P1011 & p0087 - Dodge Cummins Diesel Forum
post #1 of 5 (permalink) Old 09-04-2018, 10:28 PM Thread Starter
Bclintock's Avatar
P1011 & p0087
I’ve been getting these codes for years, I don’t always get the 0087 code. They occur when I’m pulling my loaded trailer, and under lots of stress(uphill, windy Ext..) I have ad165 lift pump, fuel rail plugged, egr, and dpf delete. Running H&S tow tune. She never misses a beat when the cel is illuminated, just really aggravating. The plug seems to have slowed the frequency of this issue, but I’d love to figure it out and fix for good.
Any advice would be great!
Thanks in advance
07 6.7 White 4dr 4wd drw 6spd, Valair DD, H&S tune, AD|| 165 lift pump,H&S EGR DPF delete
2018 pearl 4dr 4wd drw aisin (bone stock for now)
Bclintock is offline
post #2 of 5 (permalink) Old 09-05-2018, 10:37 AM
El Pozzinator's Avatar
Check torque on the rail plug. Another guy on here basically gutted his whole fuel system only to discover it was just a loose pressure relief valve. Truck was acting like a tank venting issue, recurrent low rail pressure codes.
08 Resistol. Anarchy EFI, 5" TBE, Sinister coolant filter, Carbonite DP sensor, CSS -4" springs, reverse level, CalTracs, Amsoil bypass filter, Revmax VB/TCM, & a madly leaking radiator.
El Pozzinator is offline
post #3 of 5 (permalink) Old 09-05-2018, 10:51 AM Thread Starter
Bclintock's Avatar
I will recheck torque, maybe I should also replace the oring, although it looked good.
And thanks for your Military Service!!
post #4 of 5 (permalink) Old 04-13-2019, 04:07 PM Thread Starter
Bclintock's Avatar
I still have these codes coming up, only when loaded and pulling hard. The rail plug is tight. Anybody dealt with this issue? 530k miles on it. Original stock injectors and cp3. Any suggestions on how to diagnose it? I don’t have gauges, so I’m not sure what my supply or rail pressures are when it happens.
Any thoughts?
post #5 of 5 (permalink) Old 04-13-2019, 11:12 PM
xcc_rider's Avatar
My guess would be excessive injector return rates or cp3 but it's only a guess without rail and supply pressure readings.
By it's own right, 530k miles is awesome!!
2007.5 Black Ram 2500 MC SLT 6.7, 2wd, 68rfe, 3.73 diff
Edge CTS, SmartyJr tuned, PML xtra deep trans pan and 2 add on fuel filters
(delete parts are no longer in the garage)
xcc_rider is offline
