EGR Delete / Tuner - Dodge Cummins Diesel Forum
post #1 of 8 (permalink) Old 04-22-2019, 09:39 PM Thread Starter
LastRideOut's Avatar
EGR Delete / Tuner
I recently started the EGR cleaning service with the kit from Geno's garage. New CCV, gaskets, all that.
I'm halfway through the project. The EGR cooler, servo, and iron butterfly are all off. I was planning to re-install everything but now that my state is ending emissions testing and does not require testing for all diesels 2007 and up, I've decided to do the EGR delete since most of the work is done. Woo hoo!
HOWEVER, an article over at Carbonite Cummins says that disconnection of the egr cooler/servo WILL throw my truck in limp mode. http://www.carbonitecummins.com/Docu...R%20Delete.pdf So, it looks like I need a tuner if I want to be able to drive my truck. I was planning to drive around with the CEL on for a while, but a tuner now looks necessary.
I'm perfectly content with stock horsepower. What tuner will get the job done? If it matters, I'm leaving the DPF on. I just want a EGR delete tune.
LastRideOut is offline
post #2 of 8 (permalink) Old 04-22-2019, 09:51 PM
N of 60's Avatar
Maybe tell us what year your truck is? If yours is a third gen, or a 2010 you will get away with just a CEL for having the EGR unplugged.
You will need custom tuning if you leave the DPF in place and want EGR ignored without a CEL
2011,4wd LB/CC 2500 H&S Mini MCC by Tomeygun, BD protect 68rfe VB seperator plate enhanced stall triple disk TC, Super B 64.5/80/.91 3rd gen mani & inline EB, Arp 425s, Fass Titanium 95. Spare Mini in my closet.High tech old school and finally lovin it.
N of 60 is offline
post #3 of 8 (permalink) Old 04-22-2019, 10:09 PM Thread Starter
Oops. 2008 Dodge Ram 2500 megacab 6.7L.
The EGR cooler and servo have been removed. I put the EGR valve back on after cleaning, but will obviously take it off when I put the EGR delete kit on.
The article I linked to says the truck will go into limp mode without the EGR cooler/servo, which is why I asked advice for what tuners to get.
post #4 of 8 (permalink) Old 04-24-2019, 03:50 PM
xcc_rider's Avatar
I can't attest to the cooler servo/limp mode part as I've not tried it. BUT you're going to pay out the nose for a custom tune that will delete/disable the egr system alone.
Then when you decide to delete you'll have to pay for another custom tune to do the full deletes.
The simplest and cheapest thing you can do is to fabricate a thin block off plate (steel preferably) to go between the egr cooler and exhaust manifold, reinstall the cooler and plug in the servo.
No egr gas flow and no limp mode.
You can then remove the egr valve and install that block off plate and run as long as you like until you delete.
The choice of tuners and/or custom tuning at that time will depend on what you want out of the tune.
2007.5 Black Ram 2500 MC SLT 6.7, 2wd, 68rfe, 3.73 diff
Edge CTS, SmartyJr tuned, PML xtra deep trans pan and 2 add on fuel filters
(delete parts are no longer in the garage)
xcc_rider is offline
post #5 of 8 (permalink) Old 04-24-2019, 03:58 PM
xcc_rider's Avatar
Yah I know, I didn't answer your question either.
To delete just the egr system and continue using the exhaust system will require customers tuning.
You can look into EFI and/or MM3 custom tuning for that
You could try sourcing an old H&S tuner. I cant remember which model does it but one of them allows you to delete the egr system or the exhaust system or both.
H&S tuners are no longer supported so it's not the route I'd recommend.
post #6 of 8 (permalink) Old 05-26-2019, 02:48 PM
Company Name
cumminsdieselfreak's Avatar
I recommend the MM3 from DRD. It's not cheap but customer service/tuning is second to none IMO.
2018 Ram 2500 4x4 G56
Romans 10:13
See what we are up to on:
FACEBOOK
INSTAGRAM
Or Email me at:
[email protected]mance.com
cumminsdieselfreak is offline
post #7 of 8 (permalink) Old 05-26-2019, 09:33 PM Thread Starter
I already bought a tuner from PPEI. It will be here Tuesday. I ended up deleting the DPF along with the EGR. :-)
post #8 of 8 (permalink) Old 05-26-2019, 09:49 PM
N of 60's Avatar
Enjoy and be nice to your transmission.
N of 60 is offline
Similar Threads
EGR delete with tuner chorstman1 2010-2012 General Discussion 7 12-14-2016 09:51 PM
EGR Delete Without a Tuner? Cummins 6.7 Pissndiesel 4th Gen Performance Parts Discussion 2 11-04-2016 07:06 AM
egr and dpf delete with tuner ricardo nez 07.5 - 09 3rd Gen 6.7 Liter General Discussion 7 11-28-2015 08:14 PM
IT'S ALIVE (Tuner, CAI, EGR delete and 5 in TBE) kefier2001 2010-2012 General Discussion 13 02-26-2015 11:15 PM
EGR delete requires tuner? tuner requires DPF delete? CTSUSMC 07.5 - 09 3rd Gen 6.7L Powertrain 7 10-10-2013 09:27 PM
