Keyed radio power supply ? - Dodge Cummins Diesel Forum
07.5 - 09 3rd Gen 6.7 Liter General Discussion General Chit Chat About the 6.7L 3rd generation Cummins - NO ADVERTISING
 2Likes
  • 1 Post By Asfwt
  • 1 Post By Asfwt
post #1 of 12 (permalink) Old 01-16-2020, 05:56 PM Thread Starter
Radio not getting the power feed from the keyed switch. It has 12v constant power but not 12v from the Keyed switch. Any wizards out there that can help me troubleshoot this. Do they know which fuse itís on. Itís not identified on the fuse chart. Everything else on the truck works as far as I know.
Thanks
09 4X4 QCSB stock
Asfwt is offline
post #2 of 12 (permalink) Old 01-17-2020, 10:40 AM Thread Starter
Letís see if I can come at this a different way. Anyone have a link to a wiring diagram for my truck? Yes I googled it but it was like going down a rabbit hole. Lots of links to all kinds of places but not exactly for my truck.
Thanks again,
Asfwt is offline
post #3 of 12 (permalink) Old 01-17-2020, 11:48 AM
b.lee's Avatar
Does it have an aftermarket radio installed or stock?
2012 2500 Cummins 4x4 - Mega
Laramie, Auto, EFI Live
b.lee is offline
post #4 of 12 (permalink) Old 01-17-2020, 12:14 PM Thread Starter
It has a pioneer aftermarket. The problem is on the truck side. I used a plug and play adapter from Crutchfield. Did not splice any wires. The factory plug from the truck side is still intact. But the white wire with orange stripe is not sending the signal to the radio to turn on.
B.lee thanks for your reply ,
Asfwt is offline
post #5 of 12 (permalink) Old 01-17-2020, 09:35 PM
I just did this tonight. I did not wire into any fuses though. As you look at the radio, do you see some connector plugs on the driver side of the radio just plugged into the plastic, not plugged into anything? I grabbed one of those, found which one worked on the key, then cut/spliced that into the red wire of the deck. Let me know if I need to clarify any while itís fresh on my mind. It should be your red wire as the keyed wire. On the connector it will have the yellow constant wire mating with the gray/striped wire from factory side but no keyed red wire. That red wire needs to go to the red wire I was referring to that is keyed.
I hope this helps some, let me know..
2009 Ram 2500 SXT 6.7 QCLB
morphrider is offline
post #6 of 12 (permalink) Old 01-18-2020, 07:13 AM Thread Starter
Thanks, Morphrider,
I am traveling the next few days but will check it out when I get back.
Asfwt is offline
post #7 of 12 (permalink) Old 01-19-2020, 04:34 PM
Originally Posted by Asfwt View Post
Thanks, Morphrider,
Let me know if you want pictures, I got back in there today to pre wire RCA cables out of the head unit for the sub and door speaker amp, Sirius satellite and microphone. Should have done it yesterday, lol. Took pics while I was in there so I knew what RCAís go where later on.
post #8 of 12 (permalink) Old 01-22-2020, 11:01 AM
maltstatt's Avatar
Can you please pm me or post the photos I’m having the same problem with our 08 5500
maltstatt is offline
post #9 of 12 (permalink) Old 01-22-2020, 11:27 AM
These are not connected to anything on my truck. I think these are for the electric 4wd knob, mine is on the floor. Another thing you can do is wire in to the fuse box with a terminal spade. This was just easy for me and will never be used for what it was intended for.
Sent from my LM-G710VM using Tapatalk
post #10 of 12 (permalink) Old 01-22-2020, 11:30 AM
maltstatt's Avatar
Thank you!
post #11 of 12 (permalink) Old 01-24-2020, 10:28 AM Thread Starter
Thanks for the photos. Hope to have time next week to work on it.
morphrider likes this.
Asfwt is offline
post #12 of 12 (permalink) Old 01-27-2020, 07:54 PM Thread Starter
So today I tried to find out why the keyed wire to the radio didnít work. But at the end i found it was most likely somewhere deep in the wire harness. So I spliced a power wire from the cigarette lighter to the radio. Problem solved.
Asfwt is offline
