Vacuum Pump or slight misfire? - Dodge Cummins Diesel Forum
post #1 of 5 (permalink) Old 03-31-2019, 05:35 AM Thread Starter
Fanman43's Avatar
Question Vacuum Pump or slight misfire?
Hello, all!
Quick run through on what I'm experiencing... Hoping for some advice on this:
First:
I've always had some lag when switching HVAC controls from dash vents to defrost and what-not, i know this is normally a vacuum pump issue or blendoor. Never thought twice about, never really cared. Window is normally down in the summer anyways and it basically stays on Defrost in the winter. No problems there.
Second:
The truck has 240K miles on it now and still has factory original injectors. (Verified with last 2 owners )
Third:
Got into a pretty serious accident a some time ago and got it repainted and the whole shibang. When I got it back, come to find out, when they painted all the new fenders, fender supports, and coated the frame, they attached all the grounds to the new painted surfaces which didn't help my already corroded, old, weak battery cables and grounds. This made the truck have a hard time stay running, starting, and when it would run, it would run really rough and through all kinds of codes. A few weeks of diagnosing and help from you guys, I replaced all of the battery cables and grounds from Custombatterycables.com and it seems to have solved all my problems.
Now on to the problem - After I replaced all the cables and paid more attention to my RPM making sure it wasn't surging like it was when I was having electrical issues I noticed that it had this really really slight surge at idle both hot and cold idle. Voltage stays at 14V the whole time (unless the grid heater is cycling). It's just enough for me to notice even outside the truck.
According to my Edge Insight - It drops ~50 - 100 RPM every minute or so. Then, just to throw me off, it will spike ~50 - 100RPM. Which leads me to believe it's a slight misfire caused by a failing injector. They're old... So I wouldn't be surprised.
Here's the kicker: It only does it when I have the blower motor on. Doesn't matter where it's blowing, hot or cold, A/C on or off. But if I turn the fan completely off. It doesn't do it at all.
The truck runs great though. To be completely honest, it could have been this way for as long as I've owned it and only noticed it because I was paying super close attention to it, looking for any kind of symptom after replacing the battery cables and grounds.
No Blow-by, no voltage drops, no smoke. The only other thing I can possibly think of that would lead me to injectors is that my fuel mileage has dropped by about 1MPG in the last few months. Since I'm in Utah and we switched to winter diesel before I got the truck back and most fuel stations still haven't switched back to "Summer Diesel", I feel that will account for the decrease.
Thoughts? Suggestions?
I am known to over think things and be a worry-wart when it comes to this truck so there's that...
2007.5 DODGE RAM 3500 QCDRW - 6.7L CUMMINS FULL DELETE - H&S INTAKE HORN - AFE AIR INTAKE - ARP HEAD STUDS - EFI LIVE BY STARLITE DIESEL - FASS TITANIUM - BEANS DIESEL SUMP - STRAIGHT PIPED - G56 6 SPEED TRANS
Fanman43 is offline
post #2 of 5 (permalink) Old 04-01-2019, 02:28 AM
08 Cummins
KhakiCummins's Avatar
Your truck doesn't have a vacuum pump so you can rule that out. It could be the A/C compressor cycling on since you only notice it when the blower motor is on. Even if you don't have the A/C on, the compressor will still cycle when you are on any of the defrost setting.
Duane
2008 Ram 3500 QuadCab
KhakiCummins is offline
post #3 of 5 (permalink) Old 04-04-2019, 07:26 AM Thread Starter
Fanman43's Avatar
If there's no vacuum pump; does it have a hydroboost off the power steering? There is a hissing noise when turning or applying the brakes really hard.
Fanman43 is offline
post #4 of 5 (permalink) Old 04-04-2019, 01:31 PM
08 Cummins
Yes, your truck has a hydroboost brake booster.
Duane
post #5 of 5 (permalink) Old 04-08-2019, 09:24 PM
cerberusiam's Avatar
The HVAC vents are all electric motors, they get slow when they age and the vents are really crappy so they could be sticky and jamming and the controller could be getting bad. Unfortunately the only good fix in new doors, motors, and controller.
Change your fan motor and see if that makes a difference, it could be drawing too much and throwing garbage into the electrical system. Also check for any missed grounds on the firewall or under the dash and any accessories wired directly to the battery, that is a BIG no-no.
Could also be injectors lacking extra filtration, additives, and care selecting fuel. If they are suspect change them NOW, you do not want to the results if a tip comes off an injector are they are over fueling too much. Think windowed block, melted pistons, and general mayhem.
cerberusiam is offline
Similar Threads
VP44 Diagnostic for everyone. AmT-yd- 98.5-02 Performance Parts Discussion 26 07-27-2016 11:19 AM
vacuum pump reseal? wolfdog 94-98 Non-Powertrain 3 11-14-2013 08:39 PM
wont start 0251 code gearhead1 98.5-02 Powertrain 17 09-18-2013 09:08 AM
2004 ram 5.9 jpatrick 3rd Gen. Powertrain 1 08-16-2013 12:21 AM
Joe G's fuel system writeup ykdave 94-98 Engine 2 04-22-2008 09:13 AM
