68rfe to g56 swap - Dodge Cummins Diesel Forum
post #1 of 14 (permalink) Old 05-04-2014, 07:56 PM Thread Starter
68rfe to g56 swap
I am looking to swap my 68rfe for a g56. Anyone have a lead on the parts to do so? Thanks
Mhockenberry is offline
post #2 of 14 (permalink) Old 05-04-2014, 09:08 PM
jaslater's Avatar
use the search function there is an entire thread on how do to this and parts needed and roughly the cost.
09 3500 Laramie Megacab- Carli 6'' Pintop - Carli Ball Joints/Sway Bar/ Full Rear Leaves -Trussed Front Axle - NADP Built 68RFE - BD Flex Plate - Second gen swap s464 - H+S Mini w/ MCC OD - 5'' Flo Pro - ARP 425's - Snow Stage III - Fass 150 - Ironcross - Mag Hytec
jaslater is offline
post #3 of 14 (permalink) Old 05-04-2014, 10:03 PM
El Pozzinator's Avatar
i'd also hit up the 3rd and 4th gen classifieds; i think i saw a thread in one of them titled "my place looks like a cummins graveyard" or something like that. might be worth looking into folks parting out trucks; not many folks end up interested in TCM wiring harnesses and stuff like that.
08 Resistol. Anarchy EFI, 5" TBE, Sinister coolant filter, Carbonite DP sensor, CSS -4" springs, reverse level, CalTracs, Amsoil bypass filter, Revmax VB/TCM, & a madly leaking radiator.
El Pozzinator is offline
post #4 of 14 (permalink) Old 05-04-2014, 11:22 PM Thread Starter
Ya I'll look into it thanks
post #5 of 14 (permalink) Old 05-05-2014, 09:20 AM
JHG
I used Car-Part.com--Used Auto Parts Market and was able to find a G56 listed that was 30 miles from my house. When I went to talk to them about it, they had about six G56 trucks they were parting out and ended up selling me the trans at a "kit" price which pretty much meant I got everything I needed for the manual, including the interior parts off the donor trucks without having to pay for each piece seperatly.
2015 3500 Laramie, CCSB, SRW, Aisin, Thuren Coils, Raceline 20x9 +18, Toyo MT's 315/60/20
2007.5 6.7 QCSB, 5" TBE, H&S MM, G56 Swap, 35's and 3.73's.
JHG is offline
post #6 of 14 (permalink) Old 05-05-2014, 10:04 AM Thread Starter
Ya I thought about just going that route instead of buying everything separate
post #7 of 14 (permalink) Old 05-05-2014, 10:41 AM
JHG
I'm not sure how much money it saved but it did save a ton of time, I picked up the trans and then loaded all the other parts I could think of in the truck at one time. I only took me two hours to collect all the parts I needed for the swap and the only thing I waited for was my clutch to be shipped from Valair. Clutch, driveshafts(one had to be lengthened, I replaced the other), trans and all parts needed to put it in was about 4500 once I was finished. I didn't spend a ton of time shopping for the best deal on everything, I just needed it done an had a pretty small window to make it happen. I'm sure you could do better if you take your time and wait for deals.
JHG is offline
post #8 of 14 (permalink) Old 05-05-2014, 12:26 PM Thread Starter
You spent 4500$ is that with the clutch and drive shafts?
post #9 of 14 (permalink) Old 05-05-2014, 01:39 PM
JHG
Yeah, thats with everything.
$2600-Trans 30K miles w/ no core- including crossmember, shifter, upper and lower boots, shift knob, full pedal assembly w/ gas, clutch and brake pedal, Slave Cylinder w/ braket and cutch saftey switch, interior pieces(cup holder, trim, etc.).
$300- driveshafts, one lenghtened and one from junk yard. Junkyard offered to just trade with me but for some reason I didn't. That would have saved $150.
$1400- Valair double disk organtic "quiet" clutch.
H&S reprogrammed the truck for free
add $200 in taxes and its about $4500. There were some other little things, I think I had about $100 in Mobil Delvac 50, I picked up a rear main but didn't need it so I took that back. I distroyed the bolts holding the front driveshaft and dodge got me for $40 for those. I picked up a cheap transmission jack from harbor freight for like $60 that was good enough for what I needed but i wouldn't try it without a trans jack of some kind.
JHG is offline
post #10 of 14 (permalink) Old 05-05-2014, 02:35 PM Thread Starter
Did u change the wiring harness?
post #11 of 14 (permalink) Old 05-05-2014, 03:23 PM
JHG
I didn't, I built one for the reverse lights, wired the safety switch to the P/N wire and I haven't really even started messing with the 4 low. After the swap I was pretty much over truck projects so that one is on hold for awhile. I never use 4 lo so I'm not real concerned, I might have used it once in the last 5 years I've owned the truck.
JHG is offline
post #12 of 14 (permalink) Old 05-06-2014, 10:36 AM Thread Starter
I figured out what I'm gonna have in my swap.
$100 for shift boots and interior$100 for cross member
$275 for front drive shaft
$100 for rear drive shaft
$2250 for g56. 109000 miles.
$ 1041 dd clutch
Anything else you can think I would need.
