Weird tick/knock - Dodge Cummins Diesel Forum
post #1 of 6 (permalink) Old 01-29-2019, 10:36 PM Thread Starter
Weird tick/knock
I have a 2007.5 6.7 with a g56 around 175k miles. I blew the hg got it fixed and around 250 miles later I got this weird tick that sounded like it was coming from the trans. Pulled it and the bushings between the south Bend dual disk were sitting in the bell housing. Replaced the whole clutch and the noise is still happening. Put the stethoscope on it and it sounds like itís motor related. Drained the oil and itís pretty metallic. Truck is also tuned and deleted.
Ceejeee is offline
post #2 of 6 (permalink) Old 02-05-2019, 10:06 PM Thread Starter
I tried to post a video but I donít have enough post but I can PM it . Really stumped on this. The truck idled for 10 minutes yesterday and the noise went away. Drove it about 4 miles and it came back slightly.
Thanks
Ceejeee is offline
post #3 of 6 (permalink) Old 02-05-2019, 10:56 PM
N of 60's Avatar
Looked metallic?
Oil from engine or trans?
Oil Analysis, start there if from engine.
2011,4wd LB/CC 2500 H&S Mini MCC by Tomeygun, BD protect 68rfe VB seperator plate enhanced stall triple disk TC, Super B 64.5/80/.91 3rd gen mani & inline EB, Arp 425s, Fass Titanium 95. Spare Mini in my closet.
High tech old school and finally lovin it.
N of 60 is offline
post #4 of 6 (permalink) Old 02-05-2019, 11:45 PM
iTrader Score: 15 reviews
check the the fuel injection lines that run from the common rail to each injector...if the clamps loosen up then the line ticks/knocks against the clamp with every injection pulse...it kinda sounds like a sticking valve. While the clamp were upgraded on the newer trucks, they can still loosen over time.
2005 SLT 4x4 QC LB G56, GDP horn, HDCAI, SBC ConOFE,
seafish is offline
The Following User Says Thank You to seafish For This Useful Post:
Ceejeee (02-06-2019)
post #5 of 6 (permalink) Old 02-06-2019, 08:57 AM Thread Starter
Originally Posted by N of 60 View Post
Looked metallic?
I sent you a video of the noise.
Ceejeee is offline
post #6 of 6 (permalink) Old 04-29-2019, 02:52 PM
Did you find out what the problem was? Having same issue but only at running temp and at idle.
Ziggyj6.7 is offline
Similar Threads
68RFE acting weird wert842 4th Gen Powertrain 6 10-10-2018 08:01 PM
Weird smell Mar25 98.5-02 Powertrain 3 07-16-2015 08:26 AM
10 inch lift with weird vibration over 65mph please help!!!! xtremekustomz 4wd Suspension 45 01-14-2015 06:56 AM
Weird heated seat failure - bottoms only? frobozz 2013-2018 General Discussion 1 11-25-2013 11:59 AM
Help!!! exhaust brake not working and weird sound IMThatGuy 07.5 - 09 3rd Gen 6.7L Powertrain 2 03-28-2013 07:26 AM
