Ebay EGR delete vs Sinister - Page 3 - Dodge Cummins Diesel Forum
 5Likes
post #25 of 29 (permalink) Old 05-15-2019, 01:47 PM
What Tuner are you planning to go with and where do you think is the best deal on it? I've been looking at MiniMax.
KTMGuru is offline
post #26 of 29 (permalink) Old 05-15-2019, 10:14 PM Thread Starter
LastRideOut's Avatar
I'm going with EFILive AutoCal from PPEI- a single 30+ HP tune. I've heard that Kory Willis does good work. As far as a cheap option, outside of a box tune, I haven't been able to find any sub-$500 options.
Besides, a tune isn't an area where I want to go cheap on. I'm willing to spend good $$$ on a custom tune.
s10010001 likes this.
LastRideOut is online now
post #27 of 29 (permalink) Old Yesterday, 10:51 PM Thread Starter
Well I finished the DPF delete pipe installation. It was a bit of a pain to get the DPF pipe inserted into the muffler extension pipe cause it was a tight fit. But it is in now. While I was at it, I drained all the oil, removed the oil filter, and replaced the CCV filter. I'll be putting the new oil filter on tomorow, and filling it up with the new T6 Rotella oil.
I got the air intake horn off. I ordered the 3.5" pusher horn from ebay. It's fairly obvious that the black MAP sensor connector will be transferred over to the new pusher intake. But what about the glass-like probe that was bolted onto the stock horn? I unbolted it and took it out, it looks like a small thin pencil-like probe. What does this do? I don't see a place for it on the new pusher horn.
Pics. Can't believe the local shop wanted $200 for the CCV filter plus $100 labor for replacing it. It was a ten minute job for me. WOW.
And this is the pencil-like probe I was talking about.
Edit: It looks like I can just disconnect the pencil-like probe since it connects to a connector that can be disconnected.
Zacedward likes this.
post #28 of 29 (permalink) Old Today, 07:38 AM
El Pozzinator's Avatar
Thatís a pyrometer for the EGR. It can indeed be disconnected. When your delete tuning gets loaded, thatís one of the inputs the ECM will no longer be paying attention to.
08 Resistol. Anarchy EFI, 5" TBE, Sinister coolant filter, Carbonite DP sensor, CSS -4" springs, reverse level, Amsoil bypass filter, Revmax VB / TCM, & a pile of boxes in the garage...
El Pozzinator is offline
post #29 of 29 (permalink) Old Today, 05:22 PM Thread Starter
Thanks El Pozz. I went ahead and disconnected it. Took me 20 minutes as the connectors were stuck together (I know about the red safety clips). After wiggling for a good 20 minutes, I finally got them apart.
I went ahead and cleaned the grid heater. I used acetone in combination with a wire brush. It was not that caked up, not as bad as some of the pictures that have been posted here. Still, I went ahead and cleaned it all up. I used a shop vac to vaccum up loose soot. I tried my best not to get soot into the intake, but if we are being completely honest here, any soot that fell into the intake is no worse than what has been put into the engine for the previous 107k miles with the EGR garbage on.
Pics below.
Similar Threads
Newbie guide to Cummins stewbuntu 2010-2012 General Discussion 17 09-13-2018 09:30 AM
Sinister EGR delete fitting , just started leaking FordorDodge 2010-2012 General Discussion 6 03-12-2015 03:30 PM
Sinister egr delete bolt broke fireturk51 4th Gen Performance Parts Discussion 11 01-19-2015 08:04 PM
Sinister EGR delete & S&B CAI Gunner_herman 4th Gen Performance Parts Discussion 3 06-28-2014 10:49 AM
EGR Delete Kit - Sinister vs. the rest? NSM 4th Gen Performance Parts Discussion 20 02-07-2014 12:13 PM
