Squeal around 30 PSI boost?? - Dodge Cummins Diesel Forum
post #1 of 7 (permalink) Old 04-13-2019, 12:44 PM Thread Starter
GTIgus's Avatar
Hi All, I've got a 2008 CTD Ram 3500 with about 95k miles. I've only had the truck for a month or so.
When I got the truck I replaced all fluids and filters right away, then installed a full delete kit and 4" exhaust with muffler and H&S Mini Maxx.
About 2 weeks ago we took it for a 350 mile road trip drive to see some family. On the way home I pulled onto the interstate from a rest stop and got on it pretty hard. Around 30PSI of boost, as indicted by the mini maxi, I heard a squealing kind of sound coming form the turbo area, so I backed off.
Now, every time I get around 30 PSI boost Io get the same noise. There's no power or running issues otherwise, just the noise at high boost. I've checked for leaks around the manifold and turn mounting, as well as tightened all my intercooler boots to no help. Any ideas? Thanks in advance!
GTIgus is offline
post #2 of 7 (permalink) Old 04-13-2019, 12:46 PM
gmbohuntr's Avatar
Did you check for splits in the boots?
Sent from my Pixel 2 using Tapatalk
"09 Mega Cab. AFE dry intake. 4" Flo-Pro TBE. EFI and TCM tuning by Dave Matthews of Draconian Diesel. GDP Big Line Kit. AFE DFS780 fuel pump and filter setup. 35x12.50x20 Mickey Thompson Mtz's on 20" Gear Alloy Big Bore's.
gmbohuntr is offline
post #3 of 7 (permalink) Old 04-13-2019, 12:47 PM Thread Starter
GTIgus's Avatar
Just visually, I haven't made a boost leak tester yet to pressurize the system. Do you think a split or hole would cause that symptom? Thanks!
GTIgus is offline
post #4 of 7 (permalink) Old 04-13-2019, 12:49 PM Thread Starter
GTIgus's Avatar
I have a video on youtube but the forum won't let me add it since I don't have enough posts... :-/
GTIgus is offline
post #5 of 7 (permalink) Old 04-13-2019, 01:45 PM
s10010001's Avatar
Just paste the link, we can click it just fine (or those of us that TapaTalk on mobile will see the video with just the link posted.
My 2000 had a squeal going around 38-42PSI, it was the horn boot, had a 1/2Ē crack forming coming from the clamp up.
It took forever to find it because it would not leak with my boost leak tester at 30psi, I didnít want to go higher. I found it visually when I pulled to horn off one day. Wasnít sure it was to source but when I replaced the boot it was gone.
2008 6.7 2500 4x4 Auto 3.73
2000 5.9 3500 4x4 Auto 4.10 (sold)
s10010001 is offline
post #6 of 7 (permalink) Old 04-13-2019, 03:16 PM
Supporting Vendors
Rhinopkc's Avatar
Boost leak. Had an 09 with a bad gasket at the intake horn to grid heater connection make a noise like that.
Give Us a Call for All Your Suspension, Lighting, and Wheel Needs!
424.241.3252 x700 [email protected]
Check Us Out On Facebook!
Check Our Forum For The Latest in LED and Thuren Products"
Rhinopkc is offline
post #7 of 7 (permalink) Old 04-14-2019, 08:09 AM
El Pozzinator's Avatar
Yep. My 08 did it at ~12psi when I got a boot crooked and hadnít fully snugged a clamp. Sounds kinda like a flat horn reverberating under the hood by the turbo.
Check your clamps, boots, and anything plastic between the turbo and intake.
Good luck!
08 Resistol. Anarchy EFI, 5" TBE, grid delete, fleabay elbow, Sinister coolant filter, Carbonite DP sensor, CSS -4" springs, reverse level, CalTracs, Amsoil bypass filter, Revmax VB/TCM, Mishimoto stock replacement radiator.
El Pozzinator is offline
Similar Threads
More H&S Tuning Data With EGTs, Boost and MPG NorCaler 4th Gen Performance Parts Discussion 268 07-31-2013 01:10 PM
edge juice an boost elbow? wolfdog 98.5-02 Performance Parts Discussion 7 02-11-2013 08:53 PM
Data- EGT, Boost, DP ArmRippinToys 4th Gen Performance Parts Discussion 27 02-10-2013 03:46 PM
Another Boost Fooler Question... I know OffshoreChris 3rd Gen. Performance Parts Discussion 11 01-16-2013 12:51 PM
bouncing/fluttering boost gauge & turbo bark under load help Richard LeBar 94-98 Performance Parts Discussion 14 02-06-2012 09:06 PM
