Good lord steering linkage drop - Dodge Cummins Diesel Forum
2003/2004 General Discussion General Discussion for the Early (2003/2004) Common Rail No Advertising ...NO ADVERTISING
 2Likes
  • 1 Post By Galawcum
post #1 of 7 (permalink) Old 08-12-2019, 03:49 PM Thread Starter
So after droping the kid off a school I pull into work and this happens... I count my blessings because it couldnt of happen at a better place. Anyone ever seen one shear off like this?
20003 lwb 2500 smarty touch, K/N, 4inch exh, and 1pc driveshaft
Galawcum is offline
post #2 of 7 (permalink) Old 08-12-2019, 08:08 PM
sfpcservice's Avatar
Yep, happened to me backing out of the driveway. Thanked God right there that it wasn't on the highway going around a curve on a bridge...
Got the upgraded one from Dodge, not messing around with eBay or Amazon on a part like this.
sfpcservice is offline
post #3 of 7 (permalink) Old 08-12-2019, 08:21 PM Thread Starter
Talk to me about this upgrade. I just checked 3 different box store brands and none of them will press into my pitman arm wth..... the collar will only go in the arm mabye 1/8 and its not enough thread sticking out for me to out nut and cotter key on.
Galawcum is offline
post #4 of 7 (permalink) Old 08-14-2019, 01:25 PM
Compair the A taper of the pitman to how you are trying to install the arm. .
Depending on lift and corrisponding pitman , they can go top or bottom install . The A taper indicates the correct way of install. .
I have seen more that one steering bar end installed upside down , not good .
SOLD My 2001 and 2005 .
SOLD 2004.5 Sons mod truck
24hrsparkey is offline
post #5 of 7 (permalink) Old 08-14-2019, 03:00 PM Thread Starter
Yes sir that was my problem yesterday. Then I realized the guy who put it in before me had it installed from the bottom even though the taper was from the top.
24hrsparkey likes this.
Galawcum is offline
The Following User Says Thank You to Galawcum For This Useful Post:
24hrsparkey (08-14-2019)
post #6 of 7 (permalink) Old 08-14-2019, 06:38 PM
Glad you figured it out and got the replacement in correctly .
Botched steering components can be dangerous .
post #7 of 7 (permalink) Old 08-14-2019, 09:54 PM Thread Starter
Yea sir! It has me wondering if I should replace the whole y link with a slight better one because of the nut job that worked on the truck before I got it. This stuff can turn into a death trap quick.
Galawcum is offline
