Max tow weight on gear ratio - Dodge Cummins Diesel Forum
post #1 of 4 (permalink) Old 05-04-2014, 10:46 PM Thread Starter
Looking for the difference between the 3.42 and 3.73 max towing capacity?
yamahakid is offline
post #2 of 4 (permalink) Old 05-05-2014, 08:59 AM
Jim W's Avatar
What year and what transmission; also is it a diesel or gas engine and is the truck a 3500 or 3500 SRW or DRW?
For example a 2008, 2500 Mega Cab with an auto only offers a 3:73 and 4:10 the 3:42 is only offered in a manual transmission. This is per the Ram Body Builders Guide which I have included for your reference.
http://www.rambodybuilder.com/year.pdf
Jim W.
2008 3/4T, Mega Cab SLT, 6.7L CTD 68RFE,Optix Gauges Pyro, Boost, Trans Temp A Piller mount, Mag-Hytec Trans Pan, Front & Rear Diff cover,Smarty, MBRP Exhaust, Silver, Westin Side Steps, Line-X Bed Liner, Bed Cover, Prodigy BC, 15K Reese hitch and pulling a 11K 5er
Jim W is offline
post #3 of 4 (permalink) Old 05-05-2014, 11:36 AM Thread Starter
It's a 07.5 2500 quad cad 2 wheel dr with 6.7L and a 6 sp manual tran
post #4 of 4 (permalink) Old 05-06-2014, 02:58 PM
Jim W's Avatar
Per the Ram Body Builder's website Ram only offered the 3:73 gear set with the manual transmission for that year. The max towing weight would be around 13,100 LBS+/- 300 LBS depending on trim level and if it is a LB/SB truck.
Jim W.
Jim W is offline
