Running a lil warm - Dodge Cummins Diesel Forum
07.5 - 09 3rd Gen 6.7 Liter General Discussion General Chit Chat About the 6.7L 3rd generation Cummins - NO ADVERTISING
post #1 of 6 (permalink) Old 04-15-2019, 05:44 PM Thread Starter
Running a lil warm
I just put a 190 degree thermostat in because it was going up into the 225 range and it still didn’t help so I wonder how much a coolant bypass would help
Cumnut2009 is offline
post #2 of 6 (permalink) Old 04-17-2019, 01:06 AM
GRUNT 11B's Avatar
Check all your coolers up front. Make sure they free of any oil, grime and debris. You also make have gotten a faulty thermostat.
06 QCLB 4X4 G56, SOUTHBEND DD, FASS 150, ARP STUDS, 50HP INJECTORS, EFI, HE351 S475 COMPOUNDS, FLUIDAMPR, HAMILTON PUSHRODS & 103# SPRINGS, 624 HP 1090 TQ 01 QCLB 4X4 AUTO, WHEELS, TIRES, STEERING WHEEL, CUMMINS, BUMPERS, FUEL TANK, SEATS, ETC.
GRUNT 11B is online now
post #3 of 6 (permalink) Old 04-17-2019, 02:38 AM
s10010001's Avatar
Running a lil warm
You donít need a coolant bypass. If itís getting to 225 easily there is a problem. 190 is stock on theaters trucks isnít it? My 08 is a 190.
Oil buildup isnít terrible yet common on theses trucks since the open breather isnít on the front like a 5.9. But certainly could be really dirty. A good hose cleaning should do the trick.
Iíd be looking at the water pump first, pull the belt, any play in the bearing/pull and itís going out.
How about the fan and clutch? Is your fan flipping to 1:1 properly?
What condition is it when itís gets that hot?
2008 6.7 2500 4x4 Auto 3.73
2000 5.9 3500 4x4 Auto 4.10 (sold)
s10010001 is offline
post #4 of 6 (permalink) Old 04-17-2019, 04:48 AM
Dodgetracker's Avatar
Maybe burp it and top it off thru port.
2008 2500 HD 4x4 6.7 CTD 68RFE. 4:10 Gears. AFE Stage II W/PG7. 275/70/R18 Nitto Trail Grappler on DCII rims. Reese 15k 5th Wheel Pulling a 2007 Heartland Cyclone 3795
United States Army, Retired
Dodgetracker is offline
post #5 of 6 (permalink) Old 04-17-2019, 12:05 PM
s10010001's Avatar
I was thinking that at first too, but really a little air will make it run 225? The breather is really to get all the air out of the EGR, thats why its not on other EGless 5.9/67 engines.
@Cumnut2009 needs to tell us what he's doing with the truck to get it to 225. If its getting to 225 easily then something big is wrong like a pump, fan clutch, or bad coolant (super old or oil in it). I have pulled my loaded 5th wheel up grades going into AZ, holding 70+ for extended periods of time and it doesnt overheat, its pretty hard to overheat these trucks so I don't think its gonna be something silly.
Also, if you get 225+ you risking blowing a HQ or worse if you keep driving it like that.
post #6 of 6 (permalink) Old 05-14-2019, 08:42 PM Thread Starter
I finally figured it out it would just do it driving normal but the water pump hadn’t shown any play at all then I started it on a chilly morning and heard it squeaking but thanks guys
Similar Threads
Truck is running warm.... 01xcab 89-93 Powertrain 6 09-05-2015 10:36 AM
Fix for Warm Running 48RE Rimcrew 3rd Gen. Powertrain 2 05-21-2015 03:32 PM
Trans running warm? Moochoff 3rd Gen. Powertrain 13 10-08-2012 07:27 PM
Another running warm question. Need help Arklahunter 3rd Gen. Powertrain 12 06-14-2012 08:43 AM
03 Running a little warm??? Kid Dynomite 3rd Gen. Powertrain 18 06-11-2011 06:07 PM
