Dodge Cummins Diesel Forum - View Single Post - 2.5" lift in front
post #3 of (permalink) Old 06-30-2014, 12:37 AM
Comrade General
Comrade General's Avatar
when i got my my 1/2 ton, it had approx a 2in lift in the front and only cleared 35s with some trimming
Generally if you want 35s, a 4in is the way to go, unless you dont mind trimming
The Hungry Diesel <<check it out
1993 w250 getrag, 374 spring, THD pin, THD comp inj 6x.013, SBDD clutch, timing spacer, 60mm hx35, HT3B, D80, 3.54, 35"s, 6in lift, AirDog, studs, o-ringed Dyno: 427/951
Comrade General is offline
