hey all, have owned my truck for about 5 years. previous owner installed a raptorlift pump n big line kit. first off it always runs with key on any way to fix this? second. its plumed into the factory lift pump in the tank, any harm doing that?
My truck had the same pump as you do. It died in the first year of owning the truck though...
First tip is to look and see where the raptor pump is wired too. If it goes into the fuse box (TIPM) chances are it's ran into the factory fuse location and the factory pump isn't even wired up (if it's even still there.) In-which-case, it's working that little pump a little harder than it should be, but shouldn't be too much of an issue.
As for it being on the whole time the key is on..... I'm not sure what you mean by that. It's supposed to be running when the truck is running.
379.7K members
