Air dog fuel pump - Dodge Cummins Diesel Forum
post #1 of 3 (permalink) Old 07-23-2019, 07:58 PM Thread Starter
Air dog fuel pump
Was wondering if you can run your fuel line through the factory fuel filter just for having a little extra filtration? All the install videos I have seen say to run it directly to the cp3
Richard35 is offline
post #2 of 3 (permalink) Old 07-24-2019, 01:13 PM
jakeorders's Avatar
Yes you can, but there's some here including myself that kept the factory setup with and capped the factory filter for back up. Then install the pump utilizing a sump connected directly to the CP3. There's also some claims that it restrict the flow, but as far as i know the micron on the factory filter is larger than the aftermarket pumps, the only advantage that i can think of connecting to the factory filter is the heater, for some its necessary and others dont. But most aftermarket pump do have that ability to heat up the fuel anyway. Goodluck!
2008 Ram 2500 6.7L Laramie Fully Deleted,Ananchy EFI Live(CSP5) and TCM Tune,5" MBRP,Edge CTS,Carli (BJ,TB,CA,SB and Tune Fox Shocks),FS Airbags,AFE Trans/Diff covers,S&B CAI w/Scoop,Fass 150,Beans Sump,Fleece CBP,ARP 425,Bosch 65hp,Amsoil OBP,AMP Research,Redhead Box,GDP Pro WG,Banks IC/AH,Tater 63/67,BD Exh Man,
jakeorders is offline
post #3 of 3 (permalink) Old 07-25-2019, 11:39 AM
Cacciatore's Avatar
If you look at the size of the factory lines and the size of AD hose, you'll quickly see the restriction. Your sig isn't complete, but if you have a modified fuel system that's going to need more fuel than stock, I would go straight to your CP3
2011 2500 CCSB|Carli|5 blade 72mm|S&S 150%|S&S 12mm|Wilson Patterson 48RE|Freedom Racing Engines 6.8|CTT
2013 3500 MCSB |Carli Backcountry|Baja Designs|Stainless s465|RevMax ZeroFlex|L19|CTT
Cacciatore is offline
