Dodge Cummins Diesel Forum - View Single Post - Vibrations and shuttering when turning
post #4 of (permalink) Old 06-29-2014, 11:30 PM
country_hick
country_hick's Avatar
Your u-joints might be chewed up internally and still be tight.
The bearing assembly of the u-joint may have notches instead of a smooth surface. As the u-joint is forced to work during a turn this idea would make sense. Picture the needle bearings in a case that has cutouts the same size as the needles. When you turn the needle falls into the groove nicely. Then when the needle hits the uphill part of a groove it struggles to go over that hump. That would make a jerking and a vibration.
Naturally this can happen to any bearing. It is not just limited to u-joints.
I would tend to rule out the tires. They should not be a cause of noise at low speeds.
1997 3500 club cab 3.54 gears towing & camper pkg. Still stock with a built transmission at 120k. 4" exhaust, 4kgsk, and exhaust brake waiting for installation. 37337 upgrade. Still need ideas for improvements for hauling 15k fifth wheel.
country_hick is offline
The Following User Says Thank You to country_hick For This Useful Post:
peckens (06-30-2014)
