07 dodge 2500 6.7 - Dodge Cummins Diesel Forum
post #1 of 3 (permalink) Old 08-13-2019, 10:07 PM Thread Starter
07 dodge 2500 6.7
Yesterday I was driving down the freeway at about 70 when all of a sudden my truck down shifted pretty hard twice and then died. All the dash lights stayed on and everything seems to still be working just fine as far as interior goes, but it doesnt even try to crank over. Also noticed the fuel pump and turbo do not try to cycle when I turn the key on so its seeming like theres no ACC power and it does not display what gear its in on the instrument cluster. Suggestions?
MoCamp13 is offline
post #2 of 3 (permalink) Old 08-14-2019, 02:08 PM
Babin Farms's Avatar
Have you checked battery conditions, cables and connections? Also check the multiple grounds on the truck to make sure they are all connected and clean.
2017 GMC 2500 6.0
SOLD - 2008 3500SRWCCLB 4x4 6.7 Cummins, G56 w/South Bend DD
Babin Farms is offline
post #3 of 3 (permalink) Old 08-14-2019, 06:44 PM Thread Starter
I have plugged into it and it's not showing any codes. I have also tried checking the wiring and plugs and such around and to the transmission and haven't found anything that looks like it could have caused it. I have checked the ground wires on the batteries, and they are good and completing the circuit. I read somewhere that the ignition switch going out can cause this and to try jostling the steering wheel around to see if it goes, and I tried that and nothing. When it first died on me, everything on the dash was in fact working still, and it wasn't until the day after that it quit showing me the gear positions on the instrument cluster, if that helps at all. If there's any other questions I can try to answer, I'd be happy to, just feel like I've told the story enough times now that I'm questioning what's relevant and what's not.
MoCamp13 is offline
