Oil leak - Dodge Cummins Diesel Forum
post #1 of 5 (permalink) Old 05-13-2019, 02:59 PM Thread Starter
dave_in_az's Avatar
Oil leak
After I changed the oil in my 6.7, I found that there is a little engine oil dripping from the bottom of the AC compressor. Since the oil filter is above it, I figured the oil filter was loose. But there was no oil dripping from the bottom of the oil filter and I couldn't tighten it any more by hand. I did get it a little tighter with a strap wrench.
Is there something else in that area that I should look for?
Thanks
2008 Ram 3500 DRW Big Horn Crew Cab
6.7 Cummins w/6-Spd Auto
dave_in_az is offline
post #2 of 5 (permalink) Old 05-14-2019, 12:35 AM
s10010001's Avatar
Thanks
How much oil? Id clean it all out with degreaser and a hose, then see if you can get a better ID on the leak location in a day.
The old oil filter rubber gasket did stay on there, making it double stack with the new one did it?
2008 6.7 2500 4x4 Auto 3.73
2000 5.9 3500 4x4 Auto 4.10 (sold)
s10010001 is offline
post #3 of 5 (permalink) Old 05-14-2019, 11:54 AM Thread Starter
dave_in_az's Avatar
I doubled checked the oil filter. It's not leaking. Cleaned the area and went for a drive. The oil is definitely coming from the AC pump. Very thick, amber colored oil.
post #4 of 5 (permalink) Old 05-14-2019, 12:04 PM
s10010001's Avatar
Shaft seal leaking maybe?
post #5 of 5 (permalink) Old 05-14-2019, 12:36 PM Thread Starter
dave_in_az's Avatar
Could be. I don't know if that's something they can fix or if they just replace the entire compressor
Similar Threads
Ok to Idle 5.9 Cummins Without Damper? to Troubleshoot Oil Leak JenDodge 94-98 Powertrain 35 02-16-2017 12:33 PM
NV5600 Oil Leak, Any Other Ideas? krashDH 3rd Gen. Powertrain 0 11-04-2016 04:16 PM
Another oil leak... wheeltrax 98.5-02 Powertrain 8 03-30-2016 04:06 PM
Lucas Fuel Treatment and Fuel Leak atmechanical 94-98 Powertrain 4 05-03-2012 11:00 AM
Joe G's fuel system writeup ykdave 94-98 Engine 2 04-22-2008 09:13 AM
