Dodge Cummins Diesel Forum - View Single Post - DPF 90%, required regeneration now message!!
post #3 of (permalink) Old 10-16-2014, 11:19 PM
camperman
Go Packers
camperman's Avatar
Copied & pasted from 2012 owners manual. Hope this helps.
Exhaust System – Regeneration Required Now
“Exhaust System—Regeneration Required Now” will be
displayed on the Electronic Vehicle Information Center
(EVIC) if the exhaust particulate filter reaches 80% of its
maximum storage capacity. Under conditions of exclusive
short duration and low speed driving cycles, your
Cummins diesel engine and exhaust after-treatment
system may never reach the conditions required to remove
the trapped PM. If this occurs, the “Exhaust System
— Regeneration Required Now” message will be displayed
in the EVIC. If this message is displayed, you will
hear one chime to assist in alerting you of this condition.
By simply driving your vehicle at highway speeds for as
little as 45 minutes, you can remedy the condition in the
particulate filter system and allow your Cummins diesel
engine and exhaust after-treatment system to remove the
trapped PM and restore the system to normal operating
condition.
Exhaust Filter XX% Full
Indicates that the Diesel Particulate Filter (DPF) is approaching
full.
Exhaust System – Regeneration In Process
Indicates that the Diesel Particulate Filter (DPF) is selfcleaning.
Maintain your current driving condition until
regeneration is completed.
Exhaust System – Regeneration Completed
Indicates that the Diesel Particulate Filter (DPF) selfcleaning
is completed. If this message is displayed, you
will hear one chime to assist in alerting you of this condition.
2012 SLT 3500, CCLB, HO, SRW 4x2, 4.10s, 68RFE, Mineral Grey, Pacbrake air springs, Fumoto oil valve, Cat/Cummins Dual Filter kit, Edge CTS Monitor.
camperman is offline
The Following User Says Thank You to camperman For This Useful Post:
honda_guy4 (10-17-2014)
