3” vs 6” lift - Dodge Cummins Diesel Forum
07.5 - 09 3rd Gen 6.7L Non-Powertrain Discussion of Accessories, Interior, everything not power related...NO ADVERTISING
 4Likes
  • 1 Post By avvblanc01
  • 1 Post By s10010001
  • 1 Post By ritchie1087
  • 1 Post By Rhinopkc
post #1 of 12 (permalink) Old 03-09-2019, 06:28 PM Thread Starter
3” vs 6” lift
Looking into getting a lift for my 07 6.7 mega cab dually. Looking into the carli with a 3” but I’m already leveled and run 35’s not sure if the 3” is going to make it look much Different? Also as a pipeline welder my truck spends more time off road on a row and rough back roads then it does on a main highway so the upgraded ride is much needed and more clearance on my welding bed is needed. Other than wondering if a 3” will make it look much different I’m also wondering if I’d need to jump up to 37’s on the tire to make it look right? Any help is appreciated in advance
Megaslab07 is offline
post #2 of 12 (permalink) Old 03-09-2019, 07:59 PM
Clayton @ Dude's Diesel Performance
Dude_57's Avatar
Originally Posted by Megaslab07 View Post
Looking into getting a lift for my 07 6.7 mega cab dually. Looking into the carli with a 3 but Im already leveled and run 35s not sure if the 3 is going to make it look much Different? Also as a pipeline welder my truck spends more time off road on a row and rough back roads then it does on a main highway so the upgraded ride is much needed and more clearance on my welding bed is needed. Other than wondering if a 3 will make it look much different Im also wondering if Id need to jump up to 37s on the tire to make it look right? Any help is appreciated in advance
Hey bud, glad to see you are already looking into the carli systems. Don't forget thuren is a major player as well and you can also get a 6 inch system from them if interested.
If you have the 3 inch in the front you can still get the 3 inch springs for the front, shackles that will slightly lift the truck in the rear or get the full leafs which will slightly lift it as well in the rear.
Most people get 37's to fill out the fender wells but the 35's are just fine also. The ride quality you will get from these kits will be amazing compared to what you are used too. I used to run those lease roads and i can promise you, it will be much more enjoyable with a quality kit such as Carli or Thuren.
I'll shoot you a message as well.
Matthew 6:9-13, 2 Corinthians 5:20
See what we are up to on:
Or Email us at:
Dude_57 is offline
post #3 of 12 (permalink) Old 03-31-2019, 09:19 PM
cmh2007's Avatar
I just did thuren's 3 inch kit on my 2500 and it took a total of 5.5 hours with hand tools (my air compressor was broken) and manual jacks and stands in my drive way. I say give thuren a go and see how you like their stuff. I will post a pic of the truck later. I did 3 inch coils in the front and the 2 inch shackles in the back. Also remember that if you do go to a 6 inch there is a lot of stuff that requires replacement
2009 Ram 2500 CTD 4x4 SLT Lone Star, Patriot Blue. H&S XRT Pro 120hp tune with OD tuning. Full delete, Mega Canon, waiting on the EGR.
cmh2007 is offline
post #4 of 12 (permalink) Old 04-02-2019, 05:36 PM
avvblanc01's Avatar
if you go to a 6" I'd recommend going to 37's or 38's for the right visual proportions. Here's my truck on a 3" Carli Dominator system with 305/70/17 tires (a 34ish" tire) and then 37/125/20 tires. Both look good, but a 37 definitely looks better! Keep in mind though that you need to have the perfect wheel specs to stuff a 37 without major rubbing, and you'll also need high clearance control arms. A 35 will fit on stock arms no problem.
CMH2007 is right that the 6" kits do cost more as they have more components, but with ether Thuren or Carli, the 6" kits provide more wheel travel than the 3." On these kits, the height is actually just a byproduct of travel increase since the only way to increase travel on a solid axle truck is to increase the distance between the axle and frame. Hope that helps!
