25K miles zero codes then truck would barely... - Dodge Cummins Diesel Forum
post #1 of 8 (permalink) Old 09-07-2011, 10:44 PM Thread Starter
Truck would idle real rough. Cycle the key a few times and would run right. No codes!! Dealer said the turbo was most likely getting stuck. They cleaned the turbo, EGR, 02, wrapped 02 with heat wrap, egr cooler valve and pressure lines on dpf. Truck no longer has the idle issue but is real sluggish/slow off the line....overhead mileage is way down too....Am I in some stupid regen or somthing?? Put 500 miles on it and still the same.....
rraulston is offline
post #2 of 8 (permalink) Old 09-07-2011, 10:53 PM
Powder_Keg's Avatar
Fill out your sig so we know what your working with. Otherwise we cant help not knowing anything.
2008 4X4 3500 QCLB, 34K, G56, 3:73's, EFI Live tuning, Mini Maxx (as gauges), S&B Intake, Full Deletes, 4" TBE, lowered back down, Carli suspension both ends, Billstien 5100's, Amp Research boards, Line X, Completely covered in Marathon Seat covers, Mossy Oak New Break Up
Originally Posted by Powder_Keg View Post
Cheap, Fast, Reliable. You only get two of the three....
Powder_Keg is offline
post #3 of 8 (permalink) Old 09-07-2011, 10:54 PM
scubieman's Avatar
Fill on sig. Change fuel filter, change air filter. If not get some gauges to read fuel pressures and boost.
scubieman is offline
post #4 of 8 (permalink) Old 09-07-2011, 11:51 PM Thread Starter
well I saved the sig, but its not comming up. Its a 2009 6.7 bone stock auto 4x4 extra cab. All filter within the last 1000k miles. This all started after the major cleaning. Runs fine, but just not peppy anymore. Requires alot more pedal to move. Have NEVER had a code for anything!!
2009 6.7 bone stock 4x4 extra cab. J35 flash.
post #5 of 8 (permalink) Old 09-08-2011, 09:26 AM
diesellady's Avatar
Turbo is not closing down far enough. The ring in the turbo closes to restrict exhaust flow to the fan on the turbine side of the turbo. Kind of like putting your thumb on the end of a hose to accelerate the water so you can hose off your driveway. As it accelerates the exhaust, it causes the turbo to spool much quicker on acceleration. IF the ring is stuck open too far, you will have serious turbo lag. Tell them to give you a new turbo. And have them put the star scanner on it and take it around the block. You can watch vane position as you drive.
2007 6.7 4x4 Laramie ATS 68rfe 5star, Copilot, Edge w/CTS, Atomizer, H&S 5" TB,8"Stacks,ATS Diff, 6" lift Caltracs, Dynatracs
diesellady is offline
post #6 of 8 (permalink) Old 09-08-2011, 10:22 PM Thread Starter
can I try cleaning it myself with the port they put into the turbo??? Or can it be taken apart and manually cleaned??? I am 3 mpg less on the overhead and it no longer moves up and down like it used too......
post #7 of 8 (permalink) Old 09-08-2011, 11:53 PM Thread Starter
"P2563 is a fault that gets set when the turbo has reduced travel due to soot build up. Despite some rumors it's not fuel system related or turbo actuator problems. It just indicates that you need to have the turbo cleaned."
Found this....if correct, maybe its not my problem. Ive never had a code......
post #8 of 8 (permalink) Old 09-09-2011, 01:14 AM
diesellady's Avatar
Or a P2580 which is low turbine speed sensor. THis can also indicate the turbine is not spinning fast enough. The reason you would want them to warranty it out, is because the new updated turbo has a whole new casting. Works much better and spools quicker. You will like it and the good part, is you don't have a whole drilled in your turbo.
I have a theory on why they clean it instead of pulling it and replacing it. When you drop the turbo, it hits the motormount before it clears the studs from the exhaust manifold. Pain in the you know what to remove and reinstall. If you are within warranty, just make them change it out for you. especially since you have had it cleaned once and it didn't work.
Oh and hopefully they didn't reflash the computer. The do that with out permission and the newer flashes are not always good.
Good luck, and let us know what happens.
