Best clutch replacement?! - Dodge Cummins Diesel Forum
post #1 of 10 (permalink) Old 08-06-2019, 02:52 AM Thread Starter
WY96SLT's Avatar
Slipping at/above 2200 rpm on 2008 6.8 g56. Also wonder if lower reverse gearing is possible. Doing some limited heavy hauling and the only spot I can see where I am riding the clutch is backing up the trailer(4 horse with living quarters) on incline. Clutch was "dealer replaced" at purchase approx 2 years/20,000 miles ago.
WY96SLT is offline
post #2 of 10 (permalink) Old 08-06-2019, 05:41 AM
Dodgetracker's Avatar
A lot have sworn by the Southbend DD3250.
2008 2500 HD 4x4 6.7 CTD 68RFE. 4:10 Gears. AFE Stage II W/PG7.
Pulling a 2007 Heartland Cyclone 3795
United States Army, Retired
Dodgetracker is offline
post #3 of 10 (permalink) Old 08-15-2019, 02:03 PM
evildiesel's Avatar
If you’re only doing a tuner for mods and like the driveability of your stock clutch go with the southbend 3250 full organic dual disk. I just installed this in my truck and its amazing. Feels like a firmer, more solid stock clutch. No more slipping. I was slipping pretty bad on the stock clutch. I’m at 510hp and 950 ft lbs of torque.
2006 Dodge Ram 2500 ST, RCLB, G56
AFE Intake - 4" Straight Flo-Pro Exhaust - EFILIVE - Southbend DD Clutch - CARLI - TGC 3.5" lift - 20x12 wheels - 35" AT2 Tires
evildiesel is offline
post #4 of 10 (permalink) Old 08-15-2019, 02:29 PM
the man in black's Avatar
Valiar DD organic is another strong contender. As for lower reverse, your options are find a different trans with a lower reverse, lower you axle gears or install a free spin hub kit and use 4lo without locking in the hubs->2lo.
Scooty Puff Sr - 2016 3500 CCLB
Truckasaurus - 2010 2500 CCSB -sold
the man in black is offline
post #5 of 10 (permalink) Old 08-15-2019, 03:20 PM
Babin Farms's Avatar
Valair and South Bend are the "Best" 2 out there for you application. Give them a call and I'm sure they will be able to give you all of the info that you need to make an informed decision and possible purchase for your rig.
https://www.cumminsforum.com/forum/valair-inc/
https://www.cumminsforum.com/forum/south-bend-clutch/
2017 GMC 2500 6.0
SOLD - 2008 3500SRWCCLB 4x4 6.7 Cummins, G56 w/South Bend DD
Riding the "Struggle Bus"
Babin Farms is offline
post #6 of 10 (permalink) Old 10-08-2019, 12:55 PM
kgkmav's Avatar
I am definitely going with the SB DD but i can't decide on full organic or the hybrid. I am in traffic every day and although i don't back a trailer a ton, i'm afraid it is going to be too jumpy of i go with the hybrid.
2012 2500 ST 4x4 CCSB, G56. 5" exhaust. Other parts missing
kgkmav is offline
post #7 of 10 (permalink) Old 10-08-2019, 01:21 PM
On call 24/7
98whitelightnin's Avatar
iTrader Score: 16 reviews
SB dd organic is smoother than the stock clutch it replaced. I had a dd ceramic a few years ago and hated the rough/jumpy engagement.
1998 12v, 4x4, Club Cab, Carli, Thuren, BlueTop, Core 4x4, BD Diesel, PDD 5x.012, South Bend
2012 Laramie Longhorn, EFI by Ryan, Carli, Thuren
1995 Dually, Weston's 5x.016, 4k GSK, 5" FloPro, 255/85r16 Toyo M/T, Goerend, ARP, 60# Springs, BW 62/65/14, BW 75/96/1.10, Isspro, Fass 125, BDP Sump, 7mm DV's, 751 HP 1883 FP Torque on NOS
1998 P-Pumped 24v, 4x4, NV4500 swap
98whitelightnin is online now
post #8 of 10 (permalink) Old 10-08-2019, 03:01 PM
Kmehr's Avatar
If you want to save some coin, the HD organic from south bend is awesome and still holds an impressive 425/900. I think rated to tow 25K too. I have one in mine and it feels just like the stock. I think they're about half the price of the dual discs.
1984 Dodge CCSB P-pump NV4500- SOLD
2005 QCSB NV5600, SouthBend OKHD, CFM+, Jake brake, Thuren 3in, Vulcan w/ CAT UHE 416-1225, CTS2, HPTuners by Optimal Welding, BBI stage 1, II bag of parts
Kmehr is offline
post #9 of 10 (permalink) Old 12-18-2019, 01:39 AM Thread Starter
WY96SLT's Avatar
Thank you!
WY96SLT is offline
post #10 of 10 (permalink) Old 12-18-2019, 01:55 AM
Funky Hunk's Avatar
I think the free-spin hub kit would be a good investment. I use "2-lo" a lot for backing my gooseneck trailer up a steep driveway.
89 F250 Fummins - 92 12v, ARP head studs, P7100 pump, AFC mods, 3k governor spring, 7mm DVs, Mack rack plug, 5x14s, performance LP, hx35, 4" custom exhaust, Valair clutch kit, Zf5 trans, Autometer gauges
Funky Hunk is offline
