Pitman Arm play - Dodge Cummins Diesel Forum
07.5 - 09 3rd Gen 6.7L Non-Powertrain Discussion of Accessories, Interior, everything not power related...NO ADVERTISING
post #1 of 8 (permalink) Old 08-15-2019, 12:07 AM Thread Starter
zacksnipstead's Avatar
Pitman Arm play
Hey guys I’m in the middle of doing ball joints and control arms on my 07.5 6.7 3500 and I happened to bump my head on pitman and it moved about 3/4 an inch. Now I should mention I’ve had incredibly loose steering since I bought the truck a year ago and finally started looking into it. Everything else loose has been fixed, would could the loose pitman be?
zacksnipstead is offline
post #2 of 8 (permalink) Old 08-15-2019, 12:56 AM
evildiesel's Avatar
Probably didn’t tighten the pitman arm up tight enough. Whether it be you or someone else that touched it last. The pitman arm is on a spline shaft that is also tapered like a tie rod end. It’s gotta be very tight.
2006 Dodge Ram 2500 ST, RCLB, G56
AFE Intake - 4" Straight Flo-Pro Exhaust - EFILIVE - Southbend DD Clutch - CARLI - TGC 3.5" lift - 20x12 wheels - 35" AT2 Tires
evildiesel is offline
post #3 of 8 (permalink) Old 08-15-2019, 09:10 AM Thread Starter
Ok I’ll try that after work
post #4 of 8 (permalink) Old 08-15-2019, 09:16 PM Thread Starter
So update I pulled the steering box brace out and am trying to tighten the nut but it won’t budge. Here’s a pic of the arm.
post #5 of 8 (permalink) Old 08-15-2019, 10:36 PM
TWR
TWR's Avatar
hi if it has been loose for awhile you should remove it and check the splines of the pitman arm and the sector shaft, i would say their will be damage on one or the other. As for nut torque its over 200ft. pounds
2003 Ram 3500 6 inch lift, 2016 Laramie Limited seats and 2012 console with [email protected] Shifter, Fass 95 pump, Built 47re and mishimoto trans cooler, Srt10 hood, Smarty touch.
TWR is offline
post #6 of 8 (permalink) Old 08-15-2019, 10:52 PM Thread Starter
Ok I know I can replace the pitman Arm if it’s damaged but can I replace the sector shaft or is that gonna be a new gearbox?
post #7 of 8 (permalink) Old 08-17-2019, 05:49 PM
ordo ab chao
Motorolanut's Avatar
Originally Posted by zacksnipstead View Post
Ok I know I can replace the pitman Arm if itís damaged but can I replace the sector shaft or is that gonna be a new gearbox?
New gearbox time. And replace the brace when done. I believe redhead makes a box.
Motorolanut is offline
post #8 of 8 (permalink) Old 08-17-2019, 07:29 PM
TWR
TWR's Avatar
Hi just clean the spines on the sector shaft with a wire brush and look very close at them, you will see if they have any damage. It's likely easier for you to change the steering box if the splines have damage. I had to fix a buds Truck that the steering box brace nut diameter was not big enough to push up on the pitman arm hard enough on to taper and it would rock, so I got a new pitman arm and I made a new nut and put it back together its been fine for a few years now. That nut in his kit was only about 1/8 bigger than the spline hole and over time it started to rock on the sector shaft, the sector shaft was fine. How much bigger is the nut in your kit compared to the splines hole? That nut should be about a 1/4 inch bigger on each side than the hole so it can push the pitman arm up the shaft far enough and also retain it.
TWR is offline