2006 Dodge Ram 2500 by Andrew Villablanca, on Flickr
2006 Ram 2500 by Andrew Villablanca, on Flickr
s10010001 likes this.
2006 2500 qcsb 4x4: auto, yukon hubs, Fass, 2mic Cat/baldwin 5mic FWS, 20" Trail Ready wheels & 37's, Edge insight, custom retroshop, heads/tails, Carli Dominator, Amp steps, Smarty JR 1993 D350 5spd, HID projectors, 4in TBE
avvblanc01 is offline
post #5 of 12 (permalink) Old 04-04-2019, 05:14 PM
Bad V2's Avatar
Just to clear, a 6" truck will NOT have more travel than a 3" truck. You will need a bump spacer, which will in turn, leave it at the same travel as a 3" truck. Good lookin truck, by the way! ^^^
2006 4x4 QCSB 2500 Laramie 5.9 Auto - Thuren equipped - Toyo R/T 37s
Bad V2 is offline
post #6 of 12 (permalink) Old 04-05-2019, 12:36 AM
s10010001's Avatar
@avvblanc01 Great looking rig, love the color match front end. Perfect life size too, Ill stay stock myself, but I do like that.
avvblanc01 likes this.
2008 6.7 2500 4x4 Auto 3.73
2000 5.9 3500 4x4 Auto 4.10 (sold)
s10010001 is offline
post #7 of 12 (permalink) Old 04-05-2019, 01:36 AM
avvblanc01's Avatar
The 6" carli systems do in fact increase travel over the 3" systems. The 6" has a 60% travel increase over stock, while the 3" systems have a 50% increase in travel over stock. Even though the 6" kits have bump drops, travel is stil added over both stock and the 3" system.
post #8 of 12 (permalink) Old 04-05-2019, 11:50 AM
Bad V2's Avatar
Okay, 10% is more, but just didn't want peeps thinking they're getting another 3". And peeps do think that.
Bad V2 is offline
post #9 of 12 (permalink) Old 04-05-2019, 12:28 PM
avvblanc01's Avatar
Hey as us lifted diesel truck owners know, every fraction of an inch counts!!
post #10 of 12 (permalink) Old 04-05-2019, 12:34 PM
ritchie1087's Avatar
thats a clean looking truck
ritchie1087 is offline
post #11 of 12 (permalink) Old 05-15-2019, 03:49 PM
02smokin's Avatar
6 on 35s here, I am on a 12 wide wheel though. I stayed with 35s to not throw off gearing as much as I tow almost every weekend in the summer
06 4dr,dynamic stg 4,64.5/73/.91,steed speed,anarchy EFi,fleece dual cp3s,Fleece bypass,Fass 165,ARP 425s,Manton springs/pushrods,pac brake,6" Carli,long arms, king 2.5's,WFO traction bars,35s
02smokin is offline
post #12 of 12 (permalink) Old 05-16-2019, 02:05 PM
Rhinopkc's Avatar
A couple of questions:
1. How much weight is in your truck at all times?
2. How fast do you want to drive off road?
6" vs 3" on a work truck is something that I like talking on the phone or in person about, so I can actually get a feel what the customer wants out of the truck. A 6" work truck can be a pain sometimes. I've had customers pay me to switch their 6" to a 3" after a short time of working out of the truck. Give me a call and we can go over the details.
02smokin likes this.
Give Us a Call for All Your Suspension, Lighting, and Wheel Needs!
424.241.3252 x700
Rhinopkc is offline
Similar Threads
Great, Not another Newbie "Lift" Thread willyg1997 4wd Suspension 33 06-04-2014 02:08 PM
2003 lift pump harness question SierraCTD 3rd Gen. Powertrain 1 10-08-2012 06:11 AM
3.5" Pure Performance Lift (w/ pics) jason250r 07.5 - 09 3rd Gen 6.7L Non-Powertrain 6 12-21-2010 10:52 PM
Joe G's fuel system writeup ykdave 94-98 Engine 2 04-22-2008 09:13 AM
