What is The Differance in Head Studs??? - Dodge Cummins Diesel Forum
post #1 of 53 (permalink) Old 06-02-2011, 11:14 PM Thread Starter
99Ls1fever's Avatar
I am in the need of getting some head studs and it is a must for the future with my twins build. So, I have been looking around and have come to notice there is 2 different head studs that are offered for the 6.7?
What is the differance in the two? here are the links to the two different one. There is a $600 price differance in the two.
ARP New Age 625 Dodge 6.7L CR Cummins Cylinder Head Stud Kit from Automotive Racing Products
[247-4204] $1,159.00
Cummins 625 Head Studs ARP 247-4204
ARP 12MM 07.5-2010 6.7L 24V Cummins Cylinder Head Stud Kit from Automotive Racing Products
[ARP-247-4202] $455.17
6.7L Cummins Head Studs ARP 247-4202
The 625 head studs say on the website 625 plus? does that mean 625hp or more???
08'- Smarty TNT | AFE Mega Cannon| TB 5'' | [email protected]
Built By PRT Diesel
99Ls1fever is offline
post #2 of 53 (permalink) Old 06-03-2011, 01:13 AM
soosb21's Avatar
i don't know about horse power lots of people running over 625hp on the arp 425's. the 625's to install u have to bore out the hole if I'm correct
2011 MEGA SRW FLEECE CHEETAH VGT ATS STAGE 4 7500 PLUS GDP TORKER 125HP MEGA FLO S3 Tuned By TOMEYGUN
soosb21 is offline
post #3 of 53 (permalink) Old 06-03-2011, 04:48 AM
SRT6.7's Avatar
iTrader Score: 4 reviews
The difference is the tensile strength and corrosion resistance. You do sadly want the 1k 625 bolts. The 425 will only do the job for so long and then give out specially with twins.. But you can find the studs for 950 at a few shops from the forum here..
The 625 can be torqued down way harder the the 425.
Sent from my VZ iPhone 4 using
Autoguide
TOY=07.5 SRT6.7 full build With BD Diesel Triple 74mm's many many pesos invested
--2015 sublime challenger HELLCAT manual
--06 2500 4x4 - caged race ready project truck no motor no Trans for sale 9k
SRT6.7 is offline
The Following User Says Thank You to SRT6.7 For This Useful Post:
99Ls1fever (06-03-2011)
post #4 of 53 (permalink) Old 06-03-2011, 04:49 AM
SRT6.7's Avatar
Oh also the holes don't need to be bored out for the studs unless you specify you want to do so..
Autoguide
SRT6.7 is offline
soosb21 (06-03-2011)
post #5 of 53 (permalink) Old 06-03-2011, 08:40 AM
625's all the way! Do it once and do it right the first time. You and your cylinder head will thank you later on when you decide you want throw some crazy bolt-ons at the truck. RSD has a better price on the 625's as well. James is great to deal with!
1998.5-2011 Dodge 5.9/6.7L ARP Custom 625 Headstuds
2010 2500 68RFE-6" Pro Comp lift, 18" XD Badlands, Toyo M/T 35s, 6000k HIDs, MiniMaxx w/ OD, 5" TBE, AFE MC intake, ARP 625s, GDP Street-Gate - SOLD FOR A SUPERCHARGED TUNDRA
savageclark is offline
The Following User Says Thank You to savageclark For This Useful Post:
post #6 of 53 (permalink) Old 06-03-2011, 10:37 AM Thread Starter
99Ls1fever's Avatar
Dam, Awesome info guys! Well that sucks that they are a grand. But, I guess you have to pay to play!
Built By PRT Diesel
post #7 of 53 (permalink) Old 06-04-2011, 03:51 PM
Villa Style's Avatar
The 425's you can say are about 10% better than stock and the 625's are i think 40% better as far as holding strength. The only thing that needs to be done is run a bottom tap to clean the threads real good.
The Old : 07' 6.7 Mega, EFI
The Sold: 12' Mega, EFI, Carli
The Bold: 16' Mega, EFI
Villa Style is offline
The Following User Says Thank You to Villa Style For This Useful Post:
99Ls1fever (06-05-2011)
post #8 of 53 (permalink) Old 06-04-2011, 06:34 PM
operator62's Avatar
Don't forget about the H-11 studs from A1. They are less than the 625s, but more than 425s. If you want even more clamping force you can also order the H-11s in 14mm which does require drilling out the block and retapping. Normally they are 12mm studs though, and for most of us it will be more than enough. One of the most important things is making sure your head and block are flat.
Double stacked stacking stack stackers, beautiful tow mirrors.
operator62 is offline
post #9 of 53 (permalink) Old 06-04-2011, 08:05 PM
Mr. Vehicle Destroyer
Shibbyutman's Avatar
iTrader Score: 7 reviews
Its not so much of boring out as bottom tapping.
With the factory head bolts they use a pretty long lead angle tap when hitting the block on initial machining. This means that there are several (4-5) threads at the bottom of the hole that aren't fully cut.
When you put in 625's, to take full advantage of their strength you should bottom tap every hole. Using a bottom tap on each hole will pretty much cut every thread fully right up until about the very last thread, which even the stud isn't going to have a full thread on.
Just FYI.
Back in the common snail game. 03 SO 2wd 530,000 miles and counting.
11 3500 Laramie DRW 2wd deep forest green pearl
Shibbyutman is offline
The Following User Says Thank You to Shibbyutman For This Useful Post:
Sandman76 (06-05-2011)
post #10 of 53 (permalink) Old 06-05-2011, 03:25 PM Thread Starter
99Ls1fever's Avatar
Thats Some good info Thanks Man
I have never even looked in to these head studs before, where did you get your at?
Just FYI.
Wow there is a little more to this than I was expecting!
Built By PRT Diesel
post #11 of 53 (permalink) Old 06-05-2011, 10:12 PM
WouldRatherbeCummin's Avatar
Just FYI.
man that would be a to tap out all them holes espically the ones in the back!!
2012 Mega cab 2500 4x4 Limited
H&S ARP FASS FUEL NITTO DDM TUNING CARLI PURE PERFORMANCE AMP STEPS AUTO METER
WouldRatherbeCummin is offline
post #12 of 53 (permalink) Old 06-05-2011, 10:56 PM Thread Starter
99Ls1fever's Avatar
What is the rating on the H-11 head studs? and where can you get them at? I have been just looking around for them to read up on, but have had trouble finding them on websites.
Just was curious, cause it looks like a few people on here are running them.
Built By PRT Diesel
