Is a snubber valve needed on airdog for low side FP? - Dodge Cummins Diesel Forum
2003/2004 General Discussion General Discussion for the Early (2003/2004) Common Rail No Advertising ...NO ADVERTISING
 3Likes
  • 2 Post By tryNto
  • 1 Post By tryNto
post #1 of 6 (permalink) Old 04-13-2019, 11:40 AM Thread Starter
Hey all,
Iíve been a little quiet on the forum because Iíve been rebuilding my engine.... Anyways, I got myself an airdog 100gph lift pump that replaces the in tank pump thatís in my 03 (it was retrofitted by the previous owner so I knows itís an in tank).
I am getting an isspro electric 0-30psi Fuel pressure gauge from Genoís and saw that the sensor harness is long enough to go from the cab directly to the lift pump without having a T in the line.
So my question is this: if I put a gauge directly into the lift pump, do I need to attach a snubber valve on it so it doesnít ruin the isspro sending unit or gauge?
Thanks in advance guys
a-roddd14 is offline
post #2 of 6 (permalink) Old 04-14-2019, 02:33 AM
tryNto's Avatar
Will the sensor be getting psi after it goes through the filters? lp psi is a good indicator of when it is time to change filters.
I have used an electric fuel gauge for over 10 years without a snubber, you will get opinions for both sides of this.
I thought snubbers were used for the other type of gauges, mechanical.
rghavana and a-roddd14 like this.
'03 QCLB 2500 305/555 NV5600 w/ FastCoolers 3.73 4x4, Color match Lear Topper.
Smarty S-06 PoD, Edge CTS for Gauges, DPP Cool Tube w/ OEM AF Box, Baldwin PF7977, GDP MK-2 FF Kit, Pusher Intake Horn, Adj. Boost Elbow @ 30psi, OEM Fan Clutch Delete/Mod, Steering Box Brace, On-Board Air w/Horns
tryNto is offline
post #3 of 6 (permalink) Old 04-14-2019, 09:27 AM Thread Starter
Yes it will be after the filters. I didnít think I needed a snubber but I thought I would double check! Thank you. But thatís interesting that placing it after the filters will give you an idea of when itís a good time to change them.
post #4 of 6 (permalink) Old 04-15-2019, 02:43 PM
tryNto's Avatar
I use 3psi below normal or 1 year as my time to change the 3mic filter on the GDP kit.
rghavana likes this.
tryNto is offline
post #5 of 6 (permalink) Old 04-16-2019, 11:55 AM
Diesel Auto Power
iTrader Score: 21 reviews
A snubber or needle valve will prolong the life of the sensor. Its not necessary, but its only about $6. People go both ways.
jkidd is offline
post #6 of 6 (permalink) Old 04-25-2019, 06:31 PM
I run one in the hopes of less "spiky" readings.
2004.5 2500 - Built 48re - 2 inch leveling kit - 2nd gen conversion intake/turbo/exhaust - Sinister Coolant Filter - FASS 165 - Smarty SR - DDP 90s - HD Push Rods - HD Valve Springs - ARP 625+ Studs
Krew is offline
Similar Threads
Lift pump pressure what's everyone running dodgeih 98.5-02 Performance Parts Discussion 219 05-24-2015 03:06 PM
47RE Gurus, I need input. davedriveschevys 98.5-02 Powertrain 7 02-20-2015 03:28 PM
2002 and newer Chrysler, Dodge Computer DTC Error Codes part 1 Reddevil1 3rd Gen. Powertrain 3 07-25-2012 06:14 PM
NO overdrive....Only Problem... What next?? BoostedOne 98.5-02 Technical & Diagnostics 21 02-01-2011 11:40 AM
Joe G's fuel system writeup ykdave 94-98 Engine 2 04-22-2008 09:13 AM
