Dodge Cummins Diesel Forum - View Single Post - '09 and newer free spin hub conversion
post #19 of (permalink) Old 08-29-2014, 09:13 PM
Raspy
Steers with the throttle
Raspy's Avatar
Originally Posted by Danderson View Post
If there's a hole in NTG's schedule next week,my Dynatrac freespins,bj's and u-joints are going in.Can't wait!
I'm sure you'll like the Dynatrac ball joints. They drive nice and mine have lasted a long time, maybe 160,000 miles. If I had it to do over, I'd skip the free spin hub setup. Here's why: First I had a defective hub that Dynatrac replaced under warrantee. Then a bad stub shaft bearing that damaged the stub shaft and the new hub. Those were replaced by me at my cost. Now the wheel bearings are beginning to talk to me. Twice I was stranded in the mountains in a snow storm with no 4WD before I got it straightened out. Plus there was no increase in mileage that I noticed. It's a nice idea, and it makes the U joints last longer, but it's expensive and requires periodic maintenance that is not easy. I have used 2WD low, but only a couple of times, and 4WD low would have worked too.
John
I only exaggerate enough to compensate for being taken with a grain of salt
2014 Ram 3500 Std Cab SRW Cummins/Aisin.
Raspy is offline
