Front dually spacer? - Dodge Cummins Diesel Forum
1st Gen Tire and Wheel Discussion of tire and wheel options
post #1 of 3 (permalink) Old 04-26-2018, 12:02 PM Thread Starter
12vFFS's Avatar
I have a 1990 W350 dually and am looking at some fuel mavericks. I am wondering if the will fit and what I can do because my truck has 5/8 studs? also I am looking at rims with a front single wheel conversion and just wondering how I would get the dually spacer off and make this work ?
I have also read things about having to centre the wheel with tapered lugs or studs? Just not clear on if these rims will work for me, any help would be great.
12vFFS is offline
post #2 of 3 (permalink) Old 06-22-2019, 11:20 AM
Roadsterfan's Avatar
I knew this is an older post but Im curious what you came up with. Iím doing exactly the same thing: I bought a dually front axle from a w350 and Im converting to single front wheel. I bought a set of dually front hubs that someone sheared the wheel stud locations off, narrowed the hub slightly on a lathe and is using the thicker rear stud mounting locations for a longer stud that now holds the rotor, the hub, and the wheel. It is beefier than the factory hubs and the track is now slightly wider- which is good because Iím trying to run 3rd gen wheel on this 1st gen crewcab. Prior to this, the 3rd gen wheels hit the balljoints because of the increased offset.
What did you do? Iím in the middle of this and about to mount the axle any day now- my backup plan is to mount a set of Raceline 983 Wheels (17Ēx9) which I happen to have two of, but I was trying to avoid paying retail for two more wheels in the middle of my 1st gen crewcab ctd build...
Steve Hemphill
93 D250 Dually AirRide, 92 D350 Dually,...
1990 CTD, NV4500 in a 85 F350 SRW Crewcab
Roadsterfan is offline
post #3 of 3 (permalink) Old 07-04-2019, 12:33 PM
u2slow's Avatar
Its not a spacer. It is a complete bearing hub cast in proportions to fit the OE dually wheels.
Gorilla makes a tapered seat 5/8" nut (60 degree; std for SRW wheels)
https://www.summitracing.com/int/par...57ht/overview/
There is also a more generic nut, but has a different seat angle (90 degree)
https://www.dormanproducts.com/p-26436-611-055.aspx
I consider DRW a hassle unless you're running really heavy all the time. 3750-4000# rated singles do everything I need.
If you did switch to SRW hubs, you could get away from the old 'external' style lockouts, and then run a spacer tailored for your aftermarket dually wheels. Really depends what your priorities are.
93 W250 Club 6BTA |5spd |60/80/3.54/Lockright |4" lift |315/75R16 |HX35 |5x.012s |BD pin & gov spring
90 D250 6BT |5spd |D60/3.54/Lockright
u2slow is offline
