everything went well
