Sonnax or bd-power line booster?? - Page 3 - Dodge Cummins Diesel Forum
post #25 of 62 (permalink) Old 04-16-2011, 11:44 AM
rjp
rjp's Avatar
Originally Posted by allenbr View Post
te, what year did the factory start using the anodized valve body in new trucks?
2010******************
rjp is offline
The Following User Says Thank You to rjp For This Useful Post:
allenbr (04-16-2011)
post #26 of 62 (permalink) Old 04-16-2011, 11:56 AM
rjp
rjp's Avatar
Originally Posted by TransEngineer View Post
On a 2007 truck, I would recommend replacing the valve body assy with a new Mopar part (to get an anodized VB).
The OD clutch is the normal "weak link", however I do not know of any upgrades you can do for it (I am unfamiliar with what might be available in the aftermarket - I only work on production components). The production OD clutch is a single-sided, 12-disc clutch pack. There is not physically room (inside the input clutch retainer) to fit more discs in. I suppose using a different OD friction material (with a higher coefficient of friction) would help, but then that could also lead to shift quality problems. As I said, I don't know whether anyone sells such an OD clutch or not.
The Suncoast OD clutch on the comp 68 is a new and improved billet unit that has been built to accept frictions that are substantially bigger than stock. This has made the over drive issue a thing of the past as it will now hold 1,800' + lbs of torque on a day to day basis. I personally don't see any other way that the 68rfe will ever hold big power in the over drive section of the tranny without this modification.
PS. Thanks again TA for your knowledge and input on this forum!
rjp is offline
post #27 of 62 (permalink) Old 04-17-2011, 10:17 AM Thread Starter
cwb42025's Avatar
Well been driving my truck and everything seems to be fine! Finally! I feel that I need to do something to beef up my tranny. No sure what I want to do but I'll keep everybody informed.
Thanks for all your help te!
'08 3500, 4x4, H&S, Southbend
'91 D250, 4x4
cwb42025 is offline
post #28 of 62 (permalink) Old 04-18-2011, 01:30 PM Thread Starter
cwb42025's Avatar
Well I'm still having the same problems! Been pullin around 5k today and trans is going into limp! Going to take it to the dealer this afternoon to see what's happening. It thru the p0700 again so idk what going on.
***Casey or Bentley could you please read this thread and chim in if you have any advise? I talked with Jim today in tech support today and have uninstalled Overdrive tune to make sure that's not the problem.
Thanks!
'91 D250, 4x4
cwb42025 is offline
post #29 of 62 (permalink) Old 04-18-2011, 01:51 PM
TECH SPECIALIST
I guess the dealer didn't "figure out" your problem very well.
Ask them to tell you specifically the exact fault codes that are set in your TCM. Also ask them to download and print for you the DTC Event Data associated with the most recent fault. They should have done that the last time you were in, since most of our diagnostic procedures call for reading and saving the DTC Event Data. But then, many dealer techs don't bother to read (or follow) the published diagnostics. They just guess at what they figure the problem might be, and throw some part(s) at it. If that doesn't fix it... well, they just make more money on the 2nd (and 3rd, etc.) repair attempts.
Sorry if I sound cynical, but I've seen too many techs who seem to be more motivated to replace parts than to actually track down the root cause of the problem. I recall one memorable case where a tech called in with a certain fault code. I asked him to drop the valve body and check the #2 check ball to see if it was cut or damaged. He called back a day or two later and said, "OK, I replaced the valve body. What do I do next?" He hadn't bothered to look at the check ball.
TransEngineer is online now
post #30 of 62 (permalink) Old 04-18-2011, 08:17 PM
rjp
rjp's Avatar
Originally Posted by cwb42025 View Post
You can see the mods I have in my sig.... At around 104,000 my torque converter started slipping so took it to the dealer and had it replaced. It's been two weeks and this one is slipping and making the trans over heat therefore going into limp mode. I'm not to the point of buying a good aftermarket torque converter so I thought about buying a line pressure booster. I've had the H&S overdrive software for about 15,000 miles now also. I wondered which booster is better.... Sonnax or BD-Power and can I use one of these with the overdrive software?
Thanks
Going back to the begining......... When you say its slipping,is it slipping when it gets to 5th as you try to gain speed? Are is it slipping in the lower gears?
rjp is offline
post #31 of 62 (permalink) Old 04-18-2011, 10:45 PM Thread Starter
cwb42025's Avatar
Stupid me didnt ask enough questions when the mechanic said it was slipping the first time. All i can remember is he said it was slipping by 200-300 lbs? im not sure this makes sence. He was very positive it was slipping but didnt give me codes or event data report to prove his theory.
I made it to the dealer this afternoon and got the codes and event date report from when it went into limp the last time today. I uninstalled my Overdrive software today before it went into limp so keep that in mind...
I tried to post my data from the dealer via pdf and it says ive exceeded my quota?? So any info you need to know on the event data sheet i have and could email to you te if you want?
'91 D250, 4x4
cwb42025 is offline
post #32 of 62 (permalink) Old 04-18-2011, 10:55 PM
rjp
rjp's Avatar
Thats probably 300rpms difference in the input and out put through the converter witch would be a problem. I believe 150 is the allowable number if i remember right. Trans engineer could definitely diagnose this with the info that you have. Other than that have you ever noticed it slipping in the over drive gears?
rjp is offline
post #33 of 62 (permalink) Old 04-18-2011, 11:11 PM Thread Starter
cwb42025's Avatar
I didn't notice it slipping at all actually or doing anything funny. I did notice after the new tc was put in there was a huge difference in acceleration speed.
'91 D250, 4x4
cwb42025 is offline
post #34 of 62 (permalink) Old 04-19-2011, 07:39 AM
TECH SPECIALIST
OK, so what codes did you have? In the DTC Event Data, what was the Line Pressure, and Desired Line Pressure? What was Current Gear, Target Gear, Last Shift, Engine Speed, Turbine Speed, and Output Speed?
post #35 of 62 (permalink) Old 04-19-2011, 07:58 AM Thread Starter
cwb42025's Avatar
Codes- p0700, p0871 OD pressure switch rationality, p0740 TCC out of range
Line pressure- 149.0
Desires line pressure- 150.0
Current/present gear- 2nd
Target gear- 2nd
Last shift- 1st to 2nd
Engine speed- 1935 rpm
Turbine speed- 1284 rpm
Output speed- 699 rpm
I'm you need anything else just let me know!!
Thanks!!
'91 D250, 4x4
cwb42025 is offline
post #36 of 62 (permalink) Old 04-19-2011, 08:30 AM
TECH SPECIALIST
Aha.... P0740 does indicate slippage in the converter (slipping TCC). But the P0871 is most likely caused (at your mileage) by the worn valve body (SSV) bore. Replace your valve body assy. Part number from Mopar is 68033980AB ($464 list). That should fix the P0871 fault, and may clear up the P0740 as well. If you still keep setting a P0740 (after replacing the VB), then you'll probably want to replace the converter and the pump assy. But do the easy thing first - new VB assy.
The P0871 fault COULD be caused by a wiring problem (bad connection in the OD pressure switch circuit), but it is far more likely to be caused by a worn valve body. You definitely need a new VB anyway at your mileage, so go ahead and replace it.
