Dodge Cummins Diesel Forum - View Single Post - Replacing your CP3 - DIY
post #5 of (permalink) Old 09-05-2009, 06:01 PM Thread Starter
cumminalong
Feelings NOT Included!
cumminalong's Avatar
The worst part is getting the pump back in the pilot bore of the gear housing, everything else is cake.
Put some clean oil on the o-ring and lube the pilot bore of the gear housing and it's much easier.
Once your get the o-ring past the bevel on the pilot bore, the pump will slide right in.
Make sure you don't have any oil on the pump shaft and get as much oil off the shaft bore in the pump gear as possible.
'06 Ram 2500 CTD - Garmon Stage 4 Fat Shaft, Trips (FMW 472 over a pair of FMW 467's)
'12 Ram 3500 DRW - Garmon High Pressure 68RFE
Shut up and open your wallet! This whoopin' ain't gonna be free!
cumminalong is offline
